Implementation of post-processing class for object detection networks.
Definition at line 207 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Public Member Functions | |
| DetectPostprocessor (int id, int gpuId=0) | |
| ~DetectPostprocessor () override=default | |
| NvDsInferStatus | initResource (const NvDsInferContextInitParams &initParams) override |
| void | setDlHandle (const std::shared_ptr< DlLibHandle > &dlHandle) |
| void | setNetworkInfo (const NvDsInferNetworkInfo &info) |
| void | setAllLayerInfo (std::vector< NvDsInferBatchDimsLayerInfo > &info) |
| void | setOutputLayerInfo (std::vector< NvDsInferBatchDimsLayerInfo > &info) |
| void | setLoggingFunc (const NvDsInferLoggingFunc &func) |
| const std::vector< std::vector< std::string > > & | getLabels () const |
| bool | needInputCopy () const |
| bool | needOutputCopyB4Processing () const |
| virtual NvDsInferStatus | copyBuffersToHostMemory (NvDsInferBatch &buffer, CudaStream &mainStream) |
| virtual NvDsInferStatus | postProcessHost (NvDsInferBatch &buffer, NvDsInferContextBatchOutput &output) |
| void | freeBatchOutput (NvDsInferContextBatchOutput &batchOutput) |
Protected Member Functions | |
| NvDsInferStatus | parseLabelsFile (const std::string &path) |
| NvDsInferStatus | allocDeviceResource () |
| void | releaseFrameOutput (NvDsInferFrameOutput &frameOutput) |
Protected Attributes | |
| NvDsInferNetworkType | m_NetworkType = NvDsInferNetworkType_Other |
| int | m_UniqueID = 0 |
| uint32_t | m_GpuID = 0 |
| NvDsInferLoggingFunc | m_LoggingFunc |
| std::shared_ptr< DlLibHandle > | m_CustomLibHandle |
| bool | m_CopyInputToHostBuffers = false |
| bool | m_disableOutputHostCopy = false |
| bool | m_DumpOpTensor = false |
| std::vector< std::pair< std::string, std::string > > | m_DumpOpTensorFiles |
| bool | m_OverwriteOpTensor = false |
| std::vector< std::pair< std::string, int > > | m_OverwriteOpTensorFilePairs |
| std::vector< std::ifstream * > | m_OverwriteOpTensorFiles |
| NvDsInferNetworkInfo | m_NetworkInfo = {0} |
| std::vector< NvDsInferLayerInfo > | m_AllLayerInfo |
| std::vector< NvDsInferLayerInfo > | m_OutputLayerInfo |
| std::vector< std::vector< std::string > > | m_Labels |
inline |
Definition at line 210 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
overridedefault |
inline |
Definition at line 210 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
overridedefault |
protectedinherited |
virtualinherited |
virtualinherited |
inherited |
inherited |
inlineinherited |
Definition at line 146 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_Labels.
inlineinherited |
Definition at line 146 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
overridevirtual |
Reimplemented from nvdsinfer::InferPostprocessor.
overridevirtual |
inlineinherited |
Definition at line 150 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_CopyInputToHostBuffers.
inlineinherited |
Definition at line 150 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
inlineinherited |
Definition at line 152 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_disableOutputHostCopy.
inlineinherited |
Definition at line 152 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
virtualinherited |
virtualinherited |
inlineinherited |
Definition at line 132 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_AllLayerInfo.
inlineinherited |
Definition at line 132 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
inlineinherited |
Definition at line 124 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_CustomLibHandle.
inlineinherited |
Definition at line 124 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
inlineinherited |
Definition at line 142 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_LoggingFunc.
inlineinherited |
Definition at line 142 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
inlineinherited |
Definition at line 128 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_NetworkInfo.
inlineinherited |
Definition at line 128 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
inlineinherited |
Definition at line 137 of file 9.0/sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
References nvdsinfer::InferPostprocessor::m_OutputLayerInfo.
inlineinherited |
Definition at line 137 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 199 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::setAllLayerInfo().
Definition at line 190 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::needInputCopy().
Definition at line 189 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::setDlHandle().
Definition at line 191 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::needOutputCopyB4Processing().
Definition at line 192 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 193 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 185 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 203 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::getLabels().
Definition at line 186 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::setLoggingFunc().
Definition at line 198 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::setNetworkInfo().
Definition at line 182 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 200 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Referenced by nvdsinfer::InferPostprocessor::setOutputLayerInfo().
Definition at line 194 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 195 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 196 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
Definition at line 184 of file sources/libs/nvdsinfer/nvdsinfer_context_impl.h.
