deepstream::Pipeline Class Reference
Pipeline class definition.
Pipelie class provide the high level interface for most of the functionalities. It is recommended to use Pipeline API for creating applications unless there is some specific features that are only supported in lower level APIs from Element, Object, etc.
Definition at line 91 of file service-maker/includes/pipeline.hpp.
Inheritance diagram for deepstream::Pipeline:
Collaboration diagram for deepstream::Pipeline:
Data Structures
class  DynamicSourceMessage
 Pipeline message on source add/remove. More...
class  EOSMessage
 Pipeline message on EOS. More...
class  Message
 base class for pipeline message More...
class  StateTransitionMessage
 Pipeline message on state transition. More...
Public Types
enum  State {
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING,
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING
enum  State {
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING,
  INVALID,
  EMPTY,
  READY,
  PAUSED,
  PLAYING
Public Member Functions
 Pipeline (const char *name)
 Pipeline (const char *name, const std::string &config_file)
 Constructor with name and a description file. More...
virtual ~Pipeline ()
 Destructor. More...
template<typename... Args>
Pipelineadd (const std::string &element_type, const std::string &element_name, const Args &... args)
 Template function for creating and adding element with properties. More...
Pipelineadd (Element element)
 Add a given element to the pipeline. More...
Elementfind (const ::std::string &name)
 Find an element within the pipeline by name. More...
Elementoperator[] (const std::string &name)
 Operator for accessing elements in a pipeline. More...
Pipelinelink (std::pair< std::string, std::string > route, std::pair< std::string, std::string > tips)
 Link two elements within the pipeline. More...
Pipelinelink (const std::string &arg1, const std::string arg2, const Args &...args)
 Template function for linking elements in the simplest way. More...
Pipelineattach (const std::string &elmenent_name, CustomObject *object, const std::string tip="")
 Attach a custom object to an element within the pipeline. More...
Pipelineattach (const std::string &element_name, const std::string &plugin_name, const std::string &object_name, const std::string tip="")
 Create and attach a custom object to an element within the pipeline. More...
Pipelineattach (const std::string &element_name, const std::string &plugin_name, const std::string &object_name, const std::string tip, const Args &... args)
 Template function for creating and attaching custom object with properties. More...
Pipelineinstall (std::function< void(Pipeline &, int key)> keyboard_listener)
 install a callback to capture keyboard events More...
int prepare ()
 Intialize the pipeline. More...
int prepare (std::function< void(Pipeline &, const Message &)> listener)
 Intialize the pipeline with a callback to capture the messages. More...
Pipelinestart ()
 Start the pipeline. More...
Pipelinestart (std::function< void(Pipeline &, const Message &)> listener)
 Start the pipeline with a callback to capture the messages. More...
Pipelineactivate ()
 Start the pipeline after it is already intialized. More...
Pipelinewait ()
 Wait until the pipeline ends. More...
Pipelinestop ()
 Stop the pipeline. More...
bool isRunning () const
Pipelinepause ()
 Pause the pipeline. More...
Pipelineresume ()
 Resume the pipeline. More...
Pipelineseek (uint64_t timestamp)
 Seek to a specified position for processing data within the pipeline. More...
uint32_t startRTSP (uint16_t rtsp_port, uint16_t udp_port, uint32_t buffer_size=0)
 Start an RTSP server. More...
uint32_t startRecording (const std::string &element_name, uint32_t startTime=0, uint32_t duration=0, std::function< void(const RecordingInfo &)> callback=[](const RecordingInfo &info) { printf("\nSource recorded at %s/%s. Duration %.2f sec\n", info.getFileDirectory().c_str(), info.getFileName().c_str(), info.getDuration()/1000.0);}, void *userData=nullptr)
 Send Smart Record start signal to an nvurisrcbin element. More...
bool stopRecording (const std::string &element_name)
 Send Smart Record stop signal to an nvurisrcbin element. More...
bool stopRecording (uint32_t sessionId)
void handleKey (int key)
 Destructor. More...
int prepare ()
Pipelinestart ()
Pipelineactivate ()
Pipelinewait ()
Pipelinestop ()
Pipelinepause ()
Pipelineresume ()
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgive ()
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the object's type id. More...
