_NvDsMetaCompLatency Struct Reference
Holds information about latency of the given component.
Definition at line 58 of file sources/includes/nvds_latency_meta.h.
Collaboration diagram for _NvDsMetaCompLatency:
Data Fields
gchar component_name [MAX_COMPONENT_LEN]
 Holds the name of the component for which latency is measured. More...
gdouble in_system_timestamp
 Holds the system timestamp of the buffer when it arrives at the input of the component. More...
gdouble out_system_timestamp
 Holds the system timestamp of buffer when it is sent to the downstream component. More...
guint source_id
 Holds the source ID of the component, e.g. More...
guint frame_num
 Holds the current frame number for which latency is measured. More...
guint pad_index
 Holds the pad or port index of the stream muxer for the frame in the batch. More...
NvDsMetaSubCompLatency sub_comp_latencies [16]
 Holds latency information of subcomponent in an array. More...
guint num_sub_comps
 Holds the number of subcomponents for the given component. More...
Field Documentation
◆ component_name
gchar _NvDsMetaCompLatency::component_name
Definition at line 60 of file sources/includes/nvds_latency_meta.h.
◆ frame_num
guint _NvDsMetaCompLatency::frame_num
Definition at line 70 of file sources/includes/nvds_latency_meta.h.
◆ in_system_timestamp
gdouble _NvDsMetaCompLatency::in_system_timestamp
Definition at line 63 of file sources/includes/nvds_latency_meta.h.
◆ num_sub_comps
guint _NvDsMetaCompLatency::num_sub_comps
Definition at line 77 of file sources/includes/nvds_latency_meta.h.
◆ out_system_timestamp
gdouble _NvDsMetaCompLatency::out_system_timestamp
Definition at line 66 of file sources/includes/nvds_latency_meta.h.
◆ pad_index
guint _NvDsMetaCompLatency::pad_index
Definition at line 73 of file sources/includes/nvds_latency_meta.h.
◆ source_id
guint _NvDsMetaCompLatency::source_id
the camera ID.
Definition at line 68 of file sources/includes/nvds_latency_meta.h.
◆ sub_comp_latencies
NvDsMetaSubCompLatency _NvDsMetaCompLatency::sub_comp_latencies
Definition at line 75 of file sources/includes/nvds_latency_meta.h.
