NvBufSurfTransform Types and Functions
Defines types and functions of the NvBufSurfTransform application programming interface.
Data Structures
struct  NvBufSurfTransformRect
 Holds the coordinates of a rectangle. More...
struct  _NvBufSurfTransformConfigParams
 Holds configuration parameters for a transform/composite session. More...
struct  _NvBufSurfaceTransformParams
 Holds transform parameters for a transform call. More...
struct  _NvBufSurfTransformCompositeParams
 Holds composite parameters for a composite call. More...
struct  _NvBufSurfTransform_ColorParams
struct  _NvBufSurfTransformCompositeBlendParams
 Holds composite blend parameters for a composite blender call. More...
struct  _NvBufSurfTransformCompositeBlendParamsEx
 Holds extended composite blend parameters for NvBufSurfTransformMultiInputBufCompositeBlend and NvBufSurfTransformMultiInputBufCompositeBlendAsync API. More...
Typedefs
typedef struct _NvBufSurfTransformConfigParams NvBufSurfTransformConfigParams
typedef struct _NvBufSurfaceTransformParams NvBufSurfTransformParams
typedef struct _NvBufSurfTransformCompositeParams NvBufSurfTransformCompositeParams
typedef struct _NvBufSurfTransform_ColorParams NvBufSurfTransform_ColorParams
typedef struct _NvBufSurfTransformCompositeBlendParams NvBufSurfTransformCompositeBlendParams
typedef struct _NvBufSurfTransformCompositeBlendParamsEx NvBufSurfTransformCompositeBlendParamsEx
typedef struct NvBufSurfTransformSyncObj * NvBufSurfTransformSyncObj_t
 Holds the information about synchronization objects for asynchronous transform/composite APIs. More...
Enumerations
enum  NvBufSurfTransform_Compute {
  NvBufSurfTransformCompute_Default,
  NvBufSurfTransformCompute_GPU,
  NvBufSurfTransformCompute_VIC,
 Specifies compute devices used by NvBufSurfTransform. More...
enum  NvBufSurfTransform_Flip {
  NvBufSurfTransform_None,
  NvBufSurfTransform_Rotate90,
  NvBufSurfTransform_Rotate180,
  NvBufSurfTransform_Rotate270,
  NvBufSurfTransform_FlipX,
  NvBufSurfTransform_FlipY,
  NvBufSurfTransform_Transpose,
  NvBufSurfTransform_InvTranspose,
 Specifies video flip methods. More...
enum  NvBufSurfTransform_Inter {
  NvBufSurfTransformInter_Nearest = 0,
  NvBufSurfTransformInter_Bilinear,
  NvBufSurfTransformInter_Algo1,
  NvBufSurfTransformInter_Algo2,
  NvBufSurfTransformInter_Algo3,
  NvBufSurfTransformInter_Algo4,
  NvBufSurfTransformInter_Default,
 Specifies video interpolation methods. More...
enum  NvBufSurfTransform_Error {
  NvBufSurfTransformError_ROI_Error = -4,
  NvBufSurfTransformError_Invalid_Params = -3,
  NvBufSurfTransformError_Execution_Error = -2,
  NvBufSurfTransformError_Unsupported = -1,
  NvBufSurfTransformError_Success = 0,
 Specifies error codes returned by NvBufSurfTransform functions. More...
enum  NvBufSurfTransform_Transform_Flag {
  NVBUFSURF_TRANSFORM_CROP_SRC = 1,
  NVBUFSURF_TRANSFORM_CROP_DST = 1 << 1,
  NVBUFSURF_TRANSFORM_FILTER = 1 << 2,
  NVBUFSURF_TRANSFORM_FLIP = 1 << 3,
  NVBUFSURF_TRANSFORM_NORMALIZE = 1 << 4,
  NVBUFSURF_TRANSFORM_ALLOW_ODD_CROP = 1 << 5,
 Specifies transform types. More...
enum  NvBufSurfTransform_Composite_Flag {
  NVBUFSURF_TRANSFORM_COMPOSITE = 1,
  NVBUFSURF_TRANSFORM_BLEND = 1 << 1,
  NVBUFSURF_TRANSFORM_COMPOSITE_FILTER = 1 << 2,
 Specifies types of composition operations. More...
Functions
NvBufSurfTransform_Error NvBufSurfTransformSetSessionParams (NvBufSurfTransformConfigParams *config_params)
 Sets user-defined session parameters. More...
NvBufSurfTransform_Error NvBufSurfTransformGetSessionParams (NvBufSurfTransformConfigParams *config_params)
 Gets the session parameters used by NvBufSurfTransform(). More...
