Metadata for overlay display on a frame.
The metadata is for nvosd element display various shapes on the curernt frame.
Definition at line 372 of file metadata.hpp.
Public Types | |
| typedef std::unique_ptr< AbstractIterator< DisplayMetadata > > | Iterator |
Public Member Functions | |
| DisplayMetadata (void *data=nullptr) | |
| Constructor through opaque data pointer. More... | |
| virtual | ~DisplayMetadata () |
| Destructor. More... | |
| unsigned int | nRects () const |
| Number of the rectangles. More... | |
| unsigned int | nLabels () const |
| Number of the labels. More... | |
| unsigned int | nLines () const |
| Number of the lines. More... | |
| unsigned int | nArrows () const |
| Number of the arrows. More... | |
| unsigned int | nCircles () const |
| Number of the circles. More... | |
| bool | add (NvOSD_TextParams &) |
| Add a text label. More... | |
| bool | add (NvOSD_RectParams &) |
| Add a rectangle. More... | |
| bool | add (NvOSD_LineParams &) |
| Add a line. More... | |
| bool | add (NvOSD_ArrowParams &) |
| Add an arrow. More... | |
| bool | add (NvOSD_CircleParams &) |
| Add a circle. More... | |
| virtual | operator bool () |
| operator to check if a metadata is void More... | |
Protected Attributes | |
| void * | data_ |
Friends | |
| class | FrameMetadata |
| typedef std::unique_ptr<AbstractIterator<DisplayMetadata> > deepstream::DisplayMetadata::Iterator |
Definition at line 374 of file metadata.hpp.
| deepstream::DisplayMetadata::DisplayMetadata | ( | void * | data = nullptr | ) |
By default an empty display metadata object is created.
virtual |
Destructor.
| bool deepstream::DisplayMetadata::add | ( | NvOSD_ArrowParams & | ) |
Add an arrow.
| bool deepstream::DisplayMetadata::add | ( | NvOSD_CircleParams & | ) |
Add a circle.
| bool deepstream::DisplayMetadata::add | ( | NvOSD_LineParams & | ) |
Add a line.
| bool deepstream::DisplayMetadata::add | ( | NvOSD_RectParams & | ) |
Add a rectangle.
| bool deepstream::DisplayMetadata::add | ( | NvOSD_TextParams & | ) |
Add a text label.
Referenced by deepstream::CountMarker::handleData().
| unsigned int deepstream::DisplayMetadata::nArrows | ( | ) | const |
| unsigned int deepstream::DisplayMetadata::nCircles | ( | ) | const |
| unsigned int deepstream::DisplayMetadata::nLabels | ( | ) | const |
| unsigned int deepstream::DisplayMetadata::nLines | ( | ) | const |
| unsigned int deepstream::DisplayMetadata::nRects | ( | ) | const |
inlinevirtualinherited |
Reimplemented in deepstream::UserMetadata.
Definition at line 51 of file metadata.hpp.
References deepstream::Metadata::data_.
friend |
Definition at line 408 of file metadata.hpp.
protectedinherited |
Definition at line 54 of file metadata.hpp.
Referenced by deepstream::Metadata::operator bool(), and deepstream::UserMetadata::operator bool().
