_NvDsInferContextInitParams Struct Reference
Holds the initialization parameters required for the NvDsInferContext interface.
Definition at line 241 of file sources/includes/nvdsinfer_context.h.
Collaboration diagram for _NvDsInferContextInitParams:
Data Fields
unsigned int uniqueID
 Holds a unique identifier for the instance. More...
NvDsInferNetworkMode networkMode
 Holds an internal data format specifier used by the inference engine. More...
char protoFilePath [_PATH_MAX]
 Holds the pathname of the prototxt file. More...
char modelFilePath [_PATH_MAX]
 Holds the pathname of the caffemodel file. More...
char uffFilePath [_PATH_MAX]
 Holds the pathname of the UFF model file. More...
char onnxFilePath [_PATH_MAX]
 Holds the pathname of the ONNX model file. More...
char tltEncodedModelFilePath [_PATH_MAX]
 Holds the pathname of the TLT encoded model file. More...
char int8CalibrationFilePath [_PATH_MAX]
 Holds the pathname of the INT8 calibration file. More...
union {
   NvDsInferDimsCHW   inputDims
 Holds the input dimensions for the model. More...
   NvDsInferDimsCHW   uffDimsCHW
 Holds the input dimensions for the UFF model. More...
instead
NvDsInferTensorOrder uffInputOrder
 Holds the original input order for the UFF model. More...
char uffInputBlobName [_MAX_STR_LENGTH]
 Holds the name of the input layer for the UFF model. More...
NvDsInferTensorOrder netInputOrder
 Holds the original input order for the network. More...
char tltModelKey [_MAX_STR_LENGTH]
 Holds the string key for decoding the TLT encoded model. More...
char modelEngineFilePath [_PATH_MAX]
 Holds the pathname of the serialized model engine file. More...
unsigned int maxBatchSize
 Holds the maximum number of frames to be inferred together in a batch. More...
char labelsFilePath [_PATH_MAX]
 Holds the pathname of the labels file containing strings for the class labels. More...
char meanImageFilePath [_PATH_MAX]
 Holds the pathname of the mean image file (PPM format). More...
float networkScaleFactor
 Holds the normalization factor with which to scale the input pixels. More...
NvDsInferFormat networkInputFormat
 Holds the network input format. More...
float offsets [_MAX_CHANNELS]
 Holds the per-channel offsets for mean subtraction. More...
unsigned int numOffsets
NvDsInferNetworkType networkType
 Holds the network type. More...
Use NvDsInferClusterMode instead int useDBScan
 Holds a Boolean; true if DBScan is to be used for object clustering, or false if OpenCV groupRectangles is to be used. More...
unsigned int numDetectedClasses
 Holds the number of classes detected by a detector network. More...
NvDsInferDetectionParamsperClassDetectionParams
 Holds per-class detection parameters. More...
float classifierThreshold
 Holds the minimum confidence threshold for the classifier to consider a label valid. More...
float segmentationThreshold
char ** outputLayerNames
 Holds a pointer to an array of pointers to output layer names. More...
unsigned int numOutputLayers
 Holds the number of output layer names. More...
char customLibPath [_PATH_MAX]
 Holds the pathname of the library containing custom methods required to support the network. More...
char customBBoxParseFuncName [_MAX_STR_LENGTH]
 Holds the name of the custom bounding box function in the custom library. More...
char customClassifierParseFuncName [_MAX_STR_LENGTH]
 Name of the custom classifier attribute parsing function in the custom library. More...
int copyInputToHostBuffers
 Holds a Boolean; true if the input layer contents are to be copied to host memory for access by the application. More...
unsigned int gpuID
 Holds the ID of the GPU which is to run the inference. More...
int useDLA
 Holds a Boolean; true if DLA is to be used. More...
int dlaCore
 Holds the ID of the DLA core to use. More...
unsigned int outputBufferPoolSize
 Holds the number of sets of output buffers (host and device) to be allocated. More...
char customNetworkConfigFilePath [_PATH_MAX]
 Holds the pathname of the configuration file for custom network creation. More...
char customEngineCreateFuncName [_MAX_STR_LENGTH]
 Name of the custom engine creation function in the custom library. More...
int forceImplicitBatchDimension
 For model parsers supporting both implicit batch dim and full dims, prefer to use implicit batch dim. More...
unsigned int workspaceSize
 Max workspace size (unit MB) that will be used as tensorrt build settings for cuda engine. More...
