deepstream::ObjectMetadata Class Reference
Object metadata.
The metadata is for describing a detected object
Definition at line 172 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::ObjectMetadata:
Collaboration diagram for deepstream::ObjectMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< ObjectMetadata > > Iterator
Public Member Functions
 ObjectMetadata (void *data=nullptr)
 Constructor through opaque data pointer. More...
virtual ~ObjectMetadata ()
 Destructor. More...
unsigned int uniqueComponentId () const
 Number to identify the unique component that generates the metadata. More...
void setUniqueComponentId (unsigned int)
unsigned int classId () const
 Number to identify the class of the object. More...
void setClassId (unsigned int)
unsigned long int objectId () const
 Number to identify the object which is tracked in the scene. More...
void setObjectId (unsigned long)
float confidence () const
 Confidence level. More...
void setConfidence (float)
float trackerConfidence () const
 Confidence level from tracker. More...
void setTrackerConfidence (float)
NvOSD_RectParamsrectParams () const
 Bounding box of the object. More...
void setRectParams (const NvOSD_RectParams &)
NvOSD_MaskParamsmaskParams () const
 Holds mask parameters for the object. More...
void setMaskParams (const NvOSD_MaskParams &)
NvOSD_TextParamstextParams () const
 Formated text description of the object, controlling osd display. More...
void setTextParams (const NvOSD_TextParams &)
std::string label () const
 A string to describe the object class. More...
void setLabel (std::string)
NvBbox_CoordsnvBboxInfo () const
void setNvBboxInfo (const NvBbox_Coords &)
unsigned int iterate (const std::function< void(const ClassifierMetadata &)> &func) const
 Iterate the classifier metadata within it. More...
void initiateIterator (ClassifierMetadata::Iterator &) const
 Get the iterator for object metadata within it. More...
unsigned int iterate (const std::function< void(const UserMetadata &)> &func, int meta_type) const
 Iterate the user metadata within it. More...
void initiateIterator (UserMetadata::Iterator &, int meta_type) const
 Get the iterator for user metadata within it. More...
void append (const UserMetadata &)
 Append user metadata to the object. More...
 Destructor. More...
virtual operator bool ()
 operator to check if a metadata is void More...
Protected Attributes
void * data_
Friends
class FrameMetadata
Member Typedef Documentation
◆ Iterator [1/2]
◆ Iterator [2/2]
◆ ObjectMetadata() [1/2]
deepstream::ObjectMetadata::ObjectMetadata ( void *  data = nullptr)
By default an empty object metadata object is created.
◆ ~ObjectMetadata() [1/2]
virtual deepstream::ObjectMetadata::~ObjectMetadata ( )
virtual
Destructor.
◆ ObjectMetadata() [2/2]
◆ ~ObjectMetadata() [2/2]
virtual
Destructor.
Member Function Documentation
◆ append() [1/2]
void deepstream::ObjectMetadata::append ( const UserMetadata )
◆ append() [2/2]
◆ classId() [1/2]
unsigned int deepstream::ObjectMetadata::classId ( ) const
Referenced by deepstream::ObjectCounter::consume(), and deepstream::CountMarker::handleData().
◆ classId() [2/2]
◆ confidence() [1/2]
float deepstream::ObjectMetadata::confidence ( ) const
Confidence level.
◆ confidence() [2/2]
◆ initiateIterator() [1/4]
void deepstream::ObjectMetadata::initiateIterator ( ClassifierMetadata::Iterator ) const
◆ initiateIterator() [2/4]
◆ initiateIterator() [3/4]
void deepstream::ObjectMetadata::initiateIterator ( UserMetadata::Iterator ,
int  meta_type
) const
◆ initiateIterator() [4/4]
int  meta_type
) const
◆ iterate() [1/4]
unsigned int deepstream::ObjectMetadata::iterate ( const std::function< void(const ClassifierMetadata &)> &  func) const
Referenced by deepstream::NvDsKittiDump::generateTrackerKittiDump().
