8.0 Release
13 #ifndef _GST_NVDSCOMMON_CONFIG_H_
14 #define _GST_NVDSCOMMON_CONFIG_H_
153 gint pipeline_height;
154 gint batched_push_timeout;
160 gint buffer_pool_size;
162 gint num_surfaces_per_frame;
163 gint interpolation_method;
165 guint nvbuf_memory_type;
166 gboolean live_source;
167 gboolean enable_padding;
168 gboolean attach_sys_ts_as_ntp;
169 gchar* config_file_path;
170 gboolean sync_inputs;
172 gboolean frame_num_reset_on_eos;
173 gboolean frame_num_reset_on_stream_reset;
175 guint64 frame_duration;
177 gboolean async_process;
178 gboolean no_pipeline_eos;
179 gboolean extract_sei_type5_data;
181 gboolean buffer_cache;
182 gint buffer_cache_timeout;
183 gboolean extract_sei_sim_time;
184 gboolean align_first_buffer;
185 guint sync_inputs_ntp;
186 gboolean drop_backward_sei;
NvDsUriSrcBinSRCont smart_rec_container
struct _GstDsNvUriSrcConfig GstDsNvUriSrcConfig
NvDsUriSrcBinDecSkipFrame
struct _NvDsRtspAttemptsInfo NvDsRtspAttemptsInfo
NvDsUriSrcBinType src_type
gboolean enable_error_propagation
NvDsUriSrcBinSRType smart_record
guint simulate_fps_interval_ms
guint64 creation_time_ns
Stream creation time in nanoseconds since epoch (from ISO 8601 timestamp)
guint64 ipc_connection_interval
NvDsUriSrcBinBufferMode buffer_mode
gboolean disable_passthrough
gchar * sensorId
unique Sensor ID string
gchar * smart_rec_file_prefix
gchar const * sensor_name
@ DEC_SKIP_FRAMES_TYPE_KEY_FRAME_ONLY
gint rtsp_reconnect_interval_sec_org
guint drop_frame_interval
gchar * sensorName
Sensor Name string; could be NULL.
guint smart_rec_def_duration
guint smart_rec_cache_size
gboolean low_latency_mode
gchar * smart_rec_dir_path
@ DEC_SKIP_FRAMES_TYPE_NONE
struct _NvDsSensorInfo NvDsSensorInfo
NvDsUriSrcBinSRMode smart_rec_mode
@ RTP_PROTOCOL_UDP_UDPMCAST_TCP
NvDsUriSrcBinRtpProtocol rtp_protocol
@ DEC_SKIP_FRAMES_TYPE_NONREF
NvDsUriSrcBinDecSkipFrame skip_frames_type
gint ipc_connection_attempts
gboolean sensorIdToPadIdMapping
gboolean ipc_buffer_timestamp_copy
gint rtsp_reconnect_attempts
gboolean attempt_exceeded
gint init_rtsp_reconnect_interval_sec