NvDsInferDimsCHW inferInputDims
 Inference input dimensions for runtime engine. More...
NvDsInferClusterMode clusterMode
 Holds the type of clustering mode. More...
char customBBoxInstanceMaskParseFuncName [_MAX_STR_LENGTH]
 Holds the name of the bounding box and instance mask parse function in the custom library. More...
char ** outputIOFormats
 Can be used to specify the format and datatype for bound output layers. More...
unsigned int numOutputIOFormats
 Holds number of output IO formats specified. More...
char customSegmentationParseFuncName [_MAX_STR_LENGTH]
 Holds the name of segmentation parse function in the custom library. More...
char ** layerDevicePrecisions
 Can be used to specify the device type and inference precision of layers. More...
unsigned int numLayerDevicePrecisions
 Holds number of layer device precisions specified. More...
NvDsInferTensorOrder segmentationOutputOrder
 Holds output order for segmentation network. More...
int inputFromPreprocessedTensor
 Boolean flag indicating that caller will supply preprocessed tensors for inferencing. More...
int disableOutputHostCopy
 Boolean flag indicating that whether we will post processing on GPU if this flag enabled, nvinfer will return gpu buffer to prossprocessing user must write cuda post processing code. More...
int autoIncMem
 Boolean flag indicating that whether we will automatically increase bufferpool size when facing a bottleneck. More...
double maxGPUMemPer
 Max gpu memory that can be occupied while expanding the bufferpool. More...
int dumpIpTensor
 Boolean flag indicating whether or not to dump raw input tensor data. More...
int dumpOpTensor
int overwriteIpTensor
 Boolean flag indicating whether or not to overwrite raw input tensor data provided by the user into the buffer for inference. More...
char ipTensorFilePath [_PATH_MAX]
 Path to the raw input tensor data that is going to be used to overwrite the buffer. More...
int overwriteOpTensor
 Boolean flag indicating whether or not to overwrite raw ouput tensor data provided by the user into the buffer for inference. More...
char ** opTensorFilePath
 List of paths to the raw output tensor data that are going to be used to overwrite the different output buffers. More...
int useStronglyTyped
 Boolean flag indicating whether to enable strongly typed network mode. More...
char ** dynamicPropertyKeys
 Dynamic properties for TensorRT/trtexec flags. More...
char ** dynamicPropertyValues
unsigned int numDynamicProperties
int warmupEngine
 Boolean flag indicating whether to run TensorRT engine warmup during initialization. More...
union {
instead
Field Documentation
◆ autoIncMem
int _NvDsInferContextInitParams::autoIncMem
Definition at line 430 of file sources/includes/nvdsinfer_context.h.
◆ classifierThreshold
float _NvDsInferContextInitParams::classifierThreshold
Definition at line 331 of file sources/includes/nvdsinfer_context.h.
◆ clusterMode
NvDsInferClusterMode _NvDsInferContextInitParams::clusterMode
Definition at line 389 of file sources/includes/nvdsinfer_context.h.
◆ copyInputToHostBuffers
int _NvDsInferContextInitParams::copyInputToHostBuffers
Definition at line 353 of file sources/includes/nvdsinfer_context.h.
◆ customBBoxInstanceMaskParseFuncName
char _NvDsInferContextInitParams::customBBoxInstanceMaskParseFuncName
Definition at line 393 of file sources/includes/nvdsinfer_context.h.
◆ customBBoxParseFuncName
char _NvDsInferContextInitParams::customBBoxParseFuncName
Definition at line 346 of file sources/includes/nvdsinfer_context.h.
