7.1 Release
GstBatchBufferWrapper Class Reference
TODO re-design GstBatchBufferWrapper to be video specific and NvDsBatchBufferWrapper generic ; Also rename the new data-structures according to the media they contain.
The GStreamer wrapper code for NvDsBatchBufferWrapper which represent one batched buffer. NOTE: None of the APIs in this class are thread-safe
Definition at line 127 of file gstnvstreammux_impl.h.
Inheritance diagram for GstBatchBufferWrapper:
Collaboration diagram for GstBatchBufferWrapper:
Public Member Functions
 GstBatchBufferWrapper (GstNvStreamMux *mux, unsigned int size, bool is_raw)
void unref () override
void reset_batch ()
void copy_meta (unsigned int id, std::shared_ptr< BufferWrapper > src_buffer, unsigned int batch_id, unsigned int frame_number, unsigned int num_surfaces_per_frame, NvDsBatchMeta *dest_batch_meta, unsigned int source_id) override
unsigned int copy_buf (std::shared_ptr< BufferWrapper > src, unsigned int pos) override
bool push (SourcePad *src_pad, TimePoint current_play_start, NanoSecondsType accum_dur) override
bool push (SourcePad *src_pad, unsigned long pts) override
void unref_gst_bufs ()
virtual unsigned int copy (void *buf, unsigned int pos, unsigned int num_surfaces)
Data Fields
GstBufferList * raw_batch
GstBuffergst_buffer
bool is_raw
GstNvStreamMuxmux
std::vector< std::shared_ptr< GstBufferWrapper > > gst_in_bufs
unsigned int batch_size
void * batch
◆ GstBatchBufferWrapper()
GstBatchBufferWrapper::GstBatchBufferWrapper ( GstNvStreamMux mux,
unsigned int  size,
bool  is_raw
inline
Member Function Documentation
◆ copy()
virtual unsigned int BatchBufferWrapper::copy ( void *  buf,
unsigned int  pos,
inlinevirtualinherited
Definition at line 96 of file nvstreammux_batch.h.
◆ copy_buf()
unsigned int GstBatchBufferWrapper::copy_buf ( std::shared_ptr< BufferWrapper src,
unsigned int  pos
overridevirtual
◆ copy_meta()
void GstBatchBufferWrapper::copy_meta ( unsigned int  id,
std::shared_ptr< BufferWrapper src_buffer,
NvDsBatchMeta dest_batch_meta,
overridevirtual
Reimplemented from NvDsBatchBufferWrapper.
◆ push() [1/2]
bool GstBatchBufferWrapper::push ( SourcePad src_pad,
overridevirtual
Reimplemented from BatchBufferWrapper.
◆ push() [2/2]
unsigned long  pts
overridevirtual
◆ reset_batch()
void GstBatchBufferWrapper::reset_batch ( )
◆ unref()
void GstBatchBufferWrapper::unref ( )
overridevirtual
◆ unref_gst_bufs()
void GstBatchBufferWrapper::unref_gst_bufs ( )
Referenced by mem_buf_unref_callback().
Field Documentation
◆ batch
void* BatchBufferWrapper::batch
inherited
◆ batch_size
unsigned int NvDsBatchBufferWrapper::batch_size
inherited
Definition at line 123 of file nvstreammux_batch.h.
◆ gst_buffer
GstBuffer* GstBatchBufferWrapper::gst_buffer
Definition at line 162 of file gstnvstreammux_impl.h.
Referenced by GstBatchBufferWrapper().
◆ gst_in_bufs
std::vector<std::shared_ptr<GstBufferWrapper> > GstBatchBufferWrapper::gst_in_bufs
Definition at line 165 of file gstnvstreammux_impl.h.
◆ is_raw
bool GstBatchBufferWrapper::is_raw
Definition at line 163 of file gstnvstreammux_impl.h.
◆ mux
GstNvStreamMux* GstBatchBufferWrapper::mux
Definition at line 164 of file gstnvstreammux_impl.h.
◆ raw_batch
GstBufferList* GstBatchBufferWrapper::raw_batch
Definition at line 161 of file gstnvstreammux_impl.h.
