Convinient macros for custom plugin creation
Definition in file plugin.h.
Macros | |
: name of the plugin | |
DS_CUSTOM_PLUGIN_DEFINE: @description: description of the plugin
Utility macro to create a custom plugin | |
| #define | DS_CUSTOM_PLUGIN_DEFINE(name, description, version, license) |
| #define | DS_CUSTOM_FACTORY_DEFINE_PARAMS_BEGIN(param_spec) static const char* param_spec = "[" |
| Parameter Specification. More... | |
| #define | DS_CUSTOM_FACTORY_DEFINE_PARAM(name, type, brief, description, default_value) "{name: "#name", type: "#type", brief: "#brief", description: "#description", default_value: "#default_value"}," |
| #define | DS_CUSTOM_FACTORY_DEFINE_PARAMS_END "]"; |
| #define | DS_CUSTOM_FACTORY_DEFINE_FULL(factory_name, long_name, klass, description, author, signals, param_spec, object_class, ...) |
| DS_CUSTOM_FACTORY_DEFINE_FULL: @factory_name: name of the factory @long_name: long name of the factory @klass: category string @description: detailed information. More... | |
| #define | DS_CUSTOM_FACTORY_DEFINE_WITH_PARAMS(factory_name, long_name, klass, description, author, signals, param_spec, object_class, implementation) DS_CUSTOM_FACTORY_DEFINE_FULL(factory_name, long_name, klass, description, author, signals, param_spec, object_class, new implementation) |
| convinient macro for DS_CUSTOM_FACTORY_DEFINE_FULL More... | |
| #define | DS_CUSTOM_FACTORY_DEFINE_WITH_SIGNALS(factory_name, long_name, klass, description, author, signals, object_class, implementation) |
| #define | DS_CUSTOM_FACTORY_DEFINE(factory_name, long_name, klass, description, author, object_class, implementation) |
| #define DS_CUSTOM_FACTORY_DEFINE | ( | factory_name, | |
| long_name, | |||
| klass, | |||
| description, | |||
| author, | |||
| object_class, | |||
| implementation | |||
| #define DS_CUSTOM_FACTORY_DEFINE_FULL | ( | factory_name, | |
| long_name, | |||
| klass, | |||
| description, | |||
| author, | |||
| signals, | |||
| param_spec, | |||
| object_class, | |||
Utility macro to create a custom factory
| #define DS_CUSTOM_FACTORY_DEFINE_PARAM | ( | name, | |
| type, | |||
| brief, | |||
| description, | |||
| default_value | |||
| ) | "{name: "#name", type: "#type", brief: "#brief", description: "#description", default_value: "#default_value"}," |
| #define DS_CUSTOM_FACTORY_DEFINE_PARAMS_BEGIN | ( | param_spec | ) | static const char* param_spec = "[" |
| #define DS_CUSTOM_FACTORY_DEFINE_WITH_PARAMS | ( | factory_name, | |
| long_name, | |||
| klass, | |||
| description, | |||
| author, | |||
| signals, | |||
| param_spec, | |||
| object_class, | |||
| ) | DS_CUSTOM_FACTORY_DEFINE_FULL(factory_name, long_name, klass, description, author, signals, param_spec, object_class, new implementation) |
| #define DS_CUSTOM_FACTORY_DEFINE_WITH_SIGNALS | ( | factory_name, | |
| long_name, | |||
| klass, | |||
| description, | |||
| author, | |||
| signals, | |||
| object_class, | |||
| #define DS_CUSTOM_PLUGIN_DEFINE | ( | name, | |
| description, | |||
| version, | |||
| license | |||
