Experiment with Custom vLLM#
This guide explains how to use your own version of vLLM while leveraging a pre-compiled vLLM wheel, so you don’t have to recompile the C++ source code.
Clone and Build Your Custom vLLM#
Clone your vLLM fork and build it using the provided script. For example:
# Usage: bash tools/build-custom-vllm.sh <GIT_URL> <GIT_REF> <VLLM_WHEEL_COMMIT>
bash tools/build-custom-vllm.sh https://github.com/terrykong/vllm.git terryk/demo-custom-vllm d8ee5a2ca4c73f2ce5fdc386ce5b4ef3b6e6ae70
# [INFO] pyproject.toml updated. NeMo RL is now configured to use the local vLLM at 3rdparty/vllm.
# [INFO] Verify this new vllm version by running:
# VLLM_PRECOMPILED_WHEEL_LOCATION=http://.....whl \
# uv run --extra vllm vllm serve Qwen/Qwen3-0.6B
# [INFO] For more information on this custom install, visit https://github.com/NVIDIA-NeMo/RL/blob/main/docs/guides/use-custom-vllm.md
# [IMPORTANT] Remember to set the shell variable 'VLLM_PRECOMPILED_WHEEL_LOCATION' when running NeMo RL apps with this custom vLLM to avoid re-compiling.
This script does the following:
Clones the
vllmyou specify at a particular branch.Builds
vllm.Updates NeMo RL’s pyproject.toml to work with this
vllm.Updates
uv.lock.
Make sure to add the updated pyproject.toml and uv.lock to version control so that your branch can be reproduced by others.
Verify Your Custom vLLM in Isolation#
Test your setup to ensure your custom vLLM is being used:
uv run --extra vllm python -c 'import vllm; print(f"Successfully imported vLLM version: {vllm.__version__}")'
# Uninstalled 1 package in 1ms
# Installed 1 package in 2ms
# Hi! If you see this, you're using a custom version of vLLM for the purposes of this tutorial
# INFO 06-18 09:22:44 [__init__.py:244] Automatically detected platform cuda.
# Successfully imported vLLM version: 0.0.1.dev1+g69d5add74.d20250910
If you don’t see the log message Hi! If you see this..., it’s because this message is unique to the tutorial’s specific vLLM fork. It was added in this commit and doesn’t exist in the main vLLM project.
Running NeMo RL Apps with Custom vLLM#
To ensure the custom vLLM install is setup properly in NeMo RL applications, always run the following before anything:
# Ensures vLLM uses the precompiled wheel and avoids recompiling C++ sources
export VLLM_PRECOMPILED_WHEEL_LOCATION=https://wheels.vllm.ai/d8ee5a2ca4c73f2ce5fdc386ce5b4ef3b6e6ae70/vllm-1.0.0.dev-cp38-abi3-manylinux1_x86_64.whl
# Ensures worker venvs are rebuilt to use the custom vLLM. Otherwise it may use the cached version in cached venvs
export NRL_FORCE_REBUILD_VENVS=true
# This isn't necessary if you only do `uv run foobar.py`, but may be needed if you switching between optional extras `uv run --extra vllm foobar.py`. If you are unsure if you need this, it's safer to include it.
uv pip install setuptools_scm
Then run your application:
uv run examples/run_grpo_math.py
Re-building the NeMo RL Docker Image#
Using a custom vllm may require you to rebuild the docker image. The two most common reasons are:
The
rayversion was changed, so you must rebuild the image to allowray.subto start the ray cluster with the same version as the application.Many dependencies changed and add a large overhead when
NRL_FORCE_REBUILD_VENVS=trueis set to rebuild venvs, so you wish to cache the dependencies in the image to avoid re-build/re-pulling wheels.
For convenience, you can have the image build your custom vLLM by running the same script inside the Docker build.
Pass --build-arg BUILD_CUSTOM_VLLM=1 to enable this path; the build will create 3rdparty/vllm and source 3rdparty/vllm/nemo-rl.env automatically.
docker buildx build \
--build-arg BUILD_CUSTOM_VLLM=1 \
--target release \
--build-context nemo-rl=. \
-f docker/Dockerfile \
--tag <registry>/nemo-rl:latest \
--push \
SSH Setup for Private Repositories#
If your custom vLLM is hosted in a private repository (e.g., internal GitLab), you need to set up SSH agent forwarding for Docker to clone it during the build.
Prerequisites#
Your SSH key must be registered on the Git server (GitLab/GitHub)
The key must not be expired - check your Git server’s SSH key settings
The key must be loaded into your local ssh-agent
Step 1: Verify your SSH key works#
# For GitLab (adjust host/port as needed)
ssh -T git@gitlab.example.com -p 12051
# You should see: "Welcome to GitLab, @username!"
# If you see "Your SSH key has expired", renew it on the server
Step 2: Load your SSH key into the agent#
# Check if an ssh-agent is already running
echo $SSH_AUTH_SOCK
# If empty, start one (this also sets SSH_AUTH_SOCK which `docker buildx` expects to be set when using `--ssh default`)
eval "$(ssh-agent -s)"
# Clear any old/expired keys from the agent
ssh-add -D
# Add your SSH key (use the key registered on your Git server)
ssh-add ~/.ssh/id_ed25519
# Verify it's loaded
ssh-add -l
Step 3: Run the Docker build with SSH forwarding#
--target release \
--ssh default \
--push \
Running Applications with a Custom vLLM Container#
When using a container built with custom vLLM, use the frozen environment workflow (bare python) instead of uv run with NRL_FORCE_REBUILD_VENVS=true.
# Recommended: use bare python (frozen environment)
python examples/run_grpo_math.py
# NOT recommended with custom vLLM containers:
# uv run examples/run_grpo_math.py
# or
# NRL_FORCE_REBUILD_VENVS=true uv run examples/run_grpo_math.py
Why Not Use uv run or Rebuild Venvs?#
Rebuilding worker virtual environments (via uv run or NRL_FORCE_REBUILD_VENVS=true) requires having the custom vLLM compiled locally. However, compiling vLLM requires a container environment with the correct CUDA toolchain—creating a chicken-and-egg problem.
The container already has vLLM built and cached in the frozen environments. Using bare python leverages these pre-built environments directly, avoiding the need to recompile vLLM at runtime.
Tip
For more details on frozen environments and how they differ from uv run, see the Dependency Management documentation.
