7.1 Release
nvdsinferserver::BasePreprocessor Class Referenceabstract
Base preprocessor class.
Definition at line 79 of file infer_iprocess.h.
Inheritance diagram for nvdsinferserver::BasePreprocessor:
Collaboration diagram for nvdsinferserver::BasePreprocessor:
Public Types
using PreprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
 ~BasePreprocessor () override=default
 Destructor default. More...
NvDsInferStatus transform (SharedBatchArray src, SharedCuStream mainStream, PreprocessDone done) override
 Perform the transformation on the input buffer from the buffer array, indexed using m_TransformIdx. More...
virtual NvDsInferStatus allocateResource (const std::vector< int > &devIds)=0
 Allocate resource like output buffer pool. More...
Member Typedef Documentation
◆ PreprocessDone
Definition at line 44 of file infer_iprocess.h.
◆ ~BasePreprocessor()
nvdsinferserver::BasePreprocessor::~BasePreprocessor ( )
overridedefault
Destructor default.
Member Function Documentation
◆ allocateResource()
virtual NvDsInferStatus nvdsinferserver::BasePreprocessor::allocateResource ( const std::vector< int > &  devIds)
pure virtual
Parameters
[in]devIdsList of device IDs.
Returns
Error status.
Implemented in nvdsinferserver::NetworkPreprocessor.
◆ setTransformIdx()
void nvdsinferserver::BasePreprocessor::setTransformIdx ( int  idx)
inline
Definition at line 92 of file infer_iprocess.h.
◆ setUniqueId()
void nvdsinferserver::BasePreprocessor::setUniqueId ( int  id)
inline
Definition at line 90 of file infer_iprocess.h.
◆ transform()
NvDsInferStatus nvdsinferserver::BasePreprocessor::transform ( SharedBatchArray  src,
PreprocessDone  done
inlineoverridevirtual
Parameters
[in]srcThe input batch buffer array.
[in]mainStreamThe main processing CUDA stream.
[in]doneThe call function to be called after transformation.
Returns
NVDSINFER_SUCCESS or NVDSINFER_RESOURCE_ERROR.
Implements nvdsinferserver::IPreprocessor.
Definition at line 103 of file infer_iprocess.h.
References NVDSINFER_RESOURCE_ERROR, and NVDSINFER_SUCCESS.
◆ uniqueId()
int nvdsinferserver::BasePreprocessor::uniqueId ( ) const
inline
Definition at line 91 of file infer_iprocess.h.
