_NvBufSurfTransformCompositeBlendParamsEx Struct Reference
Holds extended composite blend parameters for NvBufSurfTransformMultiInputBufCompositeBlend and NvBufSurfTransformMultiInputBufCompositeBlendAsync API.
Definition at line 280 of file sources/includes/nvbufsurftransform.h.
Collaboration diagram for _NvBufSurfTransformCompositeBlendParamsEx:
Data Fields
NvBufSurfTransformCompositeBlendParams params
 Holds legacy composite blend parameters. More...
NvBufSurfTransformRectsrc_comp_rect
 Holds source rectangle coordinates of input buffers for compositing. More...
NvBufSurfTransformRectdst_comp_rect
 Holds destination rectangle coordinates of input buffers for compositing. More...
NvBufSurfTransform_Intercomposite_blend_filter
 Holds composite filters to use for composition/blending. More...
float * alpha
 Holds alpha values of input buffers for the blending. More...
void * reserved [STRUCTURE_PADDING]
 reserved fields. More...
Field Documentation
◆ alpha
float * _NvBufSurfTransformCompositeBlendParamsEx::alpha
Definition at line 291 of file sources/includes/nvbufsurftransform.h.
◆ composite_blend_filter
NvBufSurfTransform_Inter * _NvBufSurfTransformCompositeBlendParamsEx::composite_blend_filter
Definition at line 289 of file sources/includes/nvbufsurftransform.h.
◆ dst_comp_rect
NvBufSurfTransformRect * _NvBufSurfTransformCompositeBlendParamsEx::dst_comp_rect
Definition at line 287 of file sources/includes/nvbufsurftransform.h.
◆ params
NvBufSurfTransformCompositeBlendParams _NvBufSurfTransformCompositeBlendParamsEx::params
Definition at line 283 of file sources/includes/nvbufsurftransform.h.
◆ reserved
void * _NvBufSurfTransformCompositeBlendParamsEx::reserved
reserved fields.
Definition at line 293 of file sources/includes/nvbufsurftransform.h.
◆ src_comp_rect
NvBufSurfTransformRect * _NvBufSurfTransformCompositeBlendParamsEx::src_comp_rect
Definition at line 285 of file sources/includes/nvbufsurftransform.h.
