sources/apps/apps-common/includes/deepstream_config_yaml.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2022-2026 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef _NVGSTDS_STREAMMUX_YAML_H_
14 #define _NVGSTDS_STREAMMUX_YAML_H_
15
16
17 #pragma GCC diagnostic push
18 #pragma GCC diagnostic ignored "-Wreturn-type"
19 #include <yaml-cpp/yaml.h>
20 #pragma GCC diagnostic pop
21
22 #include <gst/gst.h>
23
24 #ifdef __cplusplus
25 extern "C"
26 {
27 #endif
28
29 #include "deepstream_streammux.h"
31 #include "deepstream_osd.h"
32 #include "deepstream_segvisual.h"
33 #include "deepstream_image_save.h"
34 #include "deepstream_c2d_msg.h"
35 #include "deepstream_sinks.h"
36 #include "deepstream_sources.h"
37 #include "deepstream_tracker.h"
38 #include "deepstream_replay.h"
39 #include "deepstream_gie.h"
40 #include "deepstream_preprocess.h"
41 #include "deepstream_dewarper.h"
42 #include "deepstream_dsanalytics.h"
43 #include "deepstream_dsexample.h"
44
45 #define _MAX_STR_LENGTH 1024
46
47 std::vector<std::string> split_string (std::string input);
48
49 gboolean
51  const gchar * cfg_file_path, const gchar * file_path,
52  char *abs_path_str);
53
54 gboolean
55 parse_streammux_yaml (NvDsStreammuxConfig *config, gchar *cfg_file_path);
56
57 gboolean
58 parse_tiled_display_yaml (NvDsTiledDisplayConfig *config, gchar *cfg_file_path);
59
60 gboolean
61 parse_osd_yaml (NvDsOSDConfig *config, gchar *cfg_file_path);
62
63 gboolean
64 parse_segvisual_yaml (NvDsSegVisualConfig *config, gchar *cfg_file_path);
65
66 gboolean
67 parse_image_save_yaml (NvDsImageSave *config, gchar *cfg_file_path);
68
69 gboolean
70 parse_msgconsumer_yaml (NvDsMsgConsumerConfig *config, std::string group, gchar *cfg_file_path);
71
72 gboolean
73 parse_msgconv_yaml (NvDsSinkMsgConvBrokerConfig *config, std::string group, gchar *cfg_file_path);
74
75 gboolean
76 parse_sink_yaml (NvDsSinkSubBinConfig *config, std::string group, gchar * cfg_file_path);
77
78 gboolean
79 parse_source_yaml (NvDsSourceConfig *config, std::vector<std::string> headers,
80  std::vector<std::string> source_values, gchar *cfg_file_path);
81
82 gboolean
83 parse_tracker_yaml (NvDsTrackerConfig *config, gchar *cfg_file_path);
84
85 gboolean
86 parse_replay_yaml (NvDsReplayConfig *config, gchar *cfg_file_path);
87
88 gboolean
89 parse_gie_yaml (NvDsGieConfig *config, std::string group, gchar *cfg_file_path);
90
91 gboolean
92 parse_preprocess_yaml (NvDsPreProcessConfig *config, gchar* cfg_file_path);
93
94 gboolean
95 parse_dewarper_yaml (NvDsDewarperConfig * config, std::string group_str, gchar *cfg_file_path);
96
97 gboolean
98 parse_dsexample_yaml (NvDsDsExampleConfig *config, gchar *cfg_file_path);
99
100 gboolean
101 parse_dsanalytics_yaml (NvDsDsAnalyticsConfig *config, gchar* cfg_file_path);
102
103 #ifdef __cplusplus
104 }
105 #endif
106
107 #endif /* _NVGSTDS_DSEXAMPLE_H_ */
gboolean parse_dsanalytics_yaml(NvDsDsAnalyticsConfig *config, gchar *cfg_file_path)
deepstream_gie.h
deepstream_replay.h
