NvDsBatchBufferWrapper Class Referenceabstract
Inheritance diagram for NvDsBatchBufferWrapper:
Collaboration diagram for NvDsBatchBufferWrapper:
Public Member Functions
 NvDsBatchBufferWrapper (unsigned int size)
virtual ~NvDsBatchBufferWrapper ()
virtual unsigned int copy_buf (std::shared_ptr< BufferWrapper > buf, unsigned int pos)=0
 Copy input buffer (buf) to this NvDsBatchBufferWrapper. More...
virtual void copy_meta (unsigned int id, std::shared_ptr< BufferWrapper > src_buffer, unsigned int batch_id, unsigned int frame_number, unsigned int num_surfaces_per_frame, NvDsBatchMeta *dest_batch_meta, unsigned int source_id)
virtual void unref ()
virtual unsigned int copy (void *buf, unsigned int pos, unsigned int num_surfaces)
virtual bool push (SourcePad *pad, TimePoint play_start, NanoSecondsType accum_dur)
virtual bool push (SourcePad *pad, unsigned long pts)
Data Fields
unsigned int batch_size
void * batch
◆ NvDsBatchBufferWrapper() [1/2]
NvDsBatchBufferWrapper::NvDsBatchBufferWrapper ( unsigned int  size)
◆ ~NvDsBatchBufferWrapper() [1/2]
virtual NvDsBatchBufferWrapper::~NvDsBatchBufferWrapper ( )
virtual
◆ NvDsBatchBufferWrapper() [2/2]
◆ ~NvDsBatchBufferWrapper() [2/2]
virtual
Member Function Documentation
◆ copy() [1/2]
virtual unsigned int BatchBufferWrapper::copy ( void *  buf,
unsigned int  pos,
inlinevirtualinherited
◆ copy() [2/2]
unsigned int  pos,
◆ copy_buf() [1/2]
virtual unsigned int NvDsBatchBufferWrapper::copy_buf ( std::shared_ptr< BufferWrapper buf,
unsigned int  pos
pure virtual
Parameters
buf[IN] BufferWrapper object with a streammux input buffer
pos[IN] The index at which the input buf is copied to the output NvBufSurface->surfaceList[] for video;
Implemented in GstBatchBufferWrapper, GstBatchBufferWrapper, GstAudioBatchBufferWrapper, and GstAudioBatchBufferWrapper.
◆ copy_buf() [2/2]
unsigned int  pos
pure virtual
Parameters
◆ copy_meta() [1/2]
virtual void NvDsBatchBufferWrapper::copy_meta ( unsigned int  id,
std::shared_ptr< BufferWrapper src_buffer,
NvDsBatchMeta dest_batch_meta,
inlinevirtual
◆ copy_meta() [2/2]
inlinevirtual
◆ push() [1/4]
virtual bool BatchBufferWrapper::push ( SourcePad pad,
◆ push() [2/4]
◆ push() [3/4]
unsigned long  pts
◆ push() [4/4]
unsigned long  pts
◆ unref() [1/2]
virtual void NvDsBatchBufferWrapper::unref ( )
inlinevirtual
◆ unref() [2/2]
inlinevirtual
Field Documentation
◆ batch
◆ batch_size
unsigned int NvDsBatchBufferWrapper::batch_size
