27 #ifndef _NVDSMETA_LATENCY_H_
28 #define _NVDSMETA_LATENCY_H_
34 #define MAX_COMPONENT_LEN 64
109 gchar *element_name);
165 gchar *element_name, guint frame_id);
180 #define nvds_enable_latency_measurement (nvds_get_enable_latency_measurement())
187 #define nvds_latency_measurement_silent (nvds_get_latency_measurement_silent())
struct _NvDsMetaSubCompLatency NvDsMetaSubCompLatency
Holds information about latency of the given subcomponent.
gboolean nvds_set_output_system_timestamp(GstBuffer *buffer, gchar *element_name)
Sets the system timestamp when a Gst Buffer that is pushed to the downstream component.
gdouble comp_in_timestamp
Holds the system timestamp of the buffer when it arrives at the input of the first component in the p...
Holds information about the latency of a given frame.
guint frame_num
Holds the current frame number for which latency is measured.
gboolean nvds_get_latency_measurement_silent(void)
Indicates whether silent mode for latency measurement is enabled.
guint source_id
Holds the source ID of the component, e.g.
gboolean nvds_get_enable_latency_measurement(void)
Indicates whether the environment variable NVDS_ENABLE_LATENCY_MEASUREMENT is exported.
struct _NvDsMetaCompLatency NvDsMetaCompLatency
Holds information about latency of the given component.
NvDsUserMeta * nvds_set_input_system_timestamp(GstBuffer *buffer, gchar *element_name)
Sets the system timestamp when the Gst Buffer arrives as input at the component.
guint nvds_measure_buffer_latency(GstBuffer *buf, NvDsFrameLatencyInfo *latency_info)
Measures the latency of all frames present in the current batch.
void nvds_add_reference_timestamp_meta(GstBuffer *buffer, gchar *element_name, guint frame_id)
Adds the reference timestamp metadata for this buffer Note: element_name == "audiodecoder" and "nvv4l...
struct _GstBuffer GstBuffer
gdouble latency
Holds the latency of the frame in milliseconds.
