8.0 Release
29 #ifndef __NVDSPREPROCESS_CONVERSION_H__
30 #define __NVDSPREPROCESS_CONVERSION_H__
32 #include <cuda_fp16.h>
57 unsigned char *inBuffer,
62 float *meanDataBuffer,
88 unsigned char *inBuffer,
93 float *meanDataBuffer,
119 unsigned char *inBuffer,
124 float *meanDataBuffer,
150 unsigned char *inBuffer,
155 float *meanDataBuffer,
181 unsigned char *inBuffer,
186 float *meanDataBuffer,
212 unsigned char *inBuffer,
217 float *meanDataBuffer,
243 unsigned char *inBuffer,
248 float *meanDataBuffer,
274 unsigned char *inBuffer,
279 float *meanDataBuffer,
305 unsigned char *inBuffer,
310 float *meanDataBuffer,
336 unsigned char *inBuffer,
341 float *meanDataBuffer,
365 unsigned char *inBuffer,
370 float *meanDataBuffer,
381 float *meanDataBuffer,
390 unsigned char *inBuffer,
395 float *meanDataBuffer,
404 unsigned char *inBuffer,
409 float *meanDataBuffer,
void NvDsPreProcessConvert_C4ToP3Half(half *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel half ...
void NvDsPreProcessConvert_C3ToL3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 3 channel buffer of width x height resolution into an linear 3-channel float...
void(* NvDsPreProcessConvertFcn)(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Function pointer type to which any of the NvDsPreProcessConvert functions can be assigned.
void NvDsPreProcessConvert_C4ToL3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 4 channel buffer of width x height resolution into an linear 3-channel float...
void NvDsPreProcessConvert_C4ToP3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 3 channel buffer of width x height resolution into an planar 3-channel float...
void NvDsPreProcessConvert_C4ToP3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an input packed 4 channel buffer of width x height resolution into an planar 3-channel float...
void NvDsPreProcessConvert_FtFTensor(float *outBuffer, float *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C4ToL3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C3ToL3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C3ToP3Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C3ToP3RFloat(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C1ToP1Float(float *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
Converts an 1 channel UINT8 input of width x height resolution into an 1 channel float buffer of widt...
void(* NvDsPreProcessConvertFcnHalf)(half *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
void NvDsPreProcessConvert_C4ToP3RHalf(half *outBuffer, unsigned char *inBuffer, unsigned int width, unsigned int height, unsigned int pitch, float scaleFactor, float *meanDataBuffer, cudaStream_t stream)
