_NvDsBatchMeta Struct Reference
Holds information about a formed batch containing frames from different sources.
NOTE: Both Video and Audio metadata uses the same NvDsBatchMeta type. NOTE: Audio batch metadata is formed within nvinferaudio plugin and will not be corresponding to any one buffer output from nvinferaudio. The NvDsBatchMeta for audio is attached to the last input buffer when the audio batch buffering reach configurable threshold (audio frame length) and this is when inference output is available.
Definition at line 257 of file sources/includes/nvdsmeta.h.
Collaboration diagram for _NvDsBatchMeta:
Data Fields
NvDsBaseMeta base_meta
guint max_frames_in_batch
 Holds the maximum number of frames in the batch. More...
guint num_frames_in_batch
 Holds the number of frames now in the batch. More...
NvDsMetaPoolframe_meta_pool
 Holds a pointer to a pool of pointers of type NvDsFrameMeta, representing a pool of frame metas. More...
NvDsMetaPoolobj_meta_pool
 Holds a pointer to a pool of pointers of type NvDsObjMeta, representing a pool of object metas. More...
NvDsMetaPoolclassifier_meta_pool
 Holds a pointer to a pool of pointers of type NvDsClassifierMeta, representing a pool of classifier metas. More...
NvDsMetaPooldisplay_meta_pool
 Holds a pointer to a pool of pointers of type NvDsDisplayMeta, representing a pool of display metas. More...
NvDsMetaPooluser_meta_pool
 Holds a pointer to a pool of pointers of type NvDsUserMeta, representing a pool of user metas. More...
NvDsMetaPoollabel_info_meta_pool
 Holds a pointer to a pool of pointers of type NvDsLabelInfo, representing a pool of label metas. More...
NvDsFrameMetaListframe_meta_list
 Holds a pointer to a list of pointers of type NvDsFrameMeta or NvDsAudioFrameMeta (when the batch represent audio batch), representing frame metas used in the current batch. More...
NvDsUserMetaListbatch_user_meta_list
 Holds a pointer to a list of pointers of type NvDsUserMeta, representing user metas in the current batch. More...
GRecMutex meta_mutex
 Holds a lock to be set before accessing metadata to avoid simultaneous update by multiple components. More...
gint64 misc_batch_info [MAX_USER_FIELDS]
 Holds an array of user-specific batch information. More...
gint64 reserved [MAX_RESERVED_FIELDS]
 For internal use. More...
Field Documentation
◆ base_meta
NvDsBaseMeta _NvDsBatchMeta::base_meta
Definition at line 258 of file sources/includes/nvdsmeta.h.
◆ batch_user_meta_list
NvDsUserMetaList * _NvDsBatchMeta::batch_user_meta_list
Definition at line 288 of file sources/includes/nvdsmeta.h.
◆ classifier_meta_pool
NvDsMetaPool * _NvDsBatchMeta::classifier_meta_pool
Definition at line 271 of file sources/includes/nvdsmeta.h.
◆ display_meta_pool
NvDsMetaPool * _NvDsBatchMeta::display_meta_pool
Definition at line 274 of file sources/includes/nvdsmeta.h.
◆ frame_meta_list
NvDsFrameMetaList * _NvDsBatchMeta::frame_meta_list
Definition at line 285 of file sources/includes/nvdsmeta.h.
◆ frame_meta_pool
NvDsMetaPool * _NvDsBatchMeta::frame_meta_pool
Definition at line 265 of file sources/includes/nvdsmeta.h.
◆ label_info_meta_pool
NvDsMetaPool * _NvDsBatchMeta::label_info_meta_pool
Definition at line 280 of file sources/includes/nvdsmeta.h.
◆ max_frames_in_batch
guint _NvDsBatchMeta::max_frames_in_batch
Definition at line 260 of file sources/includes/nvdsmeta.h.
◆ meta_mutex
GRecMutex _NvDsBatchMeta::meta_mutex
Definition at line 291 of file sources/includes/nvdsmeta.h.
◆ misc_batch_info
gint64 _NvDsBatchMeta::misc_batch_info
Definition at line 293 of file sources/includes/nvdsmeta.h.
◆ num_frames_in_batch
guint _NvDsBatchMeta::num_frames_in_batch
Definition at line 262 of file sources/includes/nvdsmeta.h.
◆ obj_meta_pool
NvDsMetaPool * _NvDsBatchMeta::obj_meta_pool
Definition at line 268 of file sources/includes/nvdsmeta.h.
◆ reserved
gint64 _NvDsBatchMeta::reserved
For internal use.
Definition at line 295 of file sources/includes/nvdsmeta.h.
◆ user_meta_pool
NvDsMetaPool * _NvDsBatchMeta::user_meta_pool
Definition at line 277 of file sources/includes/nvdsmeta.h.