Protected Member Functions
int run ()
int run_after_prepare ()
int run ()
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
void * loop_ = NULL
uint bus_watch_id_ = 0
void * bus_data_ = NULL
std::function< void(Pipeline &, int key)> keyboard_listener_
std::thread thread_
std::map< std::string, Elementelements_
std::map< std::string, std::unique_ptr< SignalEmitter > > action_owners_
uint64_t start_pts_ = 0
std::unordered_map< std::string, uint32_t > element_to_session_id
std::unordered_map< uint32_t, std::string > session_id_to_element
GstObjectobject_
Member Enumeration Documentation
◆ State [1/2]
Enumerator
INVALID
EMPTY
READY
PAUSED
PLAYING
INVALID
EMPTY
READY
PAUSED
PLAYING
Definition at line 94 of file service-maker/includes/pipeline.hpp.
◆ State [2/2]
Enumerator
INVALID
EMPTY
READY
PAUSED
PLAYING
INVALID
EMPTY
READY
PAUSED
PLAYING
Definition at line 94 of file 9.0/service-maker/includes/pipeline.hpp.
◆ Pipeline() [1/4]
deepstream::Pipeline::Pipeline ( const char *  name)
◆ Pipeline() [2/4]
deepstream::Pipeline::Pipeline ( const char *  name,
const std::string &  config_file
◆ ~Pipeline() [1/2]
virtual deepstream::Pipeline::~Pipeline ( )
virtual
Destructor.
◆ Pipeline() [3/4]
◆ Pipeline() [4/4]
◆ ~Pipeline() [2/2]
virtual
Destructor.
Member Function Documentation
◆ activate() [1/2]
Pipeline& deepstream::Pipeline::activate ( )
◆ activate() [2/2]
◆ add() [1/4]
Pipeline& deepstream::Pipeline::add ( const std::string &  element_type,
const std::string &  element_name,
inline
Definition at line 174 of file service-maker/includes/pipeline.hpp.
References deepstream::Object::Element, and deepstream::Object::set().
Referenced by add().
◆ add() [2/4]
inline
Definition at line 174 of file 9.0/service-maker/includes/pipeline.hpp.
References add(), deepstream::Object::Element, and deepstream::Object::set().
◆ add() [3/4]
Pipeline& deepstream::Pipeline::add ( Element  element)
◆ add() [4/4]
◆ attach() [1/6]
Pipeline& deepstream::Pipeline::attach ( const std::string &  element_name,
const std::string &  plugin_name,
const std::string &  object_name,
inline
Definition at line 251 of file service-maker/includes/pipeline.hpp.
References attach().
◆ attach() [2/6]
inline
Definition at line 251 of file 9.0/service-maker/includes/pipeline.hpp.
◆ attach() [3/6]
const std::string  tip = ""
Supported custom objects can be buffer probes, signal handlers The custom object will be created through factory
Parameters
[in]element_namename of the elment to which the object attaches
[in]plugin_namename of the plugin where the custom object factory is defined
[in]object_namename of the new custome object
[in]tipsextra information. pad name for buffer probes, signal name for signal handlers
◆ attach() [4/6]
Parameters
◆ attach() [5/6]
Pipeline& deepstream::Pipeline::attach ( const std::string &  elmenent_name,
CustomObject object,
Supported custom objects can be buffer probes, signal handlers Once the object is attached, the element takes the ownership of it
Parameters
[in]objectpointer to a custom object
◆ attach() [6/6]
Parameters
Referenced by attach().
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
inherited
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
inherited
Emit a signal.
◆ find() [1/2]
Element* deepstream::Pipeline::find ( const ::std::string &  name)
Referenced by operator[]().