◆ customClassifierParseFuncName
char _NvDsInferContextInitParams::customClassifierParseFuncName
Definition at line 349 of file sources/includes/nvdsinfer_context.h.
◆ customEngineCreateFuncName
char _NvDsInferContextInitParams::customEngineCreateFuncName
Definition at line 373 of file sources/includes/nvdsinfer_context.h.
◆ customLibPath
char _NvDsInferContextInitParams::customLibPath
Definition at line 343 of file sources/includes/nvdsinfer_context.h.
◆ customNetworkConfigFilePath
char _NvDsInferContextInitParams::customNetworkConfigFilePath
This can be used to store custom properties required by the custom network creation function.
Definition at line 370 of file sources/includes/nvdsinfer_context.h.
◆ customSegmentationParseFuncName
char _NvDsInferContextInitParams::customSegmentationParseFuncName
Definition at line 403 of file sources/includes/nvdsinfer_context.h.
◆ disableOutputHostCopy
int _NvDsInferContextInitParams::disableOutputHostCopy
Definition at line 425 of file sources/includes/nvdsinfer_context.h.
◆ dlaCore
int _NvDsInferContextInitParams::dlaCore
Definition at line 361 of file sources/includes/nvdsinfer_context.h.
◆ dumpIpTensor
int _NvDsInferContextInitParams::dumpIpTensor
Definition at line 438 of file sources/includes/nvdsinfer_context.h.
◆ dumpOpTensor
int _NvDsInferContextInitParams::dumpOpTensor
Definition at line 441 of file sources/includes/nvdsinfer_context.h.
◆ dynamicPropertyKeys
char ** _NvDsInferContextInitParams::dynamicPropertyKeys
This allows adding new properties without modifying the structure. Each property is stored as a key-value pair where:
  • key: property name (e.g., "data_max", "init_max", "calibration_data")
  • value: property value as string (can be converted to appropriate type)
Definition at line 472 of file sources/includes/nvdsinfer_context.h.
◆ dynamicPropertyValues
char ** _NvDsInferContextInitParams::dynamicPropertyValues
Definition at line 473 of file sources/includes/nvdsinfer_context.h.
◆ forceImplicitBatchDimension
int _NvDsInferContextInitParams::forceImplicitBatchDimension
By default, full dims network mode is used.
Definition at line 378 of file sources/includes/nvdsinfer_context.h.
◆ gpuID
unsigned int _NvDsInferContextInitParams::gpuID
Definition at line 356 of file sources/includes/nvdsinfer_context.h.
◆ inferInputDims
NvDsInferDimsCHW _NvDsInferContextInitParams::inferInputDims
Definition at line 386 of file sources/includes/nvdsinfer_context.h.
◆ inputDims
NvDsInferDimsCHW _NvDsInferContextInitParams::inputDims
Definition at line 267 of file sources/includes/nvdsinfer_context.h.
◆ inputFromPreprocessedTensor
int _NvDsInferContextInitParams::inputFromPreprocessedTensor
NvDsInferContext will skip preprocessing initialization steps and will not interpret network input layer dimensions.
Definition at line 419 of file sources/includes/nvdsinfer_context.h.
◆ instead [1/2]
union { ... } Use inferInputDims _NvDsInferContextInitParams::instead
Definition at line 265 of file 9.0/sources/includes/nvdsinfer_context.h.
◆ instead [2/2]
Definition at line 265 of file sources/includes/nvdsinfer_context.h.
◆ int8CalibrationFilePath
char _NvDsInferContextInitParams::int8CalibrationFilePath
Required only when using INT8 mode.
Definition at line 263 of file sources/includes/nvdsinfer_context.h.
◆ ipTensorFilePath
char _NvDsInferContextInitParams::ipTensorFilePath
Definition at line 449 of file sources/includes/nvdsinfer_context.h.
◆ labelsFilePath
char _NvDsInferContextInitParams::labelsFilePath
The labels file is optional. The file format is described in the custom models section of the DeepStream SDK documentation.
