Train with Async GRPO#
Async GRPO is an asynchronous training mode that allows trajectory generation and policy training to run concurrently, improving GPU utilization and throughput compared to synchronous GRPO.
Configure Async GRPO#
This section covers how to configure async GRPO by modifying your settings and includes a complete example configuration.
Enable Async GRPO#
To use async GRPO, make these configuration changes:
Enable vLLM async engine:
policy:
generation:
backend: "vllm"
vllm_cfg:
async_engine: true
Enable importance sampling correction (required for convergence):
loss_fn:
use_importance_sampling_correction: true
Disable colocated inference (required for async mode):
policy:
generation:
colocated:
enabled: false
resources:
num_nodes: 1 # or more
gpus_per_node: 2 # adjust based on your setup
Add async GRPO configuration:
grpo:
async_grpo:
enabled: true
max_trajectory_age_steps: 1 # Maximum age, in training steps, for trajectories
in_flight_weight_updates: false # Enable for faster weight synchronization
recompute_kv_cache_after_weight_updates: false # Invalidates kv cache after in-flight-weight-updates
Complete Example Config#
policy:
generation:
backend: "vllm"
colocated:
enabled: false
resources:
num_nodes: 1
gpus_per_node: 2
vllm_cfg:
async_engine: true
loss_fn:
grpo:
num_prompts_per_step: 32
num_generations_per_prompt: 4
async_grpo:
enabled: true
cluster:
num_nodes: 2
gpus_per_node: 4
Implementation Structure#
This section covers the internal architecture of async GRPO and includes detailed explanations of how the core components interact.
Core Components#
The async GRPO implementation consists of three main components:
1. Main Training Loop (async_grpo_train in grpo.py)#
Coordinates overall training process
Samples trajectories from replay buffer
Runs policy training steps
Handles validation and checkpointing
Manages weight synchronization between training and generation
2. Async Trajectory Collector (AsyncTrajectoryCollector in async_utils.py)#
Runs in background Ray actor
Continuously generates trajectories using current policy weights
Manages generation scheduling and weight version tracking
Handles pause/resume for weight updates and validation
Coordinates with replay buffer for trajectory storage
3. Replay Buffer (ReplayBuffer in async_utils.py)#
Stores generated trajectories with metadata
Tracks weight versions for both generation and intended training use
Implements age-based filtering to prevent stale trajectories
Provides sampling interface for training steps
Weight Version Tracking#
Async GRPO uses a weight versioning system:
Generation Weight Version: The policy weights used to generate a trajectory
Target Weight Version: The training step where the trajectory will be used
Max Trajectory Age: How many steps old a trajectory can be before being discarded
Example with max_trajectory_age_steps: 1:
Trajectory generated with weights v10 can be used for training steps v10 or v11
At training step v12, trajectories from v10 are too old and discarded
Coordination Flow#
Startup: Trajectory collector starts generating trajectories in background
Buffer Fill: Training waits until buffer has sufficient trajectories
Training Step:
Sample trajectories from buffer
Run policy training
Update weights and notify collector
Weight Sync: Collector pauses, waits for weight refit, then resumes
Repeat: Process continues with updated weights
Architecture Diagram#
The following sequence diagram illustrates the interactions between the three main components:
sequenceDiagram
participant Training as Training Loop
participant Collector as Trajectory Collector
participant Buffer as Replay Buffer
Note over Training, Buffer: Startup
Training->>Collector: Start generation
Training->>Buffer: Initialize
Note over Training, Buffer: Main Loop
loop Async Training
par Background Generation
Collector->>Buffer: Store trajectories
and Training Steps
Training->>Buffer: Sample trajectories
Buffer-->>Training: Return valid data
Training->>Training: Update policy weights
Training->>Collector: Sync new weights
end
end
Usage Tips#
Buffer Sizing: The replay buffer size is automatically calculated as:
buffer_size = num_prompts_per_step × max_trajectory_age_steps × 2
Age Limits: Start with
max_trajectory_age_steps: 1and increase if needed for higher throughputResource Allocation: Ensure sufficient GPU memory for both the training and generation clusters
In-Flight Weight Updates: Enable
in_flight_weight_updates: truewhen usingasync_engine: truefor updating the weights of vLLM engine during generation. This prevents stalling training pipeline until longest generation finishes and provides significant performance benefits.Recompute KV Cache After Weight Updates: While using in-flight weight update, user can choose whether to recompute KV caches after weight udpate by configuring
recompute_kv_cache_after_weight_updateconfiguration.
Why Importance Sampling Correction Is Required for Async#
The GRPO Objective#
The standard GRPO loss function (without KL penalty) is:
where:
\(\pi_\theta\) is the policy model we are currently optimizing
\(\pi_{\theta_{\text{old}}}\) is the previous policy model (from the beginning of this step)
\(A_t\) is the advantage estimate
\(\varepsilon\) is a clipping hyperparameter
In standard GRPO, we assume trajectories are sampled from \(\pi_{\theta_{\text{old}}}\). However, in async GRPO, trajectories are actually sampled from \(\pi_{\theta_{\text{generator}}}\), which is the policy weights from N training steps ago (where N ≥ 1 depending on max_trajectory_age_steps).
Without importance sampling correction, the GRPO objective becomes fundamentally incorrect:
Incorrect probability ratios: The ratio \(\frac{\pi_\theta(x)}{\pi_{\theta_{\text{old}}}(x)}\) uses \(\pi_{\theta_{\text{old}}}\) probabilities that were never actually used to generate the trajectories.
Biased gradient estimates: Since we’re computing gradients based on samples from the wrong distribution, the policy updates become biased and can lead to instability.
When we enable importance sampling correction (use_importance_sampling_correction: true), we introduce the corrective term:
This transforms our loss function to properly account for the distribution mismatch. The corrected objective becomes:
The importance sampling ratio \(\frac{\pi_{\text{training}}(x)}{\pi_{\text{generator}}(x)}\) is effectively \(\frac{\pi_{\theta_{\text{old}}}(x)}{\pi_{\theta_{\text{generator}}}(x)}\), which corrects for the N-step gap between the generator policy and the policy we assume we’re sampling from.
This correction ensures that we have unbiased gradient estimates and stable convergence.
