7.1 Release
_NvOSD_FrameArrowParams Struct Reference
Holds information about the arrows in a frame.
Definition at line 121 of file nvll_osd_api.h.
Collaboration diagram for _NvOSD_FrameArrowParams:
Data Fields
NvBufSurfaceParamsbuf_ptr
 Holds a pointer to the buffer containing the frame. More...
NvOSD_Mode mode
 Holds the OSD mode to be used for processing. More...
int num_arrows
 Holds the number of arrows. More...
NvOSD_ArrowParamsarrow_params_list
 Holds the parameters of the arrows. More...
NvBufSurfacesurf
 Holds information about batched buffers. More...
Field Documentation
◆ arrow_params_list
NvOSD_ArrowParams* _NvOSD_FrameArrowParams::arrow_params_list
Definition at line 131 of file nvll_osd_api.h.
◆ buf_ptr
NvBufSurfaceParams* _NvOSD_FrameArrowParams::buf_ptr
buf_ptr is deprecated. Use NvBufSurface *surf instead
Definition at line 125 of file nvll_osd_api.h.
◆ mode
NvOSD_Mode _NvOSD_FrameArrowParams::mode
Definition at line 127 of file nvll_osd_api.h.
◆ num_arrows
int _NvOSD_FrameArrowParams::num_arrows
Definition at line 129 of file nvll_osd_api.h.
◆ surf
NvBufSurface* _NvOSD_FrameArrowParams::surf
Definition at line 133 of file nvll_osd_api.h.