NvBufSurfTransform_Error NvBufSurfTransform (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformParams *transform_params)
 Performs a transformation on batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformComposite (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformCompositeParams *composite_params)
 Composites batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformAsync (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformParams *transform_params, NvBufSurfTransformSyncObj_t *sync_obj)
 An asynchronous (non-blocking) transformation on batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformCompositeAsync (NvBufSurface *src, NvBufSurface *dst, NvBufSurfTransformCompositeParams *composite_params, NvBufSurfTransformSyncObj_t *sync_obj)
 Composites batched input images Asynchronously (non-blocking). More...
NvBufSurfTransform_Error NvBufSurfTransformCompositeBlend (NvBufSurface *src0, NvBufSurface *src1, NvBufSurface *alpha, NvBufSurface *dst, NvBufSurfTransformCompositeBlendParams *blend_params)
 Composites/Blends batched input images. More...
NvBufSurfTransform_Error NvBufSurfTransformMultiInputBufCompositeBlend (NvBufSurface **src, NvBufSurface *dst, NvBufSurfTransformCompositeBlendParamsEx *composite_blend_params)
 Performs Composition and Blending on multiple input images(batch size=1) and provide single output image(batch size=1) More...
NvBufSurfTransform_Error NvBufSurfTransformMultiInputBufCompositeBlendAsync (NvBufSurface **src, NvBufSurface *dst, NvBufSurfTransformCompositeBlendParamsEx *composite_blend_params, NvBufSurfTransformSyncObj_t *sync_obj)
 Performs Composition and Blending on multiple input images(batch size=1) and provide single output image(batch size=1) Asynchronously (non-blocking). More...
NvBufSurfTransform_Error NvBufSurfTransformSyncObjWait (NvBufSurfTransformSyncObj_t sync_obj, uint32_t time_out)
 Wait on the synchronization object. More...
NvBufSurfTransform_Error NvBufSurfTransformSyncObjDestroy (NvBufSurfTransformSyncObj_t *sync_obj)
 Destroy the synchronization object. More...
NvBufSurfTransform_Error NvBufSurfTransformSyncObjFromFile (int file, NvBufSurfTransformSyncObj_t *sync_obj, unsigned int *num_sync_objs)
 Get the synchronization object from sync point FD. More...
NvBufSurfTransform_Error NvBufSurfTransformSetDefaultSession (void)
 Sets the default transform session as the current session for all upcoming transforms. More...
Typedef Documentation
◆ NvBufSurfTransform_ColorParams [1/2]
◆ NvBufSurfTransform_ColorParams [2/2]
◆ NvBufSurfTransformCompositeBlendParams [1/2]
◆ NvBufSurfTransformCompositeBlendParams [2/2]
◆ NvBufSurfTransformCompositeBlendParamsEx [1/2]
◆ NvBufSurfTransformCompositeBlendParamsEx [2/2]
◆ NvBufSurfTransformCompositeParams [1/2]
◆ NvBufSurfTransformCompositeParams [2/2]
◆ NvBufSurfTransformConfigParams [1/2]
◆ NvBufSurfTransformConfigParams [2/2]
◆ NvBufSurfTransformParams [1/2]
◆ NvBufSurfTransformParams [2/2]
◆ NvBufSurfTransformSyncObj_t [1/2]
typedef struct NvBufSurfTransformSyncObj* NvBufSurfTransformSyncObj_t
Definition at line 301 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransformSyncObj_t [2/2]
Definition at line 301 of file sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Composite_Flag [1/2]
Enumerator
Specifies a flag to describe the requested compositing operation.
Specifies a flag to describe the requested blending operation.
This flag is applicable for NvBufSurfTransformMultiInputBufCompositeBlend and NvBufSurfTransformMultiInputBufCompositeBlendAsync API to support blending operation in upcoming releases.
Specifies a composite to set the filter type.
Definition at line 142 of file sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Composite_Flag [2/2]
Enumerator
Definition at line 142 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Compute [1/2]
Enumerator
Specifies VIC as a compute device for Jetson or dGPU for an x86_64 system.
Specifies that the GPU is the compute device.
Specifies that the VIC as a compute device.
Supported only for Jetson.
Definition at line 46 of file sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Compute [2/2]
Enumerator
Definition at line 46 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Error [1/2]
Enumerator
Specifies an error in source or destination ROI.
Specifies invalid input parameters.
Specifies a runtime execution error.
Specifies an unsupported feature or format.
Specifies a successful operation.
Definition at line 106 of file sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Error [2/2]
Enumerator
Definition at line 106 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Flip [1/2]
Enumerator
Specifies no video flip.
Specifies rotating 90 degrees clockwise.
Specifies rotating 180 degree clockwise.
Specifies rotating 270 degree clockwise.
Specifies video flip with respect to the X-axis.
Specifies video flip with respect to the Y-axis.
