Holds information on all attributes classifed by a classifier network for one frame.
Definition at line 546 of file nvdsinfer_context.h.
Data Fields | |
| NvDsInferAttribute * | attributes |
| Holds a pointer to an array of attributes. More... | |
| unsigned int | numAttributes |
| Holds the size of the attributes array. More... | |
| char * | label |
| Holds a pointer to a string containing a label for the classified output. More... | |
| NvDsInferAttribute* NvDsInferClassificationOutput::attributes |
There may be more than one attribute, depending on the number of output coverage layers (multi-label classifiers).
Definition at line 551 of file nvdsinfer_context.h.
| char* NvDsInferClassificationOutput::label |
Definition at line 556 of file nvdsinfer_context.h.
| unsigned int NvDsInferClassificationOutput::numAttributes |
Definition at line 553 of file nvdsinfer_context.h.
