7.1 Release
nvdsinfer_dbscan.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2018-2019 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
30 #ifndef __NVDSINFER_DBSCAN_H__
31 #define __NVDSINFER_DBSCAN_H__
32
33 #include <stddef.h>
34 #include <stdint.h>
35
36 #include <nvdsinfer.h>
37
38 #ifdef __cplusplus
39 extern "C" {
40 #endif
41
43 struct NvDsInferDBScan;
44
46 typedef struct NvDsInferDBScan *NvDsInferDBScanHandle;
47
49 typedef struct
50 {
51  float eps;
52  uint32_t minBoxes;
59  float minScore;
61
68
75
90  size_t *numObjects);
91
111  size_t *numObjects);
112
113 #ifdef __cplusplus
114 }
115 #endif
116
117 #endif
118
NvDsInferDBScanClusteringParams::minScore
float minScore
Holds the sum of neighborhood confidence thresholds.
Definition: nvdsinfer_dbscan.h:59
NvDsInferDBScanClusteringParams::enableATHRFilter
int enableATHRFilter
Holds a Boolean; true enables the area-to-hit ratio (ATHR) filter.
Definition: nvdsinfer_dbscan.h:55
NvDsInferDBScanClusteringParams::thresholdATHR
float thresholdATHR
Holds the area-to-hit ratio threshold.
Definition: nvdsinfer_dbscan.h:57
NvDsInferDBScanCreate
NvDsInferDBScanHandle NvDsInferDBScanCreate()
Creates a new DBScan object clustering context.
NvDsInferDBScanClusterHybrid
void NvDsInferDBScanClusterHybrid(NvDsInferDBScanHandle handle, NvDsInferDBScanClusteringParams *params, NvDsInferObjectDetectionInfo *objects, size_t *numObjects)
Clusters an array of objects in place using specified clustering parameters.
void NvDsInferDBScanCluster(NvDsInferDBScanHandle handle, NvDsInferDBScanClusteringParams *params, NvDsInferObjectDetectionInfo *objects, size_t *numObjects)
Holds information about one parsed object from a detector's output.
Definition: nvdsinfer.h:143
Holds object clustering parameters required by DBSCAN.
Definition: nvdsinfer_dbscan.h:49
NvDsInferDBScanDestroy
void NvDsInferDBScanDestroy(NvDsInferDBScanHandle handle)
Destroys a DBScan object clustering context.
struct NvDsInferDBScan * NvDsInferDBScanHandle
Holds an opaque DBScan clustering context handle.
Definition: nvdsinfer_dbscan.h:46
nvdsinfer.h
NvDsInferDBScanClusteringParams::minBoxes
uint32_t minBoxes
Definition: nvdsinfer_dbscan.h:52
NvDsInferDBScanClusteringParams::eps
float eps
Definition: nvdsinfer_dbscan.h:51