Specifies video flip transpose.
Specifies video flip inverse transpose.
Definition at line 61 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Flip [2/2]
Enumerator
Definition at line 61 of file sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Inter [1/2]
Enumerator
Specifies Nearest Interpolation Method interpolation.
Specifies Bilinear Interpolation Method interpolation.
Specifies GPU-Cubic, VIC-5 Tap interpolation.
Specifies GPU-Super, VIC-10 Tap interpolation.
Specifies GPU-Lanzos, VIC-Smart interpolation.
Specifies GPU-Ignored, VIC-Nicest interpolation.
Specifies GPU-Nearest, VIC-Nearest interpolation.
Definition at line 85 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Inter [2/2]
Enumerator
Definition at line 85 of file sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Transform_Flag [1/2]
Enumerator
Specifies a transform to crop the source rectangle.
Specifies a transform to crop the destination rectangle.
Specifies a transform to set the filter type.
Specifies a transform to set the flip method.
Specifies a transform to normalize output.
Specifies a transform to allow odd crop.
Definition at line 123 of file 9.0/sources/includes/nvbufsurftransform.h.
◆ NvBufSurfTransform_Transform_Flag [2/2]
Enumerator
Definition at line 123 of file sources/includes/nvbufsurftransform.h.
Function Documentation
◆ NvBufSurfTransform()
NvBufSurfTransform_Error NvBufSurfTransform ( NvBufSurface src,
NvBufSurface dst,
NvBufSurfTransformParams transform_params
If user-defined session parameters are to be used, call NvBufSurfTransformSetSessionParams() before calling this function.
Parameters
[in]srcA pointer to input batched buffers to be transformed.
[out]dstA pointer to a caller-allocated location where transformed output is to be stored.
When destination cropping is performed, memory outside
the crop location is not touched, and may contain stale information. The caller must perform a memset before calling this function if stale information must be eliminated.
Parameters
[in]transform_paramsA pointer to an NvBufSurfTransformParams structure which specifies the type of transform to be performed. They may include any combination of scaling, format conversion, and cropping for both source and destination. Flipping and rotation are supported on VIC.
Returns
An NvBufSurfTransform_Error value indicating success or failure.
◆ NvBufSurfTransformAsync()
NvBufSurfTransform_Error NvBufSurfTransformAsync ( NvBufSurface src,
NvBufSurface dst,
NvBufSurfTransformParams transform_params,
Parameters
Parameters
[in]transform_paramsA pointer to an NvBufSurfTransformParams structure which specifies the type of transform to be performed. They may include any combination of scaling, format conversion, and cropping for both source and destination. Flipping and rotation are supported on VIC/GPU.
[out]sync_objA pointer to an NvBufSurfTransformSyncObj structure which holds synchronization information of the current transform call. NvBufSurfTransfromSyncObjWait() API to be called on this object to wait for transformation to complete. NvBufSurfTransformSyncObjDestroy API should be called after NvBufSurfTransformSyncObjWait API to release the objects If the parameter is NULL, the call would return only after the transform is complete.
Returns
◆ NvBufSurfTransformComposite()
NvBufSurfTransform_Error NvBufSurfTransformComposite ( NvBufSurface src,
NvBufSurface dst,
NvBufSurfTransformCompositeParams composite_params
The compositer scales and stitches batched buffers indicated by src into a single destination buffer, dst.
Parameters
[out]dstA pointer a caller-allocated location (a single buffer) where composited output is to be stored.
[in]composite_paramsA pointer to an NvBufSurfTransformCompositeParams structure which specifies the compositing operation to be performed, e.g., the source and destination rectangles in src and dst.
Returns
◆ NvBufSurfTransformCompositeAsync()
NvBufSurfTransform_Error NvBufSurfTransformCompositeAsync ( NvBufSurface src,
NvBufSurface dst,
NvBufSurfTransformCompositeParams composite_params,
Parameters
[in]srcA pointer to input batched buffers to be composited.
[out]sync_objA pointer to an NvBufSurfTransformSyncObj structure which holds synchronization information of the current composite call. ref\ NvBufSurfTransfromSyncObjWait() API to be called on this object to wait for composition to complete. NvBufSurfTransformSyncObjDestroy API should be called after NvBufSurfTransformSyncObjWait API to release the objects If the parameter is NULL, the call would return only after the composite is complete.
Returns
◆ NvBufSurfTransformCompositeBlend()
NvBufSurfTransform_Error NvBufSurfTransformCompositeBlend ( NvBufSurface src0,
NvBufSurface src1,
NvBufSurface alpha,
NvBufSurface dst,
NvBufSurfTransformCompositeBlendParams blend_params
The compositer scales and blends batched buffers indicated by src0 with src1 into a batched destination buffer dst using alpha as the blending weights. A Linear interpolation operation is performed to get the final pix value each of src0, src1, alpha and dst have one to one mapping For each pixel the following linear interpolation is performed. dst = ( src0* alpha + src1* (255.0 - alpha))/255.0 If user-defined session parameters are to be used, call NvBufSurfTransformSetSessionParams() before calling this function.
