Holds object clustering parameters required by DBSCAN.
Definition at line 49 of file nvdsinfer_dbscan.h.
Data Fields | |
| float | eps |
| uint32_t | minBoxes |
| int | enableATHRFilter |
| Holds a Boolean; true enables the area-to-hit ratio (ATHR) filter. More... | |
| float | thresholdATHR |
| Holds the area-to-hit ratio threshold. More... | |
| float | minScore |
| Holds the sum of neighborhood confidence thresholds. More... | |
| int NvDsInferDBScanClusteringParams::enableATHRFilter |
The ATHR is calculated as: ATHR = sqrt(clusterArea) / nObjectsInCluster.
Definition at line 55 of file nvdsinfer_dbscan.h.
Referenced by deepstream::TensorMetaParser::handleData().
| float NvDsInferDBScanClusteringParams::eps |
Definition at line 51 of file nvdsinfer_dbscan.h.
| uint32_t NvDsInferDBScanClusteringParams::minBoxes |
Definition at line 52 of file nvdsinfer_dbscan.h.
| float NvDsInferDBScanClusteringParams::minScore |
Definition at line 59 of file nvdsinfer_dbscan.h.
| float NvDsInferDBScanClusteringParams::thresholdATHR |
Definition at line 57 of file nvdsinfer_dbscan.h.
