8.0 Release
deepstream::DataFeeder::IDataProvider Class Referenceabstract
required interface for a data feeder
Invoked when the data is required by the element to which the data feeder is attached.
Definition at line 47 of file data_feeder.hpp.
Inheritance diagram for deepstream::DataFeeder::IDataProvider:
Public Member Functions
virtual Buffer read (DataFeeder &feeder, unsigned int size, bool &eos)=0
 Read a data block. More...
virtual ~IDataProvider ()
◆ ~IDataProvider()
virtual deepstream::DataFeeder::IDataProvider::~IDataProvider ( )
inlinevirtual
Definition at line 61 of file data_feeder.hpp.
Member Function Documentation
◆ read()
virtual Buffer deepstream::DataFeeder::IDataProvider::read ( DataFeeder feeder,
unsigned int  size,
bool &  eos
pure virtual
Read a data block.
Implementation of this virtual method requires generating a buffer based on the data request.
Parameters
[in]feederreference to the data feeder
[in]sizenumber of bytes requested by the feeder
[out]eosindication of "end of stream"
Returns
a buffer with data
Implemented in deepstream::LiDARDataSource, and deepstream::FileDataSource.
