8.0 Release
13 #ifndef __NVGSTDS_SINKS_H__
14 #define __NVGSTDS_SINKS_H__
gboolean multiple_payloads
NvDsEncOutputIOMode output_io_mode
void destroy_sink_bin(void)
gboolean qos_value_specified
NvDsSinkRenderConfig render_config
NvDsSinkMsgConvBrokerConfig msg_conv_broker_config
gchar * broker_config_file_path
gboolean create_sink_bin(guint num_sub_bins, NvDsSinkSubBinConfig *config_array, NvDsSinkBin *bin, guint index)
Initialize NvDsSinkBin.
gchar * debug_payload_dir
guint conv_frame_interval
@ NV_DS_ENCODER_OUTPUT_IO_MODE_DMABUF_IMPORT
GstElement * enc_caps_filter
gchar * proto_lib
Broker settings.
@ NV_DS_SINK_MSG_CONV_BROKER
gboolean conv_msg2p_new_api
NvDsSinkEncoderConfig encoder_config
NvDsContainerType container
gboolean conv_dummy_payload
gboolean create_demux_sink_bin(guint num_sub_bins, NvDsSinkSubBinConfig *config_array, NvDsSinkBin *bin, guint index)
gchar * config_file_path
MsgConv settings.
@ NV_DS_ENCODER_OUTPUT_IO_MODE_MMAP
void set_rtsp_udp_port_num(guint rtsp_port_num, guint udp_port_num)
