8.0 Release
- p -
PAD_MIME_TYPE_AUDIO :
nvstreammux_pads.h
PAD_MIME_TYPE_INVALID :
nvstreammux_pads.h
PAD_MIME_TYPE_VIDEO :
nvstreammux_pads.h
PROCESS_MODE :
includes/nvds_rest_server.h
libs/nvds_rest_server/nvds_rest_server.h
PROCESS_MODE_UPDATE_FAIL :
PROCESS_MODE_UPDATE_SUCCESS :
PROGRESSIVE :
gstnvdsudpcommon.h
PROJECTED :
nvds_tracker_meta.h
PROP_0 :
gstnvinfer.h
gstnvinferserver.h
gst-nvmultiurisrcbin/gstdsnvurisrcbin.h
gst-nvurisrcbin/gstdsnvurisrcbin.h
PROP_ALIGN_FIRST_BUFFER :
gstdsnvmultiurisrcbin.h
PROP_ASYNC_PROCESS :
PROP_ATTACH_SYS_TIME_STAMP :
PROP_BATCH_SIZE :
gstnvinfer.h
gstnvinferserver.h
PROP_BATCHED_PUSH_TIMEOUT :
PROP_BUFFER_MODE :
PROP_BUFFER_POOL_SIZE :
PROP_CACHE_BUFFERS :
PROP_CACHE_BUFFERS_TIMEOUT :
PROP_CLIP_OBJECT_OUTSIDE_ROI :
gstnvinfer.h
PROP_COMPUTE_HW :
PROP_CONFIG_FILE_PATH :
gstnvinfer.h
gstnvinferserver.h
PROP_CROP_OBJECTS_TO_ROI_BOUNDARY :
gstnvinfer.h
PROP_CUDADEC_MEM_TYPE :
PROP_DEC_SKIP_FRAMES :
PROP_DISABLE_AUDIO :
PROP_DISABLE_PASSTHROUGH :
PROP_DROP_FRAME_INTERVAL :
PROP_DROP_ON_LATENCY :
PROP_ENABLE_PADDING :
PROP_EXTRACT_SEI_TYPE5_DATA :
PROP_EXTRACT_SEI_TYPE5_DATA_MUX :
PROP_EXTRACT_SIM_TIME :
PROP_FILE_LOOP :
PROP_FILTER_OUT_CLASS_IDS :
gstnvinfer.h
PROP_FRAME_DURATION :
PROP_FRAME_NUM_RESET_ON_EOS :
PROP_FRAME_NUM_RESET_ON_STREAM_RESET :
PROP_GPU_DEVICE_ID :
gstnvinfer.h
PROP_HEIGHT :
PROP_INFER_ON_GIE_ID :
gstnvinferserver.h
PROP_INPUT_TENSOR_META :
gstnvinfer.h
gstnvinferserver.h
PROP_INTERPOLATION_METHOD :
PROP_INTERVAL :
gstnvinfer.h
gstnvinferserver.h
PROP_IPC_BUFFER_TIMESTAMP_COPY :
PROP_IPC_CONNECTION_ATTEMPTS :
PROP_IPC_CONNECTION_INTERVAL :
PROP_IPC_SOCKET_PATH :
PROP_LAST :
gstnvinfer.h
gstnvinferserver.h
PROP_LATENCY :
PROP_LEAKY :
PROP_LIVE_SOURCE :
PROP_LOW_LATENCY_MODE :
PROP_MAX_LATNECY :
PROP_MAX_SIZE_BUFFERS :
PROP_MODEL_ENGINEFILE :
gstnvinfer.h
PROP_NO_PIPELINE_EOS :
PROP_NUM_EXTRA_SURF :
PROP_NUM_SURFACES_PER_FRAME :
PROP_NVBUF_MEMORY_TYPE :
PROP_OPERATE_ON_CLASS_IDS :
gstnvinferserver.h
gstnvinfer.h
PROP_OPERATE_ON_GIE_ID :
gstnvinfer.h
PROP_OUTPUT_CALLBACK :
gstnvinfer.h
gstnvinferserver.h
PROP_OUTPUT_CALLBACK_USERDATA :
gstnvinfer.h
gstnvinferserver.h
PROP_OUTPUT_INSTANCE_MASK :
gstnvinfer.h
PROP_OUTPUT_TENSOR_META :
gstnvinfer.h
PROP_OUTPUT_WRITE_TO_FILE :
gstnvinfer.h
PROP_PROCESS_MODE :
gstnvinfer.h
gstnvinferserver.h
PROP_RTP_PROTOCOL :
PROP_RTSP_INIT_RECONNECT_INTERVAL :
PROP_RTSP_RECONNECT_ATTEMPTS :
PROP_RTSP_RECONNECT_INTERVAL :
PROP_SEI_UUID :
PROP_SMART_RECORD :
PROP_SMART_RECORD_CACHE :
PROP_SMART_RECORD_CONTAINER :
PROP_SMART_RECORD_DEFAULT_DURATION :
PROP_SMART_RECORD_DIR_PATH :
PROP_SMART_RECORD_FILE_PREFIX :
PROP_SMART_RECORD_MODE :
PROP_SMART_RECORD_STATUS :
PROP_SMART_RECORD_VIDEO_CACHE :
PROP_SORT_BATCH_BUFFERS :
PROP_SOURCE_ID :
PROP_SOURCE_TYPE :
PROP_SYNC_INPUTS :
PROP_SYNC_INPUTS_NTP :
PROP_UDP_BUFFER_SIZE :
PROP_UNIQUE_ID :
gstnvinfer.h
gstnvinferserver.h
PROP_URI :
PROP_WIDTH :
Privacy Policy
Manage My Privacy
Do Not Sell or Share My Data
Terms of Service
Accessibility
Corporate Policies
Product Security
Contact
© 2025 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
NVIDIA Confidential | Subject to Change | For test and development only.
Tue Sep 9 2025 11:37:08 | PR-09318-R32
