deepstream::DataFeeder Class Reference
A specific signal handler for feeding data.
Users must implement the IDataProvider interface to create a data feeder. Data feeder can only be attached to elements that supports "need-data/enough-data" signal, typically an "appsrc".
Definition at line 39 of file service-maker/includes/data_feeder.hpp.
Inheritance diagram for deepstream::DataFeeder:
Collaboration diagram for deepstream::DataFeeder:
Data Structures
class  IDataProvider
 required interface for a data feeder More...
Public Member Functions
 DataFeeder (const std::string &name, IDataProvider *provider)
 Constructor. More...
 DataFeeder (const std::string &name, const char *factory, IDataProvider *provider)
virtual ~DataFeeder ()
 Destructor. More...
void startFeed (void *appsrc, unsigned int size)
 Start feeding, called by the pipeline. More...
void stopFeed ()
 Stop feeding, called by the pipeline. More...
bool doFeed (void *appsrc, unsigned int size)
 Complete the feeding, called by the feeding thread. More...
 Destructor. More...
void stopFeed ()
void * getCallbackFn (const std::string &name) const
 Return the callback for a specific signal. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the type id assigned to signal handler. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::unique_ptr< IDataProviderdata_provider_
std::thread worker_
std::mutex mutex_
std::condition_variable cv_data_
unsigned int data_size_
bool data_ready_
void * appsrc_
bool eos_
std::unique_ptr< IActionProviderprovider_
std::string param_spec_
 property spec in YAML format More...
std::map< std::string, Object::Valueproperties_
 property map More...
GstObjectobject_
◆ DataFeeder() [1/4]
deepstream::DataFeeder::DataFeeder ( const std::string &  name,
IDataProvider provider
Constructor.
Create a data feeder with a user implemented data provider interface
Parameters
[in]namename of the instance
[in]handlerimplementation of the IDataProvider interface
◆ DataFeeder() [2/4]
const char *  factory,
Constructor.
Parameters
[in]factoryname of the factory to create the instance
◆ ~DataFeeder() [1/2]
virtual deepstream::DataFeeder::~DataFeeder ( )
virtual
Destructor.
◆ DataFeeder() [3/4]
Constructor.
Parameters
◆ DataFeeder() [4/4]
Constructor.
Parameters
◆ ~DataFeeder() [2/2]
virtual
Destructor.
Member Function Documentation
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ doFeed() [1/2]
bool deepstream::DataFeeder::doFeed ( void *  appsrc,
unsigned int  size
◆ doFeed() [2/2]
unsigned int  size
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::CustomObject::get_ ( const std::string &  name)
protectedvirtualinherited
Reimplemented from deepstream::Object.
◆ get_() [2/2]
◆ getCallbackFn() [1/2]
void* deepstream::SignalHandler::getCallbackFn ( const std::string &  name) const
inherited
◆ getCallbackFn() [2/2]
inherited
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file service-maker/includes/object.hpp.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set() [6/6]
inherited
◆ set_() [1/4]
virtual void deepstream::CustomObject::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ startFeed() [1/2]
void deepstream::DataFeeder::startFeed ( void *  appsrc,
unsigned int  size
◆ startFeed() [2/2]
unsigned int  size
◆ stopFeed() [1/2]
void deepstream::DataFeeder::stopFeed ( )
◆ stopFeed() [2/2]
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::SignalHandler::type ( )
staticinherited
◆ type() [2/2]
staticinherited
Field Documentation
◆ appsrc_
void * deepstream::DataFeeder::appsrc_
protected
Definition at line 102 of file service-maker/includes/data_feeder.hpp.
◆ cv_data_
std::condition_variable deepstream::DataFeeder::cv_data_
protected
Definition at line 99 of file service-maker/includes/data_feeder.hpp.
◆ data_provider_
std::unique_ptr< IDataProvider > deepstream::DataFeeder::data_provider_
protected
Definition at line 96 of file service-maker/includes/data_feeder.hpp.
◆ data_ready_
bool deepstream::DataFeeder::data_ready_
protected
Definition at line 101 of file service-maker/includes/data_feeder.hpp.
◆ data_size_
unsigned int deepstream::DataFeeder::data_size_
protected
Definition at line 100 of file service-maker/includes/data_feeder.hpp.
◆ eos_
bool deepstream::DataFeeder::eos_
protected
Definition at line 103 of file service-maker/includes/data_feeder.hpp.
◆ mutex_
std::mutex deepstream::DataFeeder::mutex_
protected
Definition at line 98 of file service-maker/includes/data_feeder.hpp.
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ param_spec_
std::string deepstream::CustomObject::param_spec_
protectedinherited
Definition at line 51 of file service-maker/includes/custom_object.hpp.
◆ properties_
std::map< std::string, Object::Value > deepstream::CustomObject::properties_
protectedinherited
property map
Definition at line 53 of file service-maker/includes/custom_object.hpp.
◆ provider_
std::unique_ptr< IActionProvider > deepstream::SignalHandler::provider_
protectedinherited
Definition at line 91 of file service-maker/includes/signal_handler.hpp.
◆ worker_
std::thread deepstream::DataFeeder::worker_
protected
Definition at line 97 of file service-maker/includes/data_feeder.hpp.