◆ iterate() [2/4]
◆ iterate() [3/4]
unsigned int deepstream::ObjectMetadata::iterate ( const std::function< void(const UserMetadata &)> &  func,
int  meta_type
) const
◆ iterate() [4/4]
int  meta_type
) const
◆ label() [1/2]
std::string deepstream::ObjectMetadata::label ( ) const
◆ label() [2/2]
◆ maskParams() [1/2]
NvOSD_MaskParams& deepstream::ObjectMetadata::maskParams ( ) const
This mask is overlayed on object
◆ maskParams() [2/2]
◆ nvBboxInfo() [1/2]
NvBbox_Coords& deepstream::ObjectMetadata::nvBboxInfo ( ) const
◆ nvBboxInfo() [2/2]
◆ objectId() [1/2]
unsigned long int deepstream::ObjectMetadata::objectId ( ) const
Referenced by deepstream::NvDsKittiDump::generateInferenceKittiDump(), and deepstream::NvDsKittiDump::generateTrackerKittiDump().
◆ objectId() [2/2]
◆ operator bool() [1/2]
virtual deepstream::Metadata::operator bool ( )
inlinevirtualinherited
Reimplemented in deepstream::UserMetadata, and deepstream::UserMetadata.
Definition at line 51 of file 9.0/service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 51 of file service-maker/includes/metadata.hpp.
◆ rectParams() [1/2]
NvOSD_RectParams& deepstream::ObjectMetadata::rectParams ( ) const
◆ rectParams() [2/2]
Referenced by deepstream::NvDsKittiDump::generateInferenceKittiDump().
◆ setClassId() [1/2]
void deepstream::ObjectMetadata::setClassId ( unsigned int  )
◆ setClassId() [2/2]
◆ setConfidence() [1/2]
void deepstream::ObjectMetadata::setConfidence ( float  )
◆ setConfidence() [2/2]
◆ setLabel() [1/2]
void deepstream::ObjectMetadata::setLabel ( std::string  )
◆ setLabel() [2/2]
◆ setMaskParams() [1/2]
void deepstream::ObjectMetadata::setMaskParams ( const NvOSD_MaskParams )
◆ setMaskParams() [2/2]
◆ setNvBboxInfo() [1/2]
void deepstream::ObjectMetadata::setNvBboxInfo ( const NvBbox_Coords )
◆ setNvBboxInfo() [2/2]
◆ setObjectId() [1/2]
void deepstream::ObjectMetadata::setObjectId ( unsigned long  )
◆ setObjectId() [2/2]
◆ setRectParams() [1/2]
void deepstream::ObjectMetadata::setRectParams ( const NvOSD_RectParams )
◆ setRectParams() [2/2]
◆ setTextParams() [1/2]
void deepstream::ObjectMetadata::setTextParams ( const NvOSD_TextParams )
◆ setTextParams() [2/2]
◆ setTrackerConfidence() [1/2]
void deepstream::ObjectMetadata::setTrackerConfidence ( float  )
◆ setTrackerConfidence() [2/2]
◆ setUniqueComponentId() [1/2]
void deepstream::ObjectMetadata::setUniqueComponentId ( unsigned int  )
◆ setUniqueComponentId() [2/2]
◆ textParams() [1/2]
NvOSD_TextParams& deepstream::ObjectMetadata::textParams ( ) const
◆ textParams() [2/2]
◆ trackerConfidence() [1/2]
float deepstream::ObjectMetadata::trackerConfidence ( ) const
◆ trackerConfidence() [2/2]
◆ uniqueComponentId() [1/2]
unsigned int deepstream::ObjectMetadata::uniqueComponentId ( ) const
◆ uniqueComponentId() [2/2]
Friends And Related Function Documentation
◆ FrameMetadata
FrameMetadata
friend
Definition at line 230 of file service-maker/includes/metadata.hpp.
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
