sources/libs/nvdsinferserver/infer_trtis_utils.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2020-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
19 #ifndef __NVDSINFER_TRTIS_UTILS_H__
20 #define __NVDSINFER_TRTIS_UTILS_H__
21
22 #include <string>
23 #include <thread>
24 #include <vector>
25 #include <memory>
26 #include <functional>
27
28 #include "infer_common.h"
29 #include "infer_datatypes.h"
30 #include "infer_utils.h"
31
32 #include "model_config.pb.h"
33 #include "tritonserver.h"
34
40 #define CHECK_TRTIS_ERR_W_ACTION(trtisExpr, action, fmt, ...) \
41  do { \
42  UniqTritonT<TRITONSERVER_Error> errPtr( \
43  (trtisExpr), TRITONSERVER_ErrorDelete); \
44  if (errPtr) { \
45  InferError( \
46  "Triton: " fmt ", triton_err_str:%s, err_msg:%s", \
47  ##__VA_ARGS__, TRITONSERVER_ErrorCodeString(errPtr.get()), \
48  TRITONSERVER_ErrorMessage(errPtr.get())); \
49  action; \
50  } \
51  } while (0)
52
57 #define RETURN_TRTIS_ERROR(trtisExpr, fmt, ...) \
58  CHECK_TRTIS_ERR_W_ACTION(trtisExpr, return NVDSINFER_TRITON_ERROR, fmt, ##__VA_ARGS__)
59
64 #define CONTINUE_TRTIS_ERROR(trtisExpr, fmt, ...) \
65  CHECK_TRTIS_ERR_W_ACTION(trtisExpr, , fmt, ##__VA_ARGS__)
66
67 namespace ni = inference;
68
69 namespace nvdsinferserver {
70
77
84
92
99 InferTensorOrder TensorOrderFromTritonPb(ni::ModelInput::Format order);
100
108
117
129 template <typename VecDims>
130 InferDims
131 DimsFromTriton(const VecDims& shape)
132 {
133  InferDims ret{0};
134  assert((int)shape.size() <= NVDSINFER_MAX_DIMS);
135  uint32_t i = 0;
136  for (const auto &v : shape) {
137  if (v < 0) {
138  ret.d[i] = -1;
139  } else {
140  ret.d[i] = v;
141  }
142  ++i;
143  }
144  ret.numDims = i;
145  if (!hasWildcard(ret)) {
146  normalizeDims(ret);
147  }
148  return ret;
149 }
150
155 const char* TritonControlModeToStr(int32_t mode);
156
157 } // namespace nvdsinferserver
158
159 #endif /* __NVDSINFER_TRTIS_UTILS_H__ */
nvdsinferserver
Definition: sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h:64
nvdsinferserver::MemTypeFromTriton
InferMemType MemTypeFromTriton(TRITONSERVER_MemoryType type)
Maps the TRITONSERVER_MemoryType to the InferMemType.
nvdsinferserver::InferDataType
InferDataType
Datatype of the tensor buffer.
Definition: sources/includes/nvdsinferserver/infer_datatypes.h:83
enum TRITONSERVER_memorytype_enum TRITONSERVER_MemoryType
TRITONSERVER_MemoryType.
nvdsinferserver::DataTypeFromTritonPb
InferDataType DataTypeFromTritonPb(ni::DataType type)
Maps the data type from Triton model configuration proto definition to InferDataType.
ds3d::DataType
DataType
Definition: sources/includes/ds3d/common/idatatype.h:77
nvdsinferserver::InferTensorOrder
InferTensorOrder
The type of tensor order.
Definition: sources/includes/nvdsinferserver/infer_datatypes.h:41
nvdsinferserver::DataTypeToTriton
TRITONSERVER_DataType DataTypeToTriton(InferDataType type)
Maps the InferDataType to TRITONSERVER_DataType.
nvdsinferserver::normalizeDims
void normalizeDims(InferDims &dims)
InferDataType DataTypeFromTriton(TRITONSERVER_DataType type)
Maps the TRITONSERVER_DataType to the InferDataType.
infer_common.h
nvdsinferserver::DimsFromTriton
InferDims DimsFromTriton(const VecDims &shape)
Converts the input shape vector from Triton to InferDims type.
Definition: sources/libs/nvdsinferserver/infer_trtis_utils.h:131
nvdsinfer::hasWildcard
bool hasWildcard(const nvinfer1::Dims &dims)
NVDSINFER_MAX_DIMS
#define NVDSINFER_MAX_DIMS
Definition: sources/includes/nvdsinfer.h:39
enum TRITONSERVER_datatype_enum TRITONSERVER_DataType
nvdsinferserver::InferMemType
InferMemType
The memory types of inference buffers.
Definition: sources/includes/nvdsinferserver/infer_datatypes.h:56
nvdsinferserver::InferDims
Holds the information about the dimensions of a neural network layer.
Definition: sources/includes/nvdsinferserver/infer_datatypes.h:146
infer_utils.h
nvdsinferserver::TensorOrderFromTritonPb
Maps the tensor order from Triton model configuration proto definition to the InferTensorOrder type.
nvdsinferserver::TensorOrderFromTritonMeta
InferTensorOrder TensorOrderFromTritonMeta(const std::string &format)
Maps the tensor order from Triton metadata string to the InferTensorOrder type.
nvdsinferserver::MemTypeToTriton
TRITONSERVER_MemoryType MemTypeToTriton(InferMemType type)
Maps the InferMemType to the TRITONSERVER_MemoryType.
nvdsinferserver::TritonControlModeToStr
const char * TritonControlModeToStr(int32_t mode)
Returns a string describing the TRITONSERVER_ModelControlMode: none, explicit or poll.
ds3d::v2xinfer::format
static std::string format(const char *fmt,...)
Definition: sources/libs/ds3d/inference_custom_lib/ds3d_v2x_infer_custom_preprocess/tensor.hpp:26
