7.1 Release
On-Screen Display API
Defines the NvOSD library to be used to draw rectangles and text over the frame.
Data Structures
struct  _NvOSD_FrameTextParams
 Holds information about the text in a frame. More...
struct  _NvOSD_FrameRectParams
 Holds information about the rectangles in a frame. More...
struct  _NvOSD_FrameSegmentMaskParams
struct  _NvOSD_FrameLineParams
 Holds information about the lines in a frame. More...
struct  _NvOSD_FrameArrowParams
 Holds information about the arrows in a frame. More...
struct  _NvOSD_FrameCircleParams
 Holds information about the circles in a frame. More...
Macros
#define NVOSD_PRINT_E(f_, ...)   printf("libnvosd (%d):(ERROR) : " f_, __LINE__, ##__VA_ARGS__)
#define MAX_IN_BUF   16
#define MAX_BORDER_WIDTH   32
Typedefs
typedef void * NvOSDCtxHandle
typedef struct _NvOSD_FrameTextParams NvOSD_FrameTextParams
typedef struct _NvOSD_FrameRectParams NvOSD_FrameRectParams
typedef struct _NvOSD_FrameSegmentMaskParams NvOSD_FrameSegmentMaskParams
typedef struct _NvOSD_FrameLineParams NvOSD_FrameLineParams
typedef struct _NvOSD_FrameArrowParams NvOSD_FrameArrowParams
typedef struct _NvOSD_FrameCircleParams NvOSD_FrameCircleParams
Functions
NvOSDCtxHandle nvll_osd_create_context (void)
 Creates an NvOSD context. More...
void nvll_osd_destroy_context (NvOSDCtxHandle nvosd_ctx)
 Destroys an NvOSD context. More...
void nvll_osd_set_clock_params (NvOSDCtxHandle nvosd_ctx, NvOSD_TextParams *clk_params)
 Sets clock parameters for a given context. More...
int nvll_osd_put_text (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameTextParams *frame_text_params)
 /brief Overlays clock and given text at a given location in a buffer. More...
int nvll_osd_draw_segment_masks (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameSegmentMaskParams *frame_mask_params)
 Overlays segment masks at a given location in a buffer. More...
int nvll_osd_draw_rectangles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameRectParams *frame_rect_params)
 Overlays boxes at a given location in a buffer. More...
int nvll_osd_draw_lines (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameLineParams *frame_line_params)
 Overlays lines on the buffer. More...
int nvll_osd_draw_arrows (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameArrowParams *frame_arrow_params)
 Overlays arrows on the buffer. More...
int nvll_osd_draw_circles (NvOSDCtxHandle nvosd_ctx, NvOSD_FrameCircleParams *frame_circle_params)
 Overlays circles on the buffer. More...
void * nvll_osd_set_params (NvOSDCtxHandle nvosd_ctx, int width, int height)
 Sets the resolution of the frames on which the NvOSDContext is to operate. More...
int nvll_osd_init_colors_for_hw_blend (void *nvosd_ctx, NvOSD_Color_info *color_info, int num_classes)
 Initializes colors for HW based blending. More...
int nvll_osd_apply (NvOSDCtxHandle nvosd_ctx, NvBufSurfaceParams *buf_ptr, NvBufSurface *surf)
 Apply OSD to the video frame for GPU backend. More...
◆ MAX_BORDER_WIDTH
Definition at line 44 of file nvll_osd_api.h.
◆ MAX_IN_BUF
Definition at line 43 of file nvll_osd_api.h.
◆ NVOSD_PRINT_E
#define NVOSD_PRINT_E (   f_,
Definition at line 40 of file nvll_osd_api.h.
Typedef Documentation
◆ NvOSD_FrameArrowParams
◆ NvOSD_FrameCircleParams
◆ NvOSD_FrameLineParams
◆ NvOSD_FrameRectParams
◆ NvOSD_FrameSegmentMaskParams
◆ NvOSD_FrameTextParams
◆ NvOSDCtxHandle
typedef void* NvOSDCtxHandle
Definition at line 51 of file nvll_osd_api.h.
Function Documentation
◆ nvll_osd_apply()
int nvll_osd_apply ( NvOSDCtxHandle  nvosd_ctx,
NvBufSurfaceParams buf_ptr,
NvBufSurface surf
Parameters
[in]nvosd_ctxA handle for the NvOSD context.
[in]buf_ptrSurface which the OSD apply. This is now deprecated. 'NvBufSurface *surf' is used instead.