Parameters
[in]src0A pointer to input batched buffers to be blend.
[in]src1A pointer to input batched buffers to be blend with.
[in]alphaA pointer to input batched buffers which has blending weights.
[out]dstA pointer to output batched buffers where blended composite output is stored
[in]blend_paramsA pointer to an NvBufSurfTransformCompositeBlendParams structure which specifies the compositing operation to be performed
Returns
◆ NvBufSurfTransformGetSessionParams()
NvBufSurfTransform_Error NvBufSurfTransformGetSessionParams ( NvBufSurfTransformConfigParams config_params)
Parameters
[out]config_paramsA pointer to a caller-allocated structure to be populated with the session parameters used.
Returns
◆ NvBufSurfTransformMultiInputBufCompositeBlend()
NvBufSurfTransform_Error NvBufSurfTransformMultiInputBufCompositeBlend ( NvBufSurface **  src,
NvBufSurface dst,
NvBufSurfTransformCompositeBlendParamsEx composite_blend_params
Composites and blends batched(batch size=1) input buffers pointed by src pointer. Compositer scales, stitches and blends batched buffers pointed by src into single dst buffer (batch size=1), the parameters for composition and blending is provided by composite_blend_params. Use NvBufSurfTransformSetSessionParams before each call, if user defined session parameters are to be used. It is different than the NvBufSurfTransformCompositeBlend API and It is currently supported on Jetson only.
Parameters
[in]srcpointer (multiple buffer) to input batched(batch size=1) buffers to be transformed.
[out]dstpointer (single buffer) where composited output would be stored.
[in]composite_blend_paramspointer to NvBufSurfTransformCompositeBlendParamsEx structure.
Returns
NvBufSurfTransform_Error indicating success or failure.
◆ NvBufSurfTransformMultiInputBufCompositeBlendAsync()
NvBufSurfTransform_Error NvBufSurfTransformMultiInputBufCompositeBlendAsync ( NvBufSurface **  src,
NvBufSurface dst,
NvBufSurfTransformCompositeBlendParamsEx composite_blend_params,
Parameters
[in]composite_blend_paramspointer to NvBufSurfTransformCompositeParams structure.
Returns
◆ NvBufSurfTransformSetDefaultSession()
NvBufSurfTransform_Error NvBufSurfTransformSetDefaultSession ( void  )
Returns
◆ NvBufSurfTransformSetSessionParams()
NvBufSurfTransform_Error NvBufSurfTransformSetSessionParams ( NvBufSurfTransformConfigParams config_params)
If user-defined session parameters are set, they override the NvBufSurfTransform() function's default session.
Parameters
[in]config_paramsA pointer to a structure that is populated with the session parameters to be used.
Returns
◆ NvBufSurfTransformSyncObjDestroy()
NvBufSurfTransform_Error NvBufSurfTransformSyncObjDestroy ( NvBufSurfTransformSyncObj_t sync_obj)
The API deletes the sync_obj which was used for previous transform/composite Asynchronous calls
Parameters
[in]sync_objA pointer sync_obj, which the API will delete
Returns
Referenced by nvdsinferserver::BaseBatchBuffer::waitForSyncObj().
◆ NvBufSurfTransformSyncObjFromFile()
NvBufSurfTransform_Error NvBufSurfTransformSyncObjFromFile ( int  file,
unsigned int *  num_sync_objs
The API gets the corresponding synchronization object from sync point FD. It currently assumes one synchronization object for one file descriptor as all the transform APIs supports single synchronization object only.
Parameters
[in]filesync point file descriptor.
[out]sync_objA pointer to an NvBufSurfTransformSyncObj_t which is a pointer to an array of NvBufSurfTransformSyncObj allocated in the function having size (num_sync_objs * sizeof(NvBufSurfTransformSyncObj)) which holds synchronization information corresponding to FD.
[out]num_sync_objsnumber of sync objects.
Returns
◆ NvBufSurfTransformSyncObjWait()
NvBufSurfTransform_Error NvBufSurfTransformSyncObjWait ( NvBufSurfTransformSyncObj_t  sync_obj,
uint32_t  time_out
The API waits on the synchronization object to finish the corresponding processing of transform/composite calls or returns on time_out
Parameters
[in]sync_objA pointer to sync object on which the API should wait
[in]time_outMaximum time in ms API should wait before returning, only Only applicable for VIC as of now.
Returns
