deepstream::CustomFactory Class Referenceabstract
Interface definition for a custom factory.
Definition at line 32 of file service-maker/includes/custom_factory.hpp.
Inheritance diagram for deepstream::CustomFactory:
Collaboration diagram for deepstream::CustomFactory:
Public Member Functions
 CustomFactory (const std::string &name, unsigned long factory_type)
 Constructor. More...
virtual ~CustomFactory ()
 Destructor. More...
virtual CustomObjectcreateObject (const std::string &name)=0
 Virtual method for creating custom object. More...
unsigned long getObjectType ()
 Return the type id of objects created by this factory. More...
 Destructor. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the object's type id. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
GstObjectobject_
◆ CustomFactory() [1/2]
deepstream::CustomFactory::CustomFactory ( const std::string &  name,
Constructor.
Parameters
[in]namename of the factory instance
[in]factory_typeunique type id of this factory object
◆ ~CustomFactory() [1/2]
virtual deepstream::CustomFactory::~CustomFactory ( )
virtual
Destructor.
◆ CustomFactory() [2/2]
Constructor.
Parameters
◆ ~CustomFactory() [2/2]
virtual
Destructor.
Member Function Documentation
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ createObject() [1/2]
virtual CustomObject* deepstream::CustomFactory::createObject ( const std::string &  name)
pure virtual
Parameters
[in]namename of the object instance
◆ createObject() [2/2]
pure virtual
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::Object::get_ ( const std::string &  name)
protectedvirtualinherited
◆ get_() [2/2]
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getObjectType() [1/2]
unsigned long deepstream::CustomFactory::getObjectType ( )
◆ getObjectType() [2/2]
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set() [6/6]
inherited
◆ set_() [1/4]
virtual void deepstream::Object::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::Object::type ( )
staticinherited
◆ type() [2/2]
staticinherited
Field Documentation
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