◆ find() [2/2]
◆ get_() [1/2]
virtual Value deepstream::Object::get_ ( const std::string &  name)
protectedvirtualinherited
◆ get_() [2/2]
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file service-maker/includes/object.hpp.
References deepstream::Object::object_.
◆ getGObject() [2/2]
inlineinherited
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
inherited
◆ getName() [2/2]
inherited
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ getProperty() [2/2]
T &  value,
Args &...  args
inlineinherited
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References deepstream::Object::get_(), and deepstream::Object::getProperty().
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
inherited
◆ give() [2/2]
inherited
◆ handleKey() [1/2]
void deepstream::Pipeline::handleKey ( int  key)
◆ handleKey() [2/2]
◆ install() [1/2]
Pipeline& deepstream::Pipeline::install ( std::function< void(Pipeline &, int key)>  keyboard_listener)
inline
Definition at line 270 of file 9.0/service-maker/includes/pipeline.hpp.
References keyboard_listener_.
◆ install() [2/2]
inline
Definition at line 270 of file service-maker/includes/pipeline.hpp.
◆ isRunning() [1/2]
bool deepstream::Pipeline::isRunning ( ) const
◆ isRunning() [2/2]
◆ link() [1/4]
Pipeline& deepstream::Pipeline::link ( const std::string &  arg1,
inline
Definition at line 210 of file 9.0/service-maker/includes/pipeline.hpp.
References link().
◆ link() [2/4]
inline
Definition at line 210 of file service-maker/includes/pipeline.hpp.
References link().
◆ link() [3/4]
Pipeline& deepstream::Pipeline::link ( std::pair< std::string, std::string >  route,
Parameters
[in]routea pair with source element name and target element name
[in]tipsextra pair with source pad name and target pad name
◆ link() [4/4]
Parameters
Referenced by link().
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ listSignals() [2/2]
inherited
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file service-maker/includes/object.hpp.
◆ operator bool() [2/2]
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file service-maker/includes/object.hpp.
◆ operator==() [2/2]
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
◆ operator[]() [1/2]
Element& deepstream::Pipeline::operator[] ( const std::string &  name)
inline
Definition at line 189 of file service-maker/includes/pipeline.hpp.
References find().
◆ operator[]() [2/2]
inline
Definition at line 189 of file 9.0/service-maker/includes/pipeline.hpp.
References find().
◆ pause() [1/2]
Pipeline& deepstream::Pipeline::pause ( )
Pause the pipeline.
◆ pause() [2/2]
Pause the pipeline.
◆ prepare() [1/4]
int deepstream::Pipeline::prepare ( )
◆ prepare() [2/4]
◆ prepare() [3/4]
int deepstream::Pipeline::prepare ( std::function< void(Pipeline &, const Message &)>  listener)
◆ prepare() [4/4]
◆ resume() [1/2]
Pipeline& deepstream::Pipeline::resume ( )
◆ resume() [2/2]
◆ run() [1/2]
int deepstream::Pipeline::run ( )
protected
◆ run() [2/2]
protected
◆ run_after_prepare() [1/2]
int deepstream::Pipeline::run_after_prepare ( )
protected
◆ run_after_prepare() [2/2]
protected
◆ seek() [1/2]
Pipeline& deepstream::Pipeline::seek ( uint64_t  timestamp)
◆ seek() [2/2]
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ seize() [2/2]
inherited
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
◆ set() [2/6]
const T &  value,
inlineinherited
◆ set() [3/6]
const Value value
inlineinherited
Definition at line 154 of file service-maker/includes/object.hpp.
References deepstream::Object::set_().
◆ set() [4/6]
const Value value
inlineinherited
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
◆ set() [6/6]
inherited
Referenced by add(), and deepstream::Object::set().
◆ set_() [1/4]
virtual void deepstream::Object::set_ ( const std::string &  name,
const Value value
◆ set_() [2/4]
const Value value
◆ set_() [3/4]
const YAML::Node &  value
◆ set_() [4/4]
◆ start() [1/4]
Pipeline& deepstream::Pipeline::start ( )
Start the pipeline.