[in]surfHolds information of batched buffer
◆ nvll_osd_create_context()
NvOSDCtxHandle nvll_osd_create_context ( void  )
Returns
A handle for an NvOSD context if successful, or NULL otherwise.
◆ nvll_osd_destroy_context()
void nvll_osd_destroy_context ( NvOSDCtxHandle  nvosd_ctx)
Parameters
[in]nvosd_ctxA handle for the NvOSD context to be destroyed.
◆ nvll_osd_draw_arrows()
int nvll_osd_draw_arrows ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_FrameArrowParams frame_arrow_params
The length of arrow_params_list must equal num_arrows. The client is responsible for allocating this array.
Note
Currently only MODE_CPU is supported. Specifying other modes has no effect.
Parameters
[in]nvosd_ctxA handle for an NvOSD context.
[in]frame_arrow_paramsA pointer to the FrameArrowParams struct containing arrow information to be overlayed.
Returns
0 if successful, or -1 otherwise.
◆ nvll_osd_draw_circles()
int nvll_osd_draw_circles ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_FrameCircleParams frame_circle_params
You must ensure that the length of circle_params_list equals num_circles.
Note
Parameters
[in]frame_circle_paramsA pointer to the FrameCircleParams struct containing circle information to be overlayed.
Returns
◆ nvll_osd_draw_lines()
int nvll_osd_draw_lines ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_FrameLineParams frame_line_params
The length of line_params_list must be equal to num_lines. The client is responsible for allocating this array.
Note
Currently only MODE_CPU is supported. Specifying other modes will have no effect.
Parameters
[in]frame_line_paramsA pointer to the FrameLineParams struct containing line information to be overlayed.
Returns
◆ nvll_osd_draw_rectangles()
int nvll_osd_draw_rectangles ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_FrameRectParams frame_rect_params
Boxes can be configured with: a. Border only: Uou must set border_width and set has_bg_color to 0 for the given box. b. Border and background color To draw boxes with border and background color, you must set border_width and set has_bg_color to 1, and specify background color parameters for the given box. c. Solid fill acting as mask region To draw boxes with solid fill acting as mask region, you must set border_width to 0 and has_bg_color to 1 for the given box.
You must ensure that the length of rect_params_list is at least num_rects.
Parameters
[in]frame_rect_paramsA pointer to the FrameRectParams struct containing rectangles information to be overlayed.
Returns
0 for success, -1 for failure.
◆ nvll_osd_draw_segment_masks()
int nvll_osd_draw_segment_masks ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_FrameSegmentMaskParams frame_mask_params
You must ensure that the length of mask_params_list is at least num_segments.
Parameters
[in]frame_mask_paramsA pointer to the FrameSegmentMaskParams struct containing mask information to be overlayed.
Returns
◆ nvll_osd_init_colors_for_hw_blend()
int nvll_osd_init_colors_for_hw_blend ( void *  nvosd_ctx,
NvOSD_Color_info color_info,
int  num_classes
Applicable ONLY for Jetson.
Parameters
[in]nvosd_ctxA pointer to NvOSD context.
[in]color_infoA pointer to the Color_info struct containing color information.
[in]num_classesNumber of classes.
Returns
A pointer to the internally allocated Host Memory.
◆ nvll_osd_put_text()
int nvll_osd_put_text ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_FrameTextParams frame_text_params
To overlay the clock, you must call nvll_osd_set_clock_params(). You must also ensure that the length of text_params_list is at least NvOSD_FrameTextParams::num_strings.
Note
Currently only the NvOSD_Mode value MODE_CPU is supported. Specifying other modes has no effect.
Parameters
[in]frame_text_paramsA pointer to a structure containing information about rectangles to be overlayed.
Returns
0 for success, or -1 for failure.
◆ nvll_osd_set_clock_params()
void nvll_osd_set_clock_params ( NvOSDCtxHandle  nvosd_ctx,
NvOSD_TextParams clk_params
The clock is overlayed when nvll_osd_put_text() is called. If no other text is to be overlayed, nvll_osd_put_text() must be called with num_strings as 0 and text_params_list as NULL.
Parameters
[in]clk_paramsA pointer to a structure for the clock to be overlayed; NULL to disable the clock.
◆ nvll_osd_set_params()
void* nvll_osd_set_params ( NvOSDCtxHandle  nvosd_ctx,
int  width,
int  height
Parameters
[in]widthWidth of the input frames.
[in]heightHeight of the input frames.
Returns
