7.1 Release
NvDsFrameLatencyInfo Struct Reference
Holds information about the latency of a given frame.
Definition at line 83 of file nvds_latency_meta.h.
Data Fields
guint source_id
 Holds the source ID of the component, e.g. More...
guint frame_num
 Holds the current frame number for which latency is measured. More...
gdouble comp_in_timestamp
 Holds the system timestamp of the buffer when it arrives at the input of the first component in the pipeline. More...
gdouble latency
 Holds the latency of the frame in milliseconds. More...
Field Documentation
◆ comp_in_timestamp
gdouble NvDsFrameLatencyInfo::comp_in_timestamp
By default, the decoder is considered to be the first component in the pipeline.
Definition at line 92 of file nvds_latency_meta.h.
◆ frame_num
guint NvDsFrameLatencyInfo::frame_num
Definition at line 88 of file nvds_latency_meta.h.
◆ latency
gdouble NvDsFrameLatencyInfo::latency
Definition at line 94 of file nvds_latency_meta.h.
◆ source_id
guint NvDsFrameLatencyInfo::source_id
the camera ID.
Definition at line 86 of file nvds_latency_meta.h.
