deepstream::EventMessageUserMetadata Class Reference
User metadata for event message.
Objects can be attached to the event message meta for triggering an event in "nvmsgconv" element.
Definition at line 242 of file service-maker/includes/metadata.hpp.
Inheritance diagram for deepstream::EventMessageUserMetadata:
Collaboration diagram for deepstream::EventMessageUserMetadata:
Public Types
typedef std::unique_ptr< AbstractIterator< UserMetadata > > Iterator
Public Member Functions
 EventMessageUserMetadata (void *data=nullptr)
virtual ~EventMessageUserMetadata ()
void generate (const ObjectMetadata &, const FrameMetadata &, const std::string sensor="N/A", const std::string uri="N/A", const std::vector< std::string >labels=std::vector< std::string >())
 generate an event by attaching an object More...
virtual operator bool () override
 operator to check if a metadata is void More...
int metaType () const
 Get the meta type. More...
void setMetaType (int type)
 Set the meta type. More...
void * userData () const
 Get the user data pointer. More...
void setUserData (void *data, void *(*copy)(void *, void *), void(*release)(void *, void *))
 Set user data with copy and release functions. More...
Protected Member Functions
void get_ (void *&)
void get_ (void *&)
Protected Attributes
void * data_
Member Typedef Documentation
◆ Iterator [1/2]
Definition at line 103 of file service-maker/includes/metadata.hpp.
◆ Iterator [2/2]
Definition at line 103 of file 9.0/service-maker/includes/metadata.hpp.
◆ EventMessageUserMetadata() [1/2]
deepstream::EventMessageUserMetadata::EventMessageUserMetadata ( void *  data = nullptr)
◆ ~EventMessageUserMetadata() [1/2]
virtual deepstream::EventMessageUserMetadata::~EventMessageUserMetadata ( )
virtual
◆ EventMessageUserMetadata() [2/2]
◆ ~EventMessageUserMetadata() [2/2]
virtual
Member Function Documentation
◆ generate() [1/2]
void deepstream::EventMessageUserMetadata::generate ( const ObjectMetadata ,
const FrameMetadata ,
const std::string  sensor = "N/A",
const std::string  uri = "N/A",
const std::vector< std::string >  labels = std::vector< std::string >()
Referenced by deepstream::MsgMetaGenerator::handleData().
◆ generate() [2/2]
◆ get_() [1/2]
◆ get_() [2/2]
void deepstream::UserMetadata::get_ ( void *&  )
protectedinherited
◆ metaType() [1/2]
int deepstream::UserMetadata::metaType ( ) const
inherited
Get the meta type.
◆ metaType() [2/2]
inherited
Get the meta type.
◆ operator bool() [1/2]
virtual deepstream::UserMetadata::operator bool ( )
inlineoverridevirtualinherited
Reimplemented from deepstream::Metadata.
Definition at line 116 of file 9.0/service-maker/includes/metadata.hpp.
References deepstream::Metadata::data_.
◆ operator bool() [2/2]
Definition at line 116 of file service-maker/includes/metadata.hpp.
◆ setMetaType() [1/2]
void deepstream::UserMetadata::setMetaType ( int  type)
inherited
Set the meta type.
◆ setMetaType() [2/2]
inherited
Set the meta type.
◆ setUserData() [1/2]
void deepstream::UserMetadata::setUserData ( void *  data,
void *(*)(void *, void *)  copy,
void(*)(void *, void *)  release
inherited
Parameters
dataPointer to user data
copyCopy function for the user data (can be NULL)
releaseRelease function for the user data (can be NULL)
◆ setUserData() [2/2]
inherited
Parameters
◆ userData() [1/2]
void* deepstream::UserMetadata::userData ( ) const
inherited
◆ userData() [2/2]
inherited
Field Documentation
◆ data_
void * deepstream::Metadata::data_
protectedinherited
