9.0/sources/libs/nvdsinferserver/infer_proto_utils.h File Reference
Namespaces
 nvdsinferserver
Functions
InferDataType nvdsinferserver::dataTypeFromDsProto (ic::TensorDataType dt)
InferTensorOrder nvdsinferserver::tensorOrderFromDsProto (ic::TensorOrder o)
InferMediaFormat nvdsinferserver::mediaFormatFromDsProto (ic::MediaFormat f)
InferMemType nvdsinferserver::memTypeFromDsProto (ic::MemoryType t)
NvBufSurfTransform_Compute nvdsinferserver::computeHWFromDsProto (ic::FrameScalingHW h)
NvBufSurfTransform_Inter nvdsinferserver::scalingFilterFromDsProto (uint32_t filter)
bool nvdsinferserver::validateProtoConfig (ic::InferenceConfig &c, const std::string &path)
bool nvdsinferserver::compareModelRepo (const ic::TritonModelRepo &repoA, const ic::TritonModelRepo &repoB)
bool nvdsinferserver::hasTriton (const ic::BackendParams &params)
const ic::TritonParams & nvdsinferserver::getTritonParam (const ic::BackendParams &params)
ic::TritonParams * nvdsinferserver::mutableTriton (ic::BackendParams &params)
