deepstream::Object Class Reference
Base Object class.
Definition at line 44 of file service-maker/includes/object.hpp.
Inheritance diagram for deepstream::Object:
Data Structures
class  Value
 Value wrapper for various types. More...
Public Member Functions
 Object ()
 Constructor of a void object. More...
 Object (unsigned long type_id, const std::string &name)
 Create an object from a type id. More...
 Object (const Object &)
 Copy constructor. More...
 Object (Object &&)
 Move constructor. More...
Objectoperator= (const Object &)
 Copy assignment. More...
Objectoperator= (Object &&)
 Move assignment. More...
virtual ~Object ()
 Destructor. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
 Object ()
 Object (Object &&)
virtual ~Object ()
 Destructor. More...
GstObjectgive ()
static unsigned long type ()
 Return the object's type id. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
GstObjectobject_
Friends
class Pipeline
class Element
◆ Object() [1/8]
deepstream::Object::Object ( )
◆ Object() [2/8]
deepstream::Object::Object ( unsigned long  type_id,
const std::string &  name
Parameters
[in]namename to be assigned to the object instance
◆ Object() [3/8]
deepstream::Object::Object ( const Object )
Copy constructor.
◆ Object() [4/8]
deepstream::Object::Object ( Object &&  )
Move constructor.
◆ ~Object() [1/2]
virtual deepstream::Object::~Object ( )
virtual
Destructor.
◆ Object() [5/8]
◆ Object() [6/8]
Parameters
◆ Object() [7/8]
Copy constructor.
◆ Object() [8/8]
Move constructor.
◆ ~Object() [2/2]
virtual
Destructor.
Member Function Documentation
◆ connectSignal() [1/2]
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ connectSignal() [2/2]
Parameters
◆ emitSignal() [1/2]
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
Emit a signal.
◆ emitSignal() [2/2]
va_list  args
Emit a signal.
◆ get_() [1/2]
virtual Value deepstream::Object::get_ ( const std::string &  name)
protectedvirtual
Reimplemented in deepstream::CustomObject, and deepstream::CustomObject.
Referenced by getProperty().
◆ get_() [2/2]
protectedvirtual
◆ getGObject() [1/2]
GstObject* deepstream::Object::getGObject ( )
inline
Definition at line 140 of file service-maker/includes/object.hpp.
References object_.
◆ getGObject() [2/2]
inline
Definition at line 140 of file 9.0/service-maker/includes/object.hpp.
References object_.
◆ getName() [1/2]
const std::string deepstream::Object::getName ( ) const
◆ getName() [2/2]
◆ getProperty() [1/2]
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inline
Definition at line 171 of file 9.0/service-maker/includes/object.hpp.
References get_(), and getProperty().
◆ getProperty() [2/2]
T &  value,
Args &...  args
inline
◆ give() [1/2]
GstObject* deepstream::Object::give ( )
◆ give() [2/2]
◆ listSignals() [1/2]
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
◆ listSignals() [2/2]
◆ operator bool() [1/2]
deepstream::Object::operator bool ( ) const
inlineexplicitnoexcept
Definition at line 131 of file service-maker/includes/object.hpp.
References object_.
◆ operator bool() [2/2]
Definition at line 131 of file 9.0/service-maker/includes/object.hpp.
References object_.
◆ operator=() [1/4]
Object& deepstream::Object::operator= ( const Object )
Copy assignment.
◆ operator=() [2/4]
Copy assignment.
◆ operator=() [3/4]
Object& deepstream::Object::operator= ( Object &&  )
Move assignment.
◆ operator=() [4/4]
Move assignment.
◆ operator==() [1/2]
bool deepstream::Object::operator== ( const Object other)
inlinenoexcept
Definition at line 134 of file service-maker/includes/object.hpp.
References object_.
◆ operator==() [2/2]
inlinenoexcept
Definition at line 134 of file 9.0/service-maker/includes/object.hpp.
References object_.
◆ seize() [1/2]
Object& deepstream::Object::seize ( GstObject object)
◆ seize() [2/2]
◆ set() [1/6]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inline
Definition at line 161 of file 9.0/service-maker/includes/object.hpp.
References set(), and set_().
◆ set() [2/6]
const T &  value,
inline
Definition at line 161 of file service-maker/includes/object.hpp.
◆ set() [3/6]
const Value value
inline
Definition at line 154 of file service-maker/includes/object.hpp.
References set_().
◆ set() [4/6]
const Value value
inline
Definition at line 154 of file 9.0/service-maker/includes/object.hpp.
References set_().
◆ set() [5/6]
Object& deepstream::Object::set ( const YAML::Node &  params)
Referenced by deepstream::Pipeline::add(), and set().
◆ set() [6/6]
◆ set_() [1/4]
virtual void deepstream::Object::set_ ( const std::string &  name,
const Value value
protectedvirtual
◆ set_() [2/4]
const Value value
protectedvirtual
Referenced by set().
◆ set_() [3/4]
const YAML::Node &  value
protectedvirtual
◆ set_() [4/4]
protectedvirtual
◆ take() [1/2]
Object& deepstream::Object::take ( GstObject object)
◆ take() [2/2]
◆ type() [1/2]
static unsigned long deepstream::Object::type ( )
static
◆ type() [2/2]
static
Friends And Related Function Documentation
◆ Element
Element
friend
Definition at line 205 of file service-maker/includes/object.hpp.
Referenced by deepstream::Pipeline::add().
◆ Pipeline
Pipeline
friend
Definition at line 204 of file service-maker/includes/object.hpp.
Field Documentation
◆ object_
GstObject * deepstream::Object::object_
protected
Definition at line 198 of file service-maker/includes/object.hpp.
Referenced by getGObject(), operator bool(), and operator==().
