deepstream::CommonFactory Class Referenceabstract
r\Represents a unified interface for managing custom objects and factories
Definition at line 35 of file service-maker/includes/common_factory.hpp.
Public Member Functions
virtual ~CommonFactory ()=default
 CommonFactory (const CommonFactory &)=delete
 CommonFactory (CommonFactory &&)=delete
CommonFactoryoperator= (const CommonFactory &)=delete
CommonFactoryoperator= (CommonFactory &&)=delete
virtual std::unique_ptr< CustomObjectcreateObject (const std::string &factory_key, const std::string &name)=0
 Create a custom object from a custom factory. More...
virtual bool addCustomFactory (CustomFactory *factory, const char *key)=0
 Add a custom factory. More...
virtual CustomFactorygetCustomFactory (const char *factory_name)=0
 Find a custom factory that supports a certan object type. More...
static CommonFactorygetInstance ()
 Acquire the reference of the singleton. More...
Protected Member Functions
Static Protected Member Functions
static bool _load (const std::string &plugin_name)
◆ ~CommonFactory() [1/2]
virtual deepstream::CommonFactory::~CommonFactory ( )
virtualdefault
◆ CommonFactory() [1/6]
deepstream::CommonFactory::CommonFactory ( const CommonFactory )
delete
◆ CommonFactory() [2/6]
deepstream::CommonFactory::CommonFactory ( CommonFactory &&  )
delete
◆ CommonFactory() [3/6]
deepstream::CommonFactory::CommonFactory ( )
protecteddefault
◆ ~CommonFactory() [2/2]
virtualdefault
◆ CommonFactory() [4/6]
delete
◆ CommonFactory() [5/6]
delete
◆ CommonFactory() [6/6]
protecteddefault
Member Function Documentation
◆ _load() [1/2]
static bool deepstream::CommonFactory::_load ( const std::string &  plugin_name)
staticprotected
◆ _load() [2/2]
staticprotected
◆ addCustomFactory() [1/2]
virtual bool deepstream::CommonFactory::addCustomFactory ( CustomFactory factory,
const char *  key
pure virtual
Once a custom factory is added, the type of object defined within the factory can be created through common factory interface.
Parameters
[in]factorypointer to the factory
[in]keykey used to identify the factory
◆ addCustomFactory() [2/2]
const char *  key
pure virtual
Parameters
◆ createObject() [1/2]
virtual std::unique_ptr<CustomObject> deepstream::CommonFactory::createObject ( const std::string &  factory_key,
const std::string &  name
pure virtual
Parameters
[in]factory_keyidentifier of the factory where the custom object is supported
[in]namename for the object to be created.
◆ createObject() [2/2]
pure virtual
Parameters
◆ getCustomFactory() [1/2]
virtual CustomFactory* deepstream::CommonFactory::getCustomFactory ( const char *  factory_name)
pure virtual
Parameters
[in]factory_namename of the factory
Returns
Pointer of a custom factory that supports the type
◆ getCustomFactory() [2/2]
pure virtual
Parameters
Returns
◆ getInstance() [1/2]
static CommonFactory& deepstream::CommonFactory::getInstance ( )
static
◆ getInstance() [2/2]
static
◆ operator=() [1/4]
CommonFactory& deepstream::CommonFactory::operator= ( CommonFactory &&  )
delete
◆ operator=() [2/4]
delete
◆ operator=() [3/4]
CommonFactory& deepstream::CommonFactory::operator= ( const CommonFactory )
delete
◆ operator=() [4/4]
delete
