deepstream::CustomObject Class Reference
Base class for all the custom objects.
Definition at line 34 of file service-maker/includes/custom_object.hpp.
Inheritance diagram for deepstream::CustomObject:
Collaboration diagram for deepstream::CustomObject:
Public Member Functions
 CustomObject (unsigned long type_id, const char *factory, const std::string &name)
 Constructor. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the object's type id. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::string param_spec_
 property spec in YAML format More...
std::map< std::string, Object::Valueproperties_
 property map More...
GstObjectobject_
◆ CustomObject() [1/2]
deepstream::CustomObject::CustomObject ( unsigned long  type_id,
const char *  factory,
const std::string &  name
Constructor.
Parameters
[in]type_ida unique 64-bit number to represent the type
[in]factoryname of the factory who creates the instance
[in]nameN=name given to the object instance
◆ CustomObject() [2/2]
Constructor.
Parameters
Member Function Documentation
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::CustomObject::get_ ( const std::string &  name)
protectedvirtual
Reimplemented from deepstream::Object.
◆ get_() [2/2]
protectedvirtual
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set() [6/6]
inherited
◆ set_() [1/4]
virtual void deepstream::CustomObject::set_ ( const std::string &  name,
const Value value
protectedvirtual
◆ set_() [2/4]
const Value value
protectedvirtual
◆ set_() [3/4]
const YAML::Node &  value
protectedvirtual
◆ set_() [4/4]
protectedvirtual
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::Object::type ( )
staticinherited
◆ type() [2/2]
staticinherited
Field Documentation
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ param_spec_
std::string deepstream::CustomObject::param_spec_
protected
Definition at line 51 of file service-maker/includes/custom_object.hpp.
◆ properties_
std::map< std::string, Object::Value > deepstream::CustomObject::properties_
protected
property map
Definition at line 53 of file service-maker/includes/custom_object.hpp.
