7.1 Release
deepstream_sources.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2018-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef __NVGSTDS_SOURCES_H__
14 #define __NVGSTDS_SOURCES_H__
15
16 #include <gst/gst.h>
17 #include "deepstream_dewarper.h"
18 #include <sys/time.h>
19
20 #ifdef __cplusplus
21 extern "C"
22 {
23 #endif
24
25 typedef enum
26 {
37
38 typedef struct
39 {
41  gboolean enable;
42  gboolean loop;
43  gboolean live_source;
44  gboolean Intra_decode;
45  gboolean low_latency_mode;
46  guint smart_record;
53  gchar *uri;
54  gchar *dir_path;
55  gchar *file_prefix;
56  gint latency;
63  guint num_sources;
64  guint gpu_id;
65  guint camera_id;
66  guint source_id;
72 #if defined(__aarch64__) && !defined(AARCH64_IS_SBSA)
73  /* copy-hw as VIC applicable only for Jetson */
74  guint nvvideoconvert_copy_hw;
75 #endif
88  gchar* alsa_device;
90  gchar* video_format;
92
94
95 typedef struct
96 {
97  GstElement *bin;
98  GstElement *src_elem;
99  GstElement *cap_filter;
100  GstElement *cap_filter1;
101  GstElement *depay;
102  GstElement *parser;
103  GstElement *enc_que;
104  GstElement *dec_que;
105  GstElement *decodebin;
106  GstElement *enc_filter;
107  GstElement *encbin_que;
108  GstElement *tee;
109  GstElement *tee_rtsp_pre_decode;
110  GstElement *tee_rtsp_post_decode;
111  GstElement *fakesink_queue;
112  GstElement *fakesink;
113  GstElement *nvvidconv;
114  GstElement *audio_converter;
115  GstElement *audio_resample;
116
117  gboolean do_record;
118  guint64 pre_event_rec;
119  GMutex bin_lock;
120  guint bin_id;
124  gboolean have_eos;
125  struct timeval last_buffer_time;
126  struct timeval last_reconnect_time;
129  gpointer bbox_meta;
131  gchar *location;
132  gchar *file;
133  gchar *direction;
134  gint latency;
136  gboolean got_key_frame;
137  gboolean eos_done;
138  gboolean reset_done;
139  gboolean live_source;
140  gboolean reconfiguring;
143  gulong probe_id;
146  guint source_id;
149  gpointer recordCtx;
150 } NvDsSrcBin;
151
153 {
154  GstElement *bin;
155  GstElement *streammux;
156  GstElement *nvmultiurisrcbin;
157  GThread *reset_thread;
159  guint num_bins;
160  guint num_fr_on;
161  gboolean live_source;
163 };
164
165
166 gboolean create_source_bin (NvDsSourceConfig *config, NvDsSrcBin *bin);
167 gboolean create_audio_source_bin (NvDsSourceConfig *config, NvDsSrcBin *bin);
168
182 gboolean
183 create_multi_source_bin (guint num_sub_bins, NvDsSourceConfig *configs,
184  NvDsSrcParentBin *bin);
185
199 gboolean
200 create_nvmultiurisrcbin_bin (guint num_sub_bins, NvDsSourceConfig *configs,
201  NvDsSrcParentBin *bin);
202
203 gboolean reset_source_pipeline (gpointer data);
204 gboolean set_source_to_playing (gpointer data);
205 gpointer reset_encodebin (gpointer data);
206 void destroy_smart_record_bin (gpointer data);
207 #ifdef __cplusplus
208 }
209 #endif
210
211 #endif
NV_DS_SOURCE_RTSP
@ NV_DS_SOURCE_RTSP
Definition: deepstream_sources.h:30
NvDsSourceConfig::num_decode_surfaces
guint num_decode_surfaces
Definition: deepstream_sources.h:68
NvDsSrcBin::location
gchar * location
Definition: deepstream_sources.h:131
NvDsSrcBin::rtsp_reconnect_attempts
gint rtsp_reconnect_attempts
Definition: deepstream_sources.h:122
NvDsSourceConfig::cuda_memory_type
guint cuda_memory_type
Definition: deepstream_sources.h:71
NvDsSrcParentBin::nvstreammux_eosmonitor_probe
gulong nvstreammux_eosmonitor_probe
Definition: deepstream_sources.h:162
NvDsSrcBin::live_source
Definition: deepstream_sources.h:139
gboolean create_multi_source_bin(guint num_sub_bins, NvDsSourceConfig *configs, NvDsSrcParentBin *bin)
Initialize NvDsSrcParentBin.
