Holds the initialization parameters required for the NvDsPostProcessContext interface.
Definition at line 262 of file post_processor_struct.h.
Data Fields | |
| unsigned int | uniqueID |
| Holds a unique identifier for the instance. More... | |
| unsigned int | maxBatchSize |
| Holds the maximum number of frames to be inferred together in a batch. More... | |
| char | labelsFilePath [_PATH_MAX] |
| Holds the pathname of the labels file containing strings for the class labels. More... | |
| NvDsPostProcessNetworkType | networkType |
| Holds the network type. More... | |
| unsigned int | numDetectedClasses |
| Holds the number of classes detected by a detector network. More... | |
| NvDsPostProcessDetectionParams * | perClassDetectionParams |
| Holds per-class detection parameters. More... | |
| float | classifierThreshold |
| Holds the minimum confidence threshold for the classifier to consider a label valid. More... | |
| float | segmentationThreshold |
| char ** | outputLayerNames |
| Holds a pointer to an array of pointers to output layer names. More... | |
| unsigned int | numOutputLayers |
| Holds the number of output layer names. More... | |
| unsigned int | gpuID |
| Holds the ID of the GPU which is to run the inference. More... | |
| NvDsInferDimsCHW | inferInputDims |
| Inference input dimensions for runtime engine. More... | |
| NvDsPostProcessClusterMode | clusterMode |
| Holds the type of clustering mode. More... | |
| char | customBBoxInstanceMaskParseFuncName [_MAX_STR_LENGTH] |
| Holds the name of the bounding box and instance mask parse function in the custom library. More... | |
| char | customBBoxParseFuncName [_MAX_STR_LENGTH] |
| Holds the name of the custom bounding box function in the custom library. More... | |
| char | customClassifierParseFuncName [_MAX_STR_LENGTH] |
| Name of the custom classifier attribute parsing function in the custom library. More... | |
| NvDsPostProcessTensorOrder | segmentationOutputOrder |
| Holds output order for segmentation network. More... | |
| char * | classifier_type |
| gboolean | preprocessor_support = FALSE |
| Holds boolean value to show whether preprocessor support is there. More... | |
| char* _NvDsPostProcessContextInitParams::classifier_type |
Definition at line 323 of file post_processor_struct.h.
Referenced by PostProcessAlgorithm::PostProcessAlgorithm().
| float _NvDsPostProcessContextInitParams::classifierThreshold |
Definition at line 291 of file post_processor_struct.h.
| NvDsPostProcessClusterMode _NvDsPostProcessContextInitParams::clusterMode |
Definition at line 307 of file post_processor_struct.h.
| char _NvDsPostProcessContextInitParams::customBBoxInstanceMaskParseFuncName[_MAX_STR_LENGTH] |
Definition at line 311 of file post_processor_struct.h.
| char _NvDsPostProcessContextInitParams::customBBoxParseFuncName[_MAX_STR_LENGTH] |
Definition at line 315 of file post_processor_struct.h.
| char _NvDsPostProcessContextInitParams::customClassifierParseFuncName[_MAX_STR_LENGTH] |
Definition at line 318 of file post_processor_struct.h.
| unsigned int _NvDsPostProcessContextInitParams::gpuID |
Definition at line 301 of file post_processor_struct.h.
| NvDsInferDimsCHW _NvDsPostProcessContextInitParams::inferInputDims |
Definition at line 304 of file post_processor_struct.h.
| char _NvDsPostProcessContextInitParams::labelsFilePath[_PATH_MAX] |
The labels file is optional. The file format is described in the custom models section of the DeepStream SDK documentation.
Definition at line 276 of file post_processor_struct.h.
| unsigned int _NvDsPostProcessContextInitParams::maxBatchSize |
The number of input frames in a batch must be less than or equal to this.
Definition at line 271 of file post_processor_struct.h.
| NvDsPostProcessNetworkType _NvDsPostProcessContextInitParams::networkType |
Definition at line 280 of file post_processor_struct.h.
| unsigned int _NvDsPostProcessContextInitParams::numDetectedClasses |
Definition at line 283 of file post_processor_struct.h.
| unsigned int _NvDsPostProcessContextInitParams::numOutputLayers |
Definition at line 298 of file post_processor_struct.h.
| char** _NvDsPostProcessContextInitParams::outputLayerNames |
Definition at line 296 of file post_processor_struct.h.
| NvDsPostProcessDetectionParams* _NvDsPostProcessContextInitParams::perClassDetectionParams |
The array's size must be equal to numDetectedClasses.
Definition at line 287 of file post_processor_struct.h.
| gboolean _NvDsPostProcessContextInitParams::preprocessor_support = FALSE |
Definition at line 325 of file post_processor_struct.h.
| NvDsPostProcessTensorOrder _NvDsPostProcessContextInitParams::segmentationOutputOrder |
Definition at line 321 of file post_processor_struct.h.
| float _NvDsPostProcessContextInitParams::segmentationThreshold |
Definition at line 293 of file post_processor_struct.h.
| unsigned int _NvDsPostProcessContextInitParams::uniqueID |
This can be used to identify the instance that is generating log and error messages.
Definition at line 266 of file post_processor_struct.h.