gboolean parse_msgconsumer_yaml(NvDsMsgConsumerConfig *config, std::string group, gchar *cfg_file_path)
Definition: sources/apps/apps-common/includes/deepstream_preprocess.h:23
deepstream_tiled_display.h
parse_osd_yaml
gboolean parse_osd_yaml(NvDsOSDConfig *config, gchar *cfg_file_path)
Definition: sources/apps/apps-common/includes/deepstream_sinks.h:131
gboolean parse_preprocess_yaml(NvDsPreProcessConfig *config, gchar *cfg_file_path)
gboolean parse_image_save_yaml(NvDsImageSave *config, gchar *cfg_file_path)
NvDsImageSave
Definition: sources/apps/apps-common/includes/deepstream_image_save.h:21
NvDsSegVisualConfig
Definition: sources/apps/apps-common/includes/deepstream_segvisual.h:33
NvDsDsExampleConfig
Definition: sources/apps/apps-common/includes/deepstream_dsexample.h:23
gboolean parse_tiled_display_yaml(NvDsTiledDisplayConfig *config, gchar *cfg_file_path)
Definition: sources/apps/apps-common/includes/deepstream_sinks.h:105
gboolean parse_dsexample_yaml(NvDsDsExampleConfig *config, gchar *cfg_file_path)
split_string
std::vector< std::string > split_string(std::string input)
Definition: sources/apps/apps-common/includes/deepstream_dsanalytics.h:23
parse_sink_yaml
gboolean parse_sink_yaml(NvDsSinkSubBinConfig *config, std::string group, gchar *cfg_file_path)
NvDsSourceConfig
Definition: sources/apps/apps-common/includes/deepstream_sources.h:38
parse_source_yaml
gboolean parse_source_yaml(NvDsSourceConfig *config, std::vector< std::string > headers, std::vector< std::string > source_values, gchar *cfg_file_path)
parse_gie_yaml
gboolean parse_gie_yaml(NvDsGieConfig *config, std::string group, gchar *cfg_file_path)
Definition: sources/apps/apps-common/includes/deepstream_tiled_display.h:44
get_absolute_file_path_yaml
gboolean get_absolute_file_path_yaml(const gchar *cfg_file_path, const gchar *file_path, char *abs_path_str)
gboolean parse_streammux_yaml(NvDsStreammuxConfig *config, gchar *cfg_file_path)
NvDsStreammuxConfig
Definition: sources/apps/apps-common/includes/deepstream_streammux.h:23
deepstream_osd.h
gboolean parse_segvisual_yaml(NvDsSegVisualConfig *config, gchar *cfg_file_path)
deepstream_sinks.h
NvDsGieConfig
Definition: sources/apps/apps-common/includes/deepstream_gie.h:35
NvDsReplayConfig
Definition: sources/apps/apps-common/includes/deepstream_replay.h:25
parse_msgconv_yaml
gboolean parse_msgconv_yaml(NvDsSinkMsgConvBrokerConfig *config, std::string group, gchar *cfg_file_path)
NvDsTrackerConfig
Definition: sources/apps/apps-common/includes/deepstream_tracker.h:25
Definition: sources/apps/apps-common/includes/deepstream_c2d_msg.h:36
parse_replay_yaml
gboolean parse_replay_yaml(NvDsReplayConfig *config, gchar *cfg_file_path)
NvDsOSDConfig
Definition: sources/apps/apps-common/includes/deepstream_osd.h:35
parse_dewarper_yaml
gboolean parse_dewarper_yaml(NvDsDewarperConfig *config, std::string group_str, gchar *cfg_file_path)
parse_tracker_yaml
gboolean parse_tracker_yaml(NvDsTrackerConfig *config, gchar *cfg_file_path)
NvDsDewarperConfig
Definition: sources/apps/apps-common/includes/deepstream_dewarper.h:35