Definition at line 296 of file sources/includes/nvdsinfer_context.h.
◆ layerDevicePrecisions
char ** _NvDsInferContextInitParams::layerDevicePrecisions
For each layer specified the format is "<layer-name>:<device-type>:<precision>"
Definition at line 408 of file sources/includes/nvdsinfer_context.h.
◆ maxBatchSize
unsigned int _NvDsInferContextInitParams::maxBatchSize
The number of input frames in a batch must be less than or equal to this.
Definition at line 291 of file sources/includes/nvdsinfer_context.h.
◆ maxGPUMemPer
double _NvDsInferContextInitParams::maxGPUMemPer
Definition at line 434 of file sources/includes/nvdsinfer_context.h.
◆ meanImageFilePath
char _NvDsInferContextInitParams::meanImageFilePath
File resolution must be equal to the network input resolution.
Definition at line 300 of file sources/includes/nvdsinfer_context.h.
◆ modelEngineFilePath
char _NvDsInferContextInitParams::modelEngineFilePath
When using the model engine file, other parameters required for creating the model engine are ignored.
Definition at line 286 of file sources/includes/nvdsinfer_context.h.
◆ modelFilePath
char _NvDsInferContextInitParams::modelFilePath
Definition at line 253 of file sources/includes/nvdsinfer_context.h.
◆ netInputOrder
NvDsInferTensorOrder _NvDsInferContextInitParams::netInputOrder
Definition at line 278 of file sources/includes/nvdsinfer_context.h.
◆ networkInputFormat
NvDsInferFormat _NvDsInferContextInitParams::networkInputFormat
Definition at line 306 of file sources/includes/nvdsinfer_context.h.
◆ networkMode
NvDsInferNetworkMode _NvDsInferContextInitParams::networkMode
Definition at line 248 of file sources/includes/nvdsinfer_context.h.
◆ networkScaleFactor
float _NvDsInferContextInitParams::networkScaleFactor
Definition at line 303 of file sources/includes/nvdsinfer_context.h.
◆ networkType
NvDsInferNetworkType _NvDsInferContextInitParams::networkType
Definition at line 315 of file sources/includes/nvdsinfer_context.h.
◆ numDetectedClasses
unsigned int _NvDsInferContextInitParams::numDetectedClasses
Definition at line 323 of file sources/includes/nvdsinfer_context.h.
◆ numDynamicProperties
unsigned int _NvDsInferContextInitParams::numDynamicProperties
Definition at line 474 of file sources/includes/nvdsinfer_context.h.
◆ numLayerDevicePrecisions
unsigned int _NvDsInferContextInitParams::numLayerDevicePrecisions
Definition at line 410 of file sources/includes/nvdsinfer_context.h.
◆ numOffsets
unsigned int _NvDsInferContextInitParams::numOffsets
Definition at line 312 of file sources/includes/nvdsinfer_context.h.
◆ numOutputIOFormats
unsigned int _NvDsInferContextInitParams::numOutputIOFormats
Definition at line 400 of file sources/includes/nvdsinfer_context.h.
◆ numOutputLayers
unsigned int _NvDsInferContextInitParams::numOutputLayers
Definition at line 338 of file sources/includes/nvdsinfer_context.h.
◆ offsets
float _NvDsInferContextInitParams::offsets
This is an alternative to the mean image file. The number of offsets in the array must be equal to the number of input channels.
Definition at line 311 of file sources/includes/nvdsinfer_context.h.
◆ onnxFilePath
char _NvDsInferContextInitParams::onnxFilePath
Definition at line 257 of file sources/includes/nvdsinfer_context.h.
◆ opTensorFilePath
char ** _NvDsInferContextInitParams::opTensorFilePath
Definition at line 457 of file sources/includes/nvdsinfer_context.h.
◆ outputBufferPoolSize
unsigned int _NvDsInferContextInitParams::outputBufferPoolSize
Definition at line 365 of file sources/includes/nvdsinfer_context.h.
