_NvBufSurfTransformCompositeBlendParams Struct Reference
Holds composite blend parameters for a composite blender call.
Definition at line 253 of file sources/includes/nvbufsurftransform.h.
Collaboration diagram for _NvBufSurfTransformCompositeBlendParams:
Data Fields
uint32_t composite_blend_flag
 Holds a flag that indicates which composition parameters are valid. More...
uint32_t input_buf_count
 Holds the number of input buffers to be composited. More...
NvBufSurfTransform_Inter composite_blend_filter
 Holds a blend/composite filter applicable only
More...
NvBufSurfTransform_ColorParamscolor_bg
 Holds background color list for blending if background buffer is absent, if NULL it wont be used, background buffer is expected to be NULL, if blending with static color is required. More...
uint32_t * perform_blending
 Holds a boolean flag list indicating whether blending to be done for particular buffer, if NULL, blending will be on all buffers, if valid value API expects at least numFilled size list and each element can take value 0 or 1. More...
void * reserved [STRUCTURE_PADDING]
 Reserved fields for future expansion. More...
Field Documentation
◆ color_bg
NvBufSurfTransform_ColorParams * _NvBufSurfTransformCompositeBlendParams::color_bg
Definition at line 265 of file sources/includes/nvbufsurftransform.h.
◆ composite_blend_filter
NvBufSurfTransform_Inter _NvBufSurfTransformCompositeBlendParams::composite_blend_filter
Definition at line 260 of file sources/includes/nvbufsurftransform.h.
◆ composite_blend_flag
uint32_t _NvBufSurfTransformCompositeBlendParams::composite_blend_flag
Definition at line 256 of file sources/includes/nvbufsurftransform.h.
◆ input_buf_count
uint32_t _NvBufSurfTransformCompositeBlendParams::input_buf_count
Definition at line 258 of file sources/includes/nvbufsurftransform.h.
◆ perform_blending
uint32_t * _NvBufSurfTransformCompositeBlendParams::perform_blending
Definition at line 270 of file sources/includes/nvbufsurftransform.h.
◆ reserved
void * _NvBufSurfTransformCompositeBlendParams::reserved
Definition at line 272 of file sources/includes/nvbufsurftransform.h.
