Defines the API for DBScan-based object clustering.
Data Structures | |
| struct | NvDsInferDBScanClusteringParams |
| Holds object clustering parameters required by DBSCAN. More... | |
Typedefs | |
| typedef struct NvDsInferDBScan * | NvDsInferDBScanHandle |
| Holds an opaque DBScan clustering context handle. More... | |
Functions | |
| NvDsInferDBScanHandle | NvDsInferDBScanCreate () |
| Creates a new DBScan object clustering context. More... | |
| void | NvDsInferDBScanDestroy (NvDsInferDBScanHandle handle) |
| Destroys a DBScan object clustering context. More... | |
| void | NvDsInferDBScanCluster (NvDsInferDBScanHandle handle, NvDsInferDBScanClusteringParams *params, NvDsInferObjectDetectionInfo *objects, size_t *numObjects) |
| Clusters an array of objects in place using specified clustering parameters. More... | |
| void | NvDsInferDBScanClusterHybrid (NvDsInferDBScanHandle handle, NvDsInferDBScanClusteringParams *params, NvDsInferObjectDetectionInfo *objects, size_t *numObjects) |
| typedef struct NvDsInferDBScan* NvDsInferDBScanHandle |
Definition at line 46 of file nvdsinfer_dbscan.h.
| void NvDsInferDBScanCluster | ( | NvDsInferDBScanHandle | handle, |
| NvDsInferDBScanClusteringParams * | params, | ||
| NvDsInferObjectDetectionInfo * | objects, | ||
| size_t * | numObjects | ||
| [in] | handle | A handle to the context be used for clustering. |
| [in] | params | A pointer to a clustering parameter structure. |
| [in,out] | objects | A pointer to an array of objects to be clustered. The function places the clustered objects in the same array. |
| [in,out] | numObjects | A pointer to the number of valid objects in the objects array. The function sets this value after clustering. |
Referenced by deepstream::TensorMetaParser::handleData().
| void NvDsInferDBScanClusterHybrid | ( | NvDsInferDBScanHandle | handle, |
The outputs are partially only clustered i.e to merge close neighbors of the same cluster together only and the mean normalization of all the proposals in a cluster is not performed. The outputs from this stage are later fed into another clustering algorithm like NMS to obtain the final results.
| NvDsInferDBScanHandle NvDsInferDBScanCreate | ( | ) |
Referenced by deepstream::TensorMetaParser::TensorMetaParser().
| void NvDsInferDBScanDestroy | ( | NvDsInferDBScanHandle | handle | ) |
| [in] | handle | The handle to the context to be destroyed. |
Referenced by deepstream::TensorMetaParser::~TensorMetaParser().
