8.0 Release
9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h File Reference
Data Structures
struct  nvdsinfer::NvDsInferBatch
 Holds information for one batch for processing. More...
class  nvdsinfer::InferPreprocessor
 Provides pre-processing functionality like mean subtraction and normalization. More...
class  nvdsinfer::InferPostprocessor
 Base class for post-processing on inference output. More...
class  nvdsinfer::DetectPostprocessor
 Implementation of post-processing class for object detection networks. More...
class  nvdsinfer::InstanceSegmentPostprocessor
 Implementation of post-processing class for instance segmentation networks. More...
class  nvdsinfer::ClassifyPostprocessor
 Implementation of post-processing class for classification networks. More...
class  nvdsinfer::SegmentPostprocessor
 Implementation of post-processing class for segmentation networks. More...
class  nvdsinfer::OtherPostprocessor
class  nvdsinfer::NvDsInferContextImpl
 Implementation of the INvDsInferContext interface. More...
Namespaces
 nvdsinfer
Macros
#define printMsg(level, tag_str, fmt, ...)
#define printError(fmt, ...)
#define printWarning(fmt, ...)
#define printInfo(fmt, ...)
#define printDebug(fmt, ...)
◆ printDebug
#define printDebug (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_DEBUG, "DEBUG", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 542 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
◆ printError
#define printError (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_ERROR, "Error in", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 527 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
◆ printInfo
#define printInfo (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_INFO, "Info from", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 537 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
◆ printMsg
#define printMsg (   level,
  tag_str,
  fmt,
Value:
do { \
char* baseName = strrchr((char*)__FILE__, '/'); \
baseName = (baseName) ? (baseName + 1) : (char*)__FILE__; \
char logMsgBuffer[5 * _MAX_STR_LENGTH + 1]; \
snprintf(logMsgBuffer, 5 * _MAX_STR_LENGTH, \
tag_str " NvDsInferContextImpl::%s() <%s:%d> [UID = %d]: " fmt, \
__func__, baseName, __LINE__, m_UniqueID, ##__VA_ARGS__); \
if (m_LoggingFunc) { \
m_LoggingFunc(level, logMsgBuffer); \
} else { \
fprintf(stderr, "%s\n", logMsgBuffer); \
} while (0)
Definition at line 512 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
◆ printWarning
#define printWarning (   fmt,
Value:
do { \
printMsg (NVDSINFER_LOG_WARNING, "Warning from", fmt, ##__VA_ARGS__); \
} while (0)
Definition at line 532 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
_MAX_STR_LENGTH
#define _MAX_STR_LENGTH
Definition: sources/apps/apps-common/includes/deepstream_config_yaml.h:45
NVDSINFER_LOG_ERROR
@ NVDSINFER_LOG_ERROR
Definition: sources/includes/nvdsinfer.h:258
NVDSINFER_LOG_INFO
@ NVDSINFER_LOG_INFO
Definition: sources/includes/nvdsinfer.h:260
@ NVDSINFER_LOG_WARNING
Definition: sources/includes/nvdsinfer.h:259
NVDSINFER_LOG_DEBUG
@ NVDSINFER_LOG_DEBUG
Definition: sources/includes/nvdsinfer.h:261