NvDsSrcBin::src_elem
GstElement * src_elem
Definition: deepstream_sources.h:98
NvDsSrcBin::eos_done
gboolean eos_done
Definition: deepstream_sources.h:137
NvDsSourceConfig::low_latency_mode
Definition: deepstream_sources.h:45
NvDsSourceConfig::camera_csi_sensor_id
gint camera_csi_sensor_id
Definition: deepstream_sources.h:51
NV_DS_SOURCE_IPC
@ NV_DS_SOURCE_IPC
Definition: deepstream_sources.h:35
NvDsSourceConfig::camera_v4l2_dev_node
gint camera_v4l2_dev_node
Definition: deepstream_sources.h:52
NvDsSrcBin::bin_id
guint bin_id
Definition: deepstream_sources.h:120
NvDsSourceConfig::smart_rec_def_duration
guint smart_rec_def_duration
Definition: deepstream_sources.h:59
NvDsSourceConfig::video_format
gchar * video_format
Video format to be applied at nvvideoconvert source pad.
Definition: deepstream_sources.h:90
NvDsSourceConfig::alsa_device
gchar * alsa_device
ALSA device, as defined in an asound configuration file.
Definition: deepstream_sources.h:88
NvDsSrcBin::src_buffer_probe
gulong src_buffer_probe
Definition: deepstream_sources.h:127
NvDsSrcParentBin::live_source
Definition: deepstream_sources.h:161
NvDsDewarperBin
Definition: deepstream_dewarper.h:23
gboolean create_audio_source_bin(NvDsSourceConfig *config, NvDsSrcBin *bin)
NvDsSrcParentBin::streammux
GstElement * streammux
Definition: deepstream_sources.h:155
NvDsSourceConfig::dewarper_config
NvDsDewarperConfig dewarper_config
Definition: deepstream_sources.h:76
gboolean reset_source_pipeline(gpointer data)
NvDsSrcBin::nvvidconv
GstElement * nvvidconv
Definition: deepstream_sources.h:113
NvDsSrcBin::audio_converter
GstElement * audio_converter
Definition: deepstream_sources.h:114
NvDsSrcBin::fakesink_queue
GstElement * fakesink_queue
Definition: deepstream_sources.h:111
NvDsSourceConfig::smart_rec_cache_size
guint smart_rec_cache_size
Definition: deepstream_sources.h:57
NvDsSourceConfig::type
NvDsSourceType type
Definition: deepstream_sources.h:40
NvDsSourceConfig::num_extra_surfaces
guint num_extra_surfaces
Definition: deepstream_sources.h:69
NvDsSrcBin::tee_rtsp_post_decode
GstElement * tee_rtsp_post_decode
Definition: deepstream_sources.h:110
NvDsSrcBin::dec_que
GstElement * dec_que
Definition: deepstream_sources.h:104
NvDsSourceConfig::extract_sei_type5_data
gboolean extract_sei_type5_data
Definition: deepstream_sources.h:78
NvDsSourceConfig::num_sources
guint num_sources
Definition: deepstream_sources.h:63
NvDsSrcBin::source_id
guint source_id
Definition: deepstream_sources.h:146
void destroy_smart_record_bin(gpointer data)
NvDsSrcBin::probe_id
gulong probe_id
Definition: deepstream_sources.h:143
Definition: deepstream_sources.h:112
NvDsSourceConfig::rtsp_reconnect_attempts
guint rtsp_reconnect_attempts
Definition: deepstream_sources.h:80
NvDsSourceConfig::dir_path
gchar * dir_path
Definition: deepstream_sources.h:54
NvDsSourceConfig::rtsp_reconnect_interval_sec
gint rtsp_reconnect_interval_sec
Definition: deepstream_sources.h:79
NvDsSrcBin::parent_bin
NvDsSrcParentBin * parent_bin
Definition: deepstream_sources.h:148
NvDsSrcBin::prev_accumulated_base
guint64 prev_accumulated_base
Definition: deepstream_sources.h:145
NvDsSourceConfig::latency
gint latency
Definition: deepstream_sources.h:56
NvDsSrcBin::bin
GstElement * bin
Definition: deepstream_sources.h:97
