7.1 Release
Latency Measurement API
Defines an API for measuring latency in modules.
Data Structures
struct  _NvDsMetaSubCompLatency
 Holds information about latency of the given subcomponent. More...
struct  _NvDsMetaCompLatency
 Holds information about latency of the given component. More...
struct  NvDsFrameLatencyInfo
 Holds information about the latency of a given frame. More...
Macros
#define MAX_COMPONENT_LEN   64
#define nvds_enable_latency_measurement   (nvds_get_enable_latency_measurement())
 Defines a pseudo-variable whose value is the return value of nvds_get_enable_latency_measurement(). More...
Typedefs
typedef struct _NvDsMetaSubCompLatency NvDsMetaSubCompLatency
typedef struct _NvDsMetaCompLatency NvDsMetaCompLatency
Functions
NvDsUserMetanvds_set_input_system_timestamp (GstBuffer *buffer, gchar *element_name)
 Sets the system timestamp when the Gst Buffer arrives as input at the component. More...
gboolean nvds_set_output_system_timestamp (GstBuffer *buffer, gchar *element_name)
 Sets the system timestamp when a Gst Buffer that is pushed to the downstream component. More...
guint nvds_measure_buffer_latency (GstBuffer *buf, NvDsFrameLatencyInfo *latency_info)
 Measures the latency of all frames present in the current batch. More...
gboolean nvds_get_enable_latency_measurement (void)
 Indicates whether the environment variable NVDS_ENABLE_LATENCY_MEASUREMENT is exported. More...
void nvds_add_reference_timestamp_meta (GstBuffer *buffer, gchar *element_name, guint frame_id)
 Adds the reference timestamp metadata for this buffer Note: element_name == "audiodecoder" and "nvv4l2decoder" will be used for latency measurement calculations where the timestamp will be used by API: nvds_measure_buffer_latency() to calculate the latency of buffers downstream relative to the decoder. More...
◆ MAX_COMPONENT_LEN
Definition at line 34 of file nvds_latency_meta.h.
◆ nvds_enable_latency_measurement
It indicates whether latency measurement is enabled.
Definition at line 172 of file nvds_latency_meta.h.
Typedef Documentation
◆ NvDsMetaCompLatency
◆ NvDsMetaSubCompLatency
Function Documentation
◆ nvds_add_reference_timestamp_meta()
void nvds_add_reference_timestamp_meta ( GstBuffer buffer,
gchar *  element_name,
guint  frame_id
Parameters
[in]bufferA pointer to the arriving Gst Buffer.
[in]element_nameA pointer to the name of the component for which latency is to be measured.
[in]frame_idThe id/number of this frame/buffer produced by the component that produces this buffer.
◆ nvds_get_enable_latency_measurement()
gboolean nvds_get_enable_latency_measurement ( void  )
Returns
True if the environment variable is exported, or false otherwise.
◆ nvds_measure_buffer_latency()
guint nvds_measure_buffer_latency ( GstBuffer buf,
NvDsFrameLatencyInfo latency_info
The latency is computed from decoder input up to the point this API is called. You can install the probe on either pad of the component and call this function to measure the latency.
Parameters
[in]bufA pointer to a Gst Buffer to which NvDsBatchMeta is attached as metadata.
[out]latency_infoA pointer to an NvDsFrameLatencyInfo structure allocated for a batch of this size. The function fills it with information about all of the sources.
◆ nvds_set_input_system_timestamp()
NvDsUserMeta* nvds_set_input_system_timestamp ( GstBuffer buffer,
Parameters
Returns
A pointer to a NvDsUserMeta structure which holds an NvDsMetaCompLatency as NvDsUserMeta.user_meta_data.
◆ nvds_set_output_system_timestamp()
gboolean nvds_set_output_system_timestamp ( GstBuffer buffer,
This is a corresponding function to nvds_set_input_system_timestamp().
Parameters
[in]bufferA pointer to a Gst Buffer to be pushed to the downstream component.
Returns
TRUE if the timestamp is attached successfully, or FALSE otherwise.