◆ start() [2/4]
Start the pipeline.
◆ start() [3/4]
Pipeline& deepstream::Pipeline::start ( std::function< void(Pipeline &, const Message &)>  listener)
◆ start() [4/4]
◆ startRecording() [1/2]
uint32_t deepstream::Pipeline::startRecording ( const std::string &  element_name,
uint32_t  startTime = 0,
uint32_t  duration = 0,
std::function< void(const RecordingInfo &)>  callback = [](const RecordingInfo &info) { printf("\nSource recorded at %s/%s. Duration %.2f sec\n", info.getFileDirectory().c_str(), info.getFileName().c_str(), info.getDuration()/1000.0);},
void *  userData = nullptr
Parameters
[in]element_namename of the nvurisrcbin element
[in]startTimeseconds of cached data to include before trigger (0 = from now)
[in]durationseconds to record (0 = element default)
[in]userDataoptional user data pointer passed to callback
◆ startRecording() [2/2]
Parameters
◆ startRTSP() [1/2]
uint32_t deepstream::Pipeline::startRTSP ( uint16_t  rtsp_port,
uint16_t  udp_port,
uint32_t  buffer_size = 0
◆ startRTSP() [2/2]
uint16_t  udp_port,
◆ stop() [1/2]
Pipeline& deepstream::Pipeline::stop ( )
Stop the pipeline.
◆ stop() [2/2]
Stop the pipeline.
◆ stopRecording() [1/4]
bool deepstream::Pipeline::stopRecording ( const std::string &  element_name)
Parameters
◆ stopRecording() [2/4]
Parameters
◆ stopRecording() [3/4]
bool deepstream::Pipeline::stopRecording ( uint32_t  sessionId)
Parameters
[in]sessionIdsession id returned by startRecording
◆ stopRecording() [4/4]
Parameters
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
inherited
◆ take() [2/2]
inherited
◆ type() [1/2]
static unsigned long deepstream::Object::type ( )
staticinherited
◆ type() [2/2]
staticinherited
◆ wait() [1/2]
Pipeline& deepstream::Pipeline::wait ( )
◆ wait() [2/2]
Field Documentation
◆ action_owners_
std::map< std::string, std::unique_ptr< SignalEmitter > > deepstream::Pipeline::action_owners_
protected
Definition at line 355 of file service-maker/includes/pipeline.hpp.
◆ bus_data_
void * deepstream::Pipeline::bus_data_ = NULL
protected
Definition at line 347 of file service-maker/includes/pipeline.hpp.
◆ bus_watch_id_
uint deepstream::Pipeline::bus_watch_id_ = 0
protected
Definition at line 345 of file service-maker/includes/pipeline.hpp.
◆ element_to_session_id
std::unordered_map< std::string, uint32_t > deepstream::Pipeline::element_to_session_id
protected
Definition at line 359 of file service-maker/includes/pipeline.hpp.
◆ elements_
std::map< std::string, Element > deepstream::Pipeline::elements_
protected
Definition at line 353 of file service-maker/includes/pipeline.hpp.
◆ keyboard_listener_
std::function< void(Pipeline &, int key)> deepstream::Pipeline::keyboard_listener_
protected
Definition at line 348 of file service-maker/includes/pipeline.hpp.
Referenced by install().
◆ loop_
void * deepstream::Pipeline::loop_ = NULL
protected
Definition at line 343 of file service-maker/includes/pipeline.hpp.
◆ object_
GstObject * deepstream::Object::object_
protectedinherited
◆ session_id_to_element
std::unordered_map< uint32_t, std::string > deepstream::Pipeline::session_id_to_element
protected
Definition at line 360 of file service-maker/includes/pipeline.hpp.
◆ start_pts_
uint64_t deepstream::Pipeline::start_pts_ = 0
protected
Definition at line 357 of file service-maker/includes/pipeline.hpp.
◆ thread_
std::thread deepstream::Pipeline::thread_
protected
Definition at line 351 of file service-maker/includes/pipeline.hpp.