NV_DS_SOURCE_URI
@ NV_DS_SOURCE_URI
Definition: deepstream_sources.h:28
NV_DS_SOURCE_ALSA_SRC
@ NV_DS_SOURCE_ALSA_SRC
Definition: deepstream_sources.h:34
NvDsSourceConfig::smart_rec_container
guint smart_rec_container
Definition: deepstream_sources.h:58
NV_DS_SOURCE_URI_MULTIPLE
@ NV_DS_SOURCE_URI_MULTIPLE
Definition: deepstream_sources.h:29
NvDsSrcBin::enc_filter
GstElement * enc_filter
Definition: deepstream_sources.h:106
NvDsSourceConfig::live_source
Definition: deepstream_sources.h:43
NvDsSrcBin::depay
GstElement * depay
Definition: deepstream_sources.h:101
NvDsSourceConfig
Definition: deepstream_sources.h:38
NvDsSrcBin::bin_lock
GMutex bin_lock
Definition: deepstream_sources.h:119
NvDsSrcBin::reconfiguring
Definition: deepstream_sources.h:140
reset_encodebin
gpointer reset_encodebin(gpointer data)
NvDsSourceConfig::nvbuf_memory_type
guint nvbuf_memory_type
Definition: deepstream_sources.h:70
NvDsSrcParentBin::num_fr_on
guint num_fr_on
Definition: deepstream_sources.h:160
NvDsSrcBin::audio_resample
GstElement * audio_resample
Definition: deepstream_sources.h:115
NvDsSrcBin::tee
GstElement * tee
Definition: deepstream_sources.h:108
NvDsSrcBin::encbin_que
GstElement * encbin_que
Definition: deepstream_sources.h:107
NvDsSrcParentBin::reset_thread
GThread * reset_thread
Definition: deepstream_sources.h:157
NvDsSourceConfig::select_rtp_protocol
guint select_rtp_protocol
Definition: deepstream_sources.h:67
NvDsSrcBin::cap_filter1
GstElement * cap_filter1
Definition: deepstream_sources.h:100
NvDsSrcBin::rtspsrc_monitor_probe
gulong rtspsrc_monitor_probe
Definition: deepstream_sources.h:128
NvDsSrcBin::bbox_meta
gpointer bbox_meta
Definition: deepstream_sources.h:129
NvDsSrcBin::inbuf
GstBuffer * inbuf
Definition: deepstream_sources.h:130
NvDsSourceConfig::source_height
gint source_height
Definition: deepstream_sources.h:48
NvDsSourceConfig::smart_rec_duration
guint smart_rec_duration
Definition: deepstream_sources.h:60
NvDsSrcBin
Definition: deepstream_sources.h:95
NvDsSrcParentBin::nvmultiurisrcbin
GstElement * nvmultiurisrcbin
Definition: deepstream_sources.h:156
NvDsSourceType
NvDsSourceType
Definition: deepstream_sources.h:25
NV_DS_SOURCE_CAMERA_V4L2
@ NV_DS_SOURCE_CAMERA_V4L2
Definition: deepstream_sources.h:27
NvDsSrcBin::enc_que
GstElement * enc_que
Definition: deepstream_sources.h:103
NvDsSrcBin::do_record
gboolean do_record
Definition: deepstream_sources.h:117
NvDsSrcBin::parser
GstElement * parser
Definition: deepstream_sources.h:102
NvDsSrcBin::tee_rtsp_pre_decode
GstElement * tee_rtsp_pre_decode
Definition: deepstream_sources.h:109
NvDsSrcParentBin::num_bins
guint num_bins
Definition: deepstream_sources.h:159
create_source_bin
gboolean create_source_bin(NvDsSourceConfig *config, NvDsSrcBin *bin)
NvDsSourceConfig::smart_rec_start_time
guint smart_rec_start_time
Definition: deepstream_sources.h:61
NvDsSrcBin::file
gchar * file
Definition: deepstream_sources.h:132
NvDsSourceConfig::source_width
gint source_width
Definition: deepstream_sources.h:47
NvDsSourceConfig::loop
gboolean loop
Definition: deepstream_sources.h:42
gboolean create_nvmultiurisrcbin_bin(guint num_sub_bins, NvDsSourceConfig *configs, NvDsSrcParentBin *bin)
NvDsSourceConfig::enable
gboolean enable
Definition: deepstream_sources.h:41
