8.0 Release
17 #ifndef __NVDSINFER_CONVERSION_H__
18 #define __NVDSINFER_CONVERSION_H__
43 unsigned char *inBuffer,
48 float *meanDataBuffer,
74 unsigned char *inBuffer,
79 float *meanDataBuffer,
105 unsigned char *inBuffer,
110 float *meanDataBuffer,
136 unsigned char *inBuffer,
141 float *meanDataBuffer,
167 unsigned char *inBuffer,
172 float *meanDataBuffer,
198 unsigned char *inBuffer,
203 float *meanDataBuffer,
229 unsigned char *inBuffer,
234 float *meanDataBuffer,
260 unsigned char *inBuffer,
265 float *meanDataBuffer,
289 unsigned char *inBuffer,
294 float *meanDataBuffer,
305 float *meanDataBuffer,
315 unsigned char *inBuffer,
320 float *meanDataBuffer,
330 float *meanDataBuffer,
void NvDsInferConvert_C3ToL3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 3 channel buffer of width x height resolution into an linear 3-channel float...
void NvDsInferConvert_C4ToL3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 4 channel buffer of width x height resolution into an linear 3-channel float...
void NvDsInferConvert_C1ToP1Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an 1 channel UINT8 input of width x height resolution into an 1 channel float buffer of widt...
void NvDsInferConvert_C3ToP3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void(* NvDsInferConvertFcn)(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Function pointer type to which any of the NvDsInferConvert functions can be assigned.
void NvDsInferConvert_C4ToL3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsInferConvert_C4ToP3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 4 channel buffer of width x height resolution into an planar 3-channel float...
void NvDsInferConvert_FtFTensor(float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsInferConvert_C4ToP3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float...
void NvDsInferConvert_C3ToP3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void(* NvDsInferConvertFcnFloat)(float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsInferConvert_C3ToL3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