◆ outputIOFormats
char ** _NvDsInferContextInitParams::outputIOFormats
For each layer specified the format is "<layer-name>:<data-type>:<format>"
Definition at line 398 of file sources/includes/nvdsinfer_context.h.
◆ outputLayerNames
char ** _NvDsInferContextInitParams::outputLayerNames
Definition at line 336 of file sources/includes/nvdsinfer_context.h.
◆ overwriteIpTensor
int _NvDsInferContextInitParams::overwriteIpTensor
Definition at line 445 of file sources/includes/nvdsinfer_context.h.
◆ overwriteOpTensor
int _NvDsInferContextInitParams::overwriteOpTensor
Definition at line 453 of file sources/includes/nvdsinfer_context.h.
◆ perClassDetectionParams
NvDsInferDetectionParams * _NvDsInferContextInitParams::perClassDetectionParams
The array's size must be equal to numDetectedClasses.
Definition at line 327 of file sources/includes/nvdsinfer_context.h.
◆ protoFilePath
char _NvDsInferContextInitParams::protoFilePath
Definition at line 251 of file sources/includes/nvdsinfer_context.h.
◆ segmentationOutputOrder
NvDsInferTensorOrder _NvDsInferContextInitParams::segmentationOutputOrder
Definition at line 413 of file sources/includes/nvdsinfer_context.h.
◆ segmentationThreshold
float _NvDsInferContextInitParams::segmentationThreshold
Definition at line 333 of file sources/includes/nvdsinfer_context.h.
◆ tltEncodedModelFilePath
char _NvDsInferContextInitParams::tltEncodedModelFilePath
Definition at line 259 of file sources/includes/nvdsinfer_context.h.
◆ tltModelKey
char _NvDsInferContextInitParams::tltModelKey
Definition at line 281 of file sources/includes/nvdsinfer_context.h.
◆ uffDimsCHW
NvDsInferDimsCHW _NvDsInferContextInitParams::uffDimsCHW
Definition at line 269 of file sources/includes/nvdsinfer_context.h.
◆ uffFilePath
char _NvDsInferContextInitParams::uffFilePath
Definition at line 255 of file sources/includes/nvdsinfer_context.h.
◆ uffInputBlobName
char _NvDsInferContextInitParams::uffInputBlobName
Definition at line 275 of file sources/includes/nvdsinfer_context.h.
◆ uffInputOrder
NvDsInferTensorOrder _NvDsInferContextInitParams::uffInputOrder
Definition at line 273 of file sources/includes/nvdsinfer_context.h.
◆ uniqueID
unsigned int _NvDsInferContextInitParams::uniqueID
This can be used to identify the instance that is generating log and error messages.
Definition at line 245 of file sources/includes/nvdsinfer_context.h.
◆ useDBScan
Use NvDsInferClusterMode instead int _NvDsInferContextInitParams::useDBScan
Definition at line 320 of file sources/includes/nvdsinfer_context.h.
◆ useDLA
int _NvDsInferContextInitParams::useDLA
Definition at line 359 of file sources/includes/nvdsinfer_context.h.
◆ useStronglyTyped
int _NvDsInferContextInitParams::useStronglyTyped
When enabled, tensor data types are inferred from network input types and operator type specification following TensorRT type inference rules. This corresponds to the –stronglyTyped flag in trtexec.
Definition at line 464 of file sources/includes/nvdsinfer_context.h.
◆ warmupEngine
int _NvDsInferContextInitParams::warmupEngine
When enabled, dummy inference is run for batch sizes 1 through maxBatchSize to pre-warm TRT's internal CUDA kernel caches and execution graphs. This eliminates the latency penalty that occurs when the first real inference arrives with a previously unseen batch size (partial batch), which can cause persistent latency accumulation in streaming pipelines.
Definition at line 484 of file sources/includes/nvdsinfer_context.h.
◆ workspaceSize
unsigned int _NvDsInferContextInitParams::workspaceSize
Definition at line 383 of file sources/includes/nvdsinfer_context.h.