NvDsSrcBin::accumulated_base
guint64 accumulated_base
Definition: deepstream_sources.h:144
NvDsSourceConfig::smart_rec_interval
guint smart_rec_interval
Definition: deepstream_sources.h:62
NvDsSrcParentBin::sub_bins
NvDsSrcBin sub_bins[MAX_SOURCE_BINS]
Definition: deepstream_sources.h:158
NvDsSrcBin::num_rtsp_reconnects
gint num_rtsp_reconnects
Definition: deepstream_sources.h:123
NvDsSrcBin::direction
gchar * direction
Definition: deepstream_sources.h:133
NvDsSrcBin::recordCtx
gpointer recordCtx
Definition: deepstream_sources.h:149
NvDsSrcParentBin
Definition: deepstream_sources.h:152
NvDsSourceConfig::rtsp_reconnect_attempt_exceeded
gboolean rtsp_reconnect_attempt_exceeded
Definition: deepstream_sources.h:81
GstBuffer
struct _GstBuffer GstBuffer
Definition: idatatype.h:19
NV_DS_SOURCE_AUDIO_WAV
@ NV_DS_SOURCE_AUDIO_WAV
Definition: deepstream_sources.h:32
NvDsSourceConfig::camera_id
guint camera_id
Definition: deepstream_sources.h:65
NvDsSourceConfig::smart_record
guint smart_record
Definition: deepstream_sources.h:46
NvDsSrcBin::async_state_watch_running
gboolean async_state_watch_running
Definition: deepstream_sources.h:141
NvDsSourceConfig::file_prefix
gchar * file_prefix
Definition: deepstream_sources.h:55
NvDsSrcBin::have_eos
gboolean have_eos
Definition: deepstream_sources.h:124
NvDsSourceConfig::gpu_id
guint gpu_id
Definition: deepstream_sources.h:64
NvDsSourceConfig::source_fps_d
gint source_fps_d
Definition: deepstream_sources.h:50
NvDsSourceConfig::uri
gchar * uri
Definition: deepstream_sources.h:53
MAX_SOURCE_BINS
#define MAX_SOURCE_BINS
Definition: deepstream_config.h:84
NvDsSrcBin::reset_done
gboolean reset_done
Definition: deepstream_sources.h:138
NvDsSourceConfig::Intra_decode
Definition: deepstream_sources.h:44
NvDsSourceConfig::source_id
guint source_id
Definition: deepstream_sources.h:66
NvDsSourceConfig::input_audio_rate
guint input_audio_rate
Desired input audio rate to nvinferaudio from PGIE config; This config shall be copied over from NvDs...
Definition: deepstream_sources.h:86
NvDsSrcParentBin::bin
GstElement * bin
Definition: deepstream_sources.h:154
NvDsDewarperConfig
Definition: deepstream_dewarper.h:35
NvDsSourceConfig::udp_buffer_size
guint udp_buffer_size
Definition: deepstream_sources.h:82
NV_DS_SOURCE_AUDIO_URI
@ NV_DS_SOURCE_AUDIO_URI
Definition: deepstream_sources.h:33
NvDsSourceConfig::drop_frame_interval
guint drop_frame_interval
Definition: deepstream_sources.h:77
NvDsSrcBin::got_key_frame
Definition: deepstream_sources.h:136
NvDsSrcBin::pre_event_rec
Definition: deepstream_sources.h:118
Definition: deepstream_sources.h:99
NvDsSrcBin::latency
gint latency
Definition: deepstream_sources.h:134
NvDsSrcBin::decodebin
GstElement * decodebin
Definition: deepstream_sources.h:105
NvDsSrcBin::config
NvDsSourceConfig * config
Definition: deepstream_sources.h:147
NvDsSrcBin::rtsp_reconnect_interval_sec
Definition: deepstream_sources.h:121
NvDsSrcBin::udp_buffer_size
Definition: deepstream_sources.h:135
NvDsSourceConfig::source_fps_n
gint source_fps_n
Definition: deepstream_sources.h:49
gboolean set_source_to_playing(gpointer data)
NV_DS_SOURCE_CAMERA_CSI
@ NV_DS_SOURCE_CAMERA_CSI
Definition: deepstream_sources.h:31
NvDsSrcBin::dewarper_bin
NvDsDewarperBin dewarper_bin
Definition: deepstream_sources.h:142
