deepstream::FrameMetadata Class Reference
Holds information for a single frame.
Iterable via iterators for ObjectMetadata and DisplayMetadata.
Definition at line 437 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::FrameMetadata:
Collaboration diagram for deepstream::FrameMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< FrameMetadata > > Iterator
Public Member Functions
 FrameMetadata (void *data=nullptr)
 Constructor through opaque data pointer. More...
virtual ~FrameMetadata ()
 Destructor. More...
unsigned int iterate (const std::function< void(const ObjectMetadata &)> &func) const
 Iterate the object metadata within it. More...
void initiateIterator (ObjectMetadata::Iterator &) const
 Get the iterator for object metadata within it. More...
unsigned int iterate (const std::function< void(const DisplayMetadata &)> &func) const
 Iterate the display metadata within it. More...
void initiateIterator (DisplayMetadata::Iterator &) const
 Get the iterator for display metadata within it. More...
unsigned int iterate (const std::function< void(const UserMetadata &)> &func, int meta_type) const
 Iterate the user metadata within it. More...
void initiateIterator (UserMetadata::Iterator &, int meta_type) const
 Get the iterator for user metadata within it. More...
unsigned int padIndex () const
 Index of the pad from which the frame is generated. More...
unsigned int batchId () const
 Location the frame in the batch. More...
int frameNum () const
 Frame number. More...
unsigned int sourceId () const
 Identify the source of the frame, e.g. More...
unsigned int sourceWidth () const
 Picture width of the source. More...
unsigned int sourceHeight () const
 Picture height of the source. More...
unsigned int pipelineWidth () const
 Picture width of the pipeline. More...
unsigned int pipelineHeight () const
 Picture height of the pipeline. More...
uint64_t bufferPTS () const
 Holds the presentation timestamp (PTS) of the frame. More...
uint64_t ntpTimestamp () const
 Holds the ntp timestamp. More...
void append (const DisplayMetadata &)
 Append display metadata to the frame. More...
void append (const UserMetadata &)
 Append user metadata to the frame. More...
void append (const ObjectMetadata &)
 Append object metadata to the frame. More...
 Destructor. More...
virtual operator bool ()
 operator to check if a metadata is void More...
Protected Attributes
void * data_
Friends
class BatchMetadata
Member Typedef Documentation
◆ Iterator [1/2]
◆ Iterator [2/2]
◆ FrameMetadata() [1/2]
deepstream::FrameMetadata::FrameMetadata ( void *  data = nullptr)
By default an empty frame metadata object is created.
◆ ~FrameMetadata() [1/2]
virtual deepstream::FrameMetadata::~FrameMetadata ( )
virtual
Destructor.
◆ FrameMetadata() [2/2]
◆ ~FrameMetadata() [2/2]
virtual
Destructor.
Member Function Documentation
◆ append() [1/6]
void deepstream::FrameMetadata::append ( const DisplayMetadata )
Referenced by deepstream::TensorMetaParser::handleData().
◆ append() [2/6]
◆ append() [3/6]
void deepstream::FrameMetadata::append ( const ObjectMetadata )
◆ append() [4/6]
◆ append() [5/6]
void deepstream::FrameMetadata::append ( const UserMetadata )
◆ append() [6/6]
◆ batchId() [1/2]
unsigned int deepstream::FrameMetadata::batchId ( ) const
◆ batchId() [2/2]
◆ bufferPTS() [1/2]
uint64_t deepstream::FrameMetadata::bufferPTS ( ) const
◆ bufferPTS() [2/2]
◆ frameNum() [1/2]
int deepstream::FrameMetadata::frameNum ( ) const
◆ frameNum() [2/2]
Frame number.
◆ initiateIterator() [1/6]
void deepstream::FrameMetadata::initiateIterator ( DisplayMetadata::Iterator ) const
◆ initiateIterator() [2/6]
◆ initiateIterator() [3/6]
void deepstream::FrameMetadata::initiateIterator ( ObjectMetadata::Iterator ) const
◆ initiateIterator() [4/6]
◆ initiateIterator() [5/6]
void deepstream::FrameMetadata::initiateIterator ( UserMetadata::Iterator ,
int  meta_type
) const
◆ initiateIterator() [6/6]
int  meta_type
) const
◆ iterate() [1/6]
unsigned int deepstream::FrameMetadata::iterate ( const std::function< void(const DisplayMetadata &)> &  func) const
◆ iterate() [2/6]
◆ iterate() [3/6]
unsigned int deepstream::FrameMetadata::iterate ( const std::function< void(const ObjectMetadata &)> &  func) const
Referenced by deepstream::ObjectCounter::consume(), and deepstream::TensorMetaParser::handleData().
◆ iterate() [4/6]
◆ iterate() [5/6]
unsigned int deepstream::FrameMetadata::iterate ( const std::function< void(const UserMetadata &)> &  func,
int  meta_type
) const
◆ iterate() [6/6]
int  meta_type
) const
◆ ntpTimestamp() [1/2]
uint64_t deepstream::FrameMetadata::ntpTimestamp ( ) const
◆ ntpTimestamp() [2/2]
◆ operator bool() [1/2]
virtual deepstream::Metadata::operator bool ( )
inlinevirtualinherited
Reimplemented in deepstream::UserMetadata, and deepstream::UserMetadata.
Definition at line 51 of file 9.0/service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 51 of file service-maker/includes/metadata.hpp.
◆ padIndex() [1/2]
unsigned int deepstream::FrameMetadata::padIndex ( ) const
◆ padIndex() [2/2]
Referenced by deepstream::ObjectCounter::consume(), deepstream::TensorMetaParser::handleData(), and deepstream::FPSCounter::handleData().
◆ pipelineHeight() [1/2]
unsigned int deepstream::FrameMetadata::pipelineHeight ( ) const
◆ pipelineHeight() [2/2]
◆ pipelineWidth() [1/2]
unsigned int deepstream::FrameMetadata::pipelineWidth ( ) const
◆ pipelineWidth() [2/2]
◆ sourceHeight() [1/2]
unsigned int deepstream::FrameMetadata::sourceHeight ( ) const
◆ sourceHeight() [2/2]
◆ sourceId() [1/2]
unsigned int deepstream::FrameMetadata::sourceId ( ) const
camera ID
◆ sourceId() [2/2]
camera ID
◆ sourceWidth() [1/2]
unsigned int deepstream::FrameMetadata::sourceWidth ( ) const
◆ sourceWidth() [2/2]
Friends And Related Function Documentation
◆ BatchMetadata
BatchMetadata
friend
Definition at line 496 of file service-maker/includes/metadata.hpp.
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
