Typedefs | |
| typedef void(* | NvDsInferConvertFcn) (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Function pointer type to which any of the NvDsInferConvert functions can be assigned. More... | |
| typedef void(* | NvDsInferConvertFcnFloat) (float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
Functions | |
| void | NvDsInferConvert_C3ToP3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| This is a header file for pre-processing cuda kernels with normalization and mean subtraction required by nvdsinfer. More... | |
| void | NvDsInferConvert_C3ToL3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an input packed 3 channel buffer of width x height resolution into an linear 3-channel float buffer of width x height resolution. More... | |
| void | NvDsInferConvert_C4ToP3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution. More... | |
| void | NvDsInferConvert_C4ToL3Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| void | NvDsInferConvert_C3ToP3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution with plane order reversed. More... | |
| void | NvDsInferConvert_C3ToL3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an input packed 3 channel buffer of width x height resolution into an linear 3-channel float buffer of width x height resolution with plane order reversed. More... | |
| void | NvDsInferConvert_C4ToP3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an input packed 4 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution with plane order reversed. More... | |
| void | NvDsInferConvert_C4ToL3RFloat (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an input packed 4 channel buffer of width x height resolution into an linear 3-channel float buffer of width x height resolution with plane order reversed. More... | |
| void | NvDsInferConvert_C1ToP1Float (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| Converts an 1 channel UINT8 input of width x height resolution into an 1 channel float buffer of width x height resolution. More... | |
| void | NvDsInferConvert_FtFTensor (float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
| typedef void(* NvDsInferConvertFcn) (float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
Definition at line 313 of file nvdsinfer_conversion.h.
| typedef void(* NvDsInferConvertFcnFloat) (float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream) |
Definition at line 323 of file nvdsinfer_conversion.h.
| void NvDsInferConvert_C1ToP1Float | ( | float * | outBuffer, |
| unsigned char * | inBuffer, | ||
| unsigned int | width, | ||
| unsigned int | height, | ||
| unsigned int | pitch, | ||
| float | scaleFactor, | ||
| float * | meanDataBuffer, | ||
| cudaStream_t | stream | ||
The input buffer can have a pitch > width . The cuda kernel supports normalization and mean image subtraction.
| outBuffer | Cuda device buffer for float output. Should be at least (width * height * sizeof(float)) bytes. |
| inBuffer | Cuda device buffer for UINT8 input. Should be at least (pitch * height) bytes. |
| width | Width of the buffers in pixels. |
| height | Height of the buffers in pixels. |
| pitch | Pitch of the input buffer in bytes. |
| scaleFactor | Normalization factor. |
| meanDataBuffer | Mean Image Data buffer. Should be at least (width * height * sizeof(float)) bytes. |
| stream | Cuda stream identifier. |
| void NvDsInferConvert_C3ToL3Float | ( | float * | outBuffer, |
The input buffer can have a pitch > (width * 3). The cuda kernel supports normalization and mean image subtraction.
This kernel can be used for RGB -> RGB and BGR -> BGR conversions.
| outBuffer | Cuda device buffer for planar float output. Should be at least (width * height * 3 * sizeof(float)) bytes. |
| inBuffer | Cuda device buffer for packed input. Should be at least (pitch * height) bytes. |
| meanDataBuffer | Mean Image Data buffer. Should be at least (width * height * 3 * sizeof(float)) bytes. |
| void NvDsInferConvert_C3ToL3RFloat | ( | float * | outBuffer, |
This kernel can be used for BGR -> RGB and RGB -> BGR conversions.
| void NvDsInferConvert_C3ToP3Float | ( | float * | outBuffer, |
Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float buffer of width x height resolution. The input buffer can have a pitch > (width * 3). The cuda kernel supports normalization and mean image subtraction.
| void NvDsInferConvert_C3ToP3RFloat | ( | float * | outBuffer, |
| void NvDsInferConvert_C4ToL3Float | ( | float * | outBuffer, |
This kernel can be used for RGBA -> RGB and BGRx -> BGR conversions.
| outBuffer | Cuda device buffer for linear float output. Should be at least (width * height * 3 * sizeof(float)) bytes. |
| void NvDsInferConvert_C4ToL3RFloat | ( | float * | outBuffer, |
This kernel can be used for BGRx -> RGB and RGBA -> BGR conversions.
| void NvDsInferConvert_C4ToP3Float | ( | float * | outBuffer, |
| void NvDsInferConvert_C4ToP3RFloat | ( | float * | outBuffer, |
| void NvDsInferConvert_FtFTensor | ( | float * | outBuffer, |
| float * | inBuffer, | ||
