7.1 Release
_NvDsMetaSubCompLatency Struct Reference
Holds information about latency of the given subcomponent.
Definition at line 44 of file nvds_latency_meta.h.
Data Fields
gchar sub_comp_name [MAX_COMPONENT_LEN]
 Holds the subcomponent names. More...
gdouble in_system_timestamp
 Holds the system timestamp of the buffer when it arrives at the input of the component. More...
gdouble out_system_timestamp
 Holds the system timestamp of the buffer when it leaves at the output of the component. More...
Field Documentation
◆ in_system_timestamp
gdouble _NvDsMetaSubCompLatency::in_system_timestamp
Definition at line 49 of file nvds_latency_meta.h.
◆ out_system_timestamp
gdouble _NvDsMetaSubCompLatency::out_system_timestamp
Definition at line 52 of file nvds_latency_meta.h.
◆ sub_comp_name
gchar _NvDsMetaSubCompLatency::sub_comp_name[MAX_COMPONENT_LEN]
Definition at line 46 of file nvds_latency_meta.h.
