NvDsInferDetectionOutput Struct Reference
Holds information on all objects detected by a detector network in one frame.
Holds the information on all objects detected by a detector network in one frame.
Definition at line 566 of file sources/includes/nvdsinfer_context.h.
Collaboration diagram for NvDsInferDetectionOutput:
Data Fields
NvDsInferObjectobjects
 Holds a pointer to an array of objects. More...
unsigned int numObjects
 Holds the number of objects in objects. More...
Field Documentation
◆ numObjects
unsigned int NvDsInferDetectionOutput::numObjects
Number of objects in the array.
Definition at line 571 of file sources/includes/nvdsinfer_context.h.
Referenced by nvdsinferserver::DetectionOutput::swapObjects().
◆ objects
NvDsInferObject * NvDsInferDetectionOutput::objects
Array of objects.
Definition at line 569 of file sources/includes/nvdsinfer_context.h.
The documentation for this struct was generated from the following files:
