_NvBufSurfTransformCompositeParams Struct Reference
Holds composite parameters for a composite call.
Definition at line 217 of file sources/includes/nvbufsurftransform.h.
Collaboration diagram for _NvBufSurfTransformCompositeParams:
Data Fields
uint32_t composite_flag
 Holds a flag that indicates which composition parameters are valid. More...
uint32_t input_buf_count
 Holds the number of input buffers to be composited. More...
NvBufSurfTransformRectsrc_comp_rect
 Holds source rectangle coordinates of input buffers for compositing. More...
NvBufSurfTransformRectdst_comp_rect
 Holds destination rectangle coordinates of input buffers for compositing. More...
NvBufSurfTransform_Inter composite_filter
 Holds a composite filter. More...
void * reserved [STRUCTURE_PADDING]
 Reserved fields for future expansion. More...
Field Documentation
◆ composite_filter
NvBufSurfTransform_Inter _NvBufSurfTransformCompositeParams::composite_filter
Definition at line 229 of file sources/includes/nvbufsurftransform.h.
◆ composite_flag
uint32_t _NvBufSurfTransformCompositeParams::composite_flag
Definition at line 220 of file sources/includes/nvbufsurftransform.h.
◆ dst_comp_rect
NvBufSurfTransformRect * _NvBufSurfTransformCompositeParams::dst_comp_rect
Definition at line 227 of file sources/includes/nvbufsurftransform.h.
◆ input_buf_count
uint32_t _NvBufSurfTransformCompositeParams::input_buf_count
Definition at line 222 of file sources/includes/nvbufsurftransform.h.
◆ reserved
void * _NvBufSurfTransformCompositeParams::reserved
Definition at line 231 of file sources/includes/nvbufsurftransform.h.
◆ src_comp_rect
NvBufSurfTransformRect * _NvBufSurfTransformCompositeParams::src_comp_rect
Definition at line 224 of file sources/includes/nvbufsurftransform.h.
