7.1 Release
_NvDsLabelInfo Struct Reference
Holds label metadata for the classifier.
Definition at line 417 of file nvdsmeta.h.
Collaboration diagram for _NvDsLabelInfo:
Data Fields
NvDsBaseMeta base_meta
guint num_classes
 Holds the number of classes of the given label. More...
gchar result_label [MAX_LABEL_SIZE]
 Holds an string describing the label of the classified object. More...
gchar * pResult_label
 Holds a pointer to the result label if its length exceeds MAX_LABEL_SIZE bytes. More...
guint result_class_id
 Holds the class UD of the best result. More...
guint label_id
 Holds the label ID in case there are multiple label classifiers. More...
gfloat result_prob
 Holds the probability of best result. More...
Field Documentation
◆ base_meta
NvDsBaseMeta _NvDsLabelInfo::base_meta
Definition at line 418 of file nvdsmeta.h.
◆ label_id
guint _NvDsLabelInfo::label_id
Definition at line 428 of file nvdsmeta.h.
◆ num_classes
guint _NvDsLabelInfo::num_classes
Definition at line 420 of file nvdsmeta.h.
◆ pResult_label
gchar* _NvDsLabelInfo::pResult_label
Definition at line 424 of file nvdsmeta.h.
◆ result_class_id
guint _NvDsLabelInfo::result_class_id
Definition at line 426 of file nvdsmeta.h.
◆ result_label
gchar _NvDsLabelInfo::result_label[MAX_LABEL_SIZE]
Definition at line 422 of file nvdsmeta.h.
◆ result_prob
gfloat _NvDsLabelInfo::result_prob
Definition at line 430 of file nvdsmeta.h.
