7.1 Release
nvdsinferserver::NetworkPreprocessor Class Reference
Preprocessor for scaling and normalization of the input and conversion to network media format.
Definition at line 51 of file infer_preprocess.h.
Inheritance diagram for nvdsinferserver::NetworkPreprocessor:
Collaboration diagram for nvdsinferserver::NetworkPreprocessor:
Public Types
using PreprocessDone = std::function< void(NvDsInferStatus, SharedBatchArray)>
Public Member Functions
 NetworkPreprocessor (const NvDsInferNetworkInfo &info, InferMediaFormat networkFormat, InferDataType dt, int maxBatchSize)
virtual ~NetworkPreprocessor ()=default
bool setScaleOffsets (float scale, const std::vector< float > &offsets={})
bool setMeanFile (const std::string &file)
void setNetworkTensorOrder (InferTensorOrder order)
void setPoolSize (int size)
int poolSize () const
void setNetworkTensorName (std::string name)
const BatchSurfaceInfogetDstSurfaceInfo () const
NvDsInferStatus allocateResource (const std::vector< int > &devIds) override
NvDsInferStatus syncStream ()
NvDsInferStatus transform (SharedBatchArray src, SharedCuStream mainStream, PreprocessDone done) override
 Perform the transformation on the input buffer from the buffer array, indexed using m_TransformIdx. More...
void setUniqueId (int id)
int uniqueId () const
void setTransformIdx (int idx)
Protected Member Functions
NvDsInferStatus readMeanImageFile ()
 DISABLE_CLASS_COPY (NetworkPreprocessor)
Member Typedef Documentation
◆ PreprocessDone
Definition at line 44 of file infer_iprocess.h.
◆ NetworkPreprocessor()
nvdsinferserver::NetworkPreprocessor::NetworkPreprocessor ( const NvDsInferNetworkInfo info,
InferDataType  dt,
int  maxBatchSize
◆ ~NetworkPreprocessor()
virtual nvdsinferserver::NetworkPreprocessor::~NetworkPreprocessor ( )
virtualdefault
Member Function Documentation
◆ allocateResource()
NvDsInferStatus nvdsinferserver::NetworkPreprocessor::allocateResource ( const std::vector< int > &  devIds)
overridevirtual
◆ DISABLE_CLASS_COPY()
nvdsinferserver::NetworkPreprocessor::DISABLE_CLASS_COPY ( NetworkPreprocessor  )
protected
◆ getDstSurfaceInfo()
const BatchSurfaceInfo& nvdsinferserver::NetworkPreprocessor::getDstSurfaceInfo ( ) const
inline
Definition at line 65 of file infer_preprocess.h.
◆ poolSize()
int nvdsinferserver::NetworkPreprocessor::poolSize ( ) const
inline
Definition at line 63 of file infer_preprocess.h.
◆ readMeanImageFile()
NvDsInferStatus nvdsinferserver::NetworkPreprocessor::readMeanImageFile ( )
protected
◆ setMeanFile()
bool nvdsinferserver::NetworkPreprocessor::setMeanFile ( const std::string &  file)
◆ setNetworkTensorName()
void nvdsinferserver::NetworkPreprocessor::setNetworkTensorName ( std::string  name)
inline
Definition at line 64 of file infer_preprocess.h.
◆ setNetworkTensorOrder()
void nvdsinferserver::NetworkPreprocessor::setNetworkTensorOrder ( InferTensorOrder  order)
inline
Definition at line 59 of file infer_preprocess.h.
◆ setPoolSize()
void nvdsinferserver::NetworkPreprocessor::setPoolSize ( int  size)
inline
Definition at line 62 of file infer_preprocess.h.
◆ setScaleOffsets()
bool nvdsinferserver::NetworkPreprocessor::setScaleOffsets ( float  scale,
const std::vector< float > &  offsets = {}
◆ setTransformIdx()
void nvdsinferserver::BasePreprocessor::setTransformIdx ( int  idx)
inlineinherited
Definition at line 92 of file infer_iprocess.h.
◆ setUniqueId()
void nvdsinferserver::BasePreprocessor::setUniqueId ( int  id)
inlineinherited
Definition at line 90 of file infer_iprocess.h.
◆ syncStream()
NvDsInferStatus nvdsinferserver::NetworkPreprocessor::syncStream ( )
◆ transform()
NvDsInferStatus nvdsinferserver::BasePreprocessor::transform ( SharedBatchArray  src,
PreprocessDone  done
inlineoverridevirtualinherited
Parameters
[in]srcThe input batch buffer array.
[in]mainStreamThe main processing CUDA stream.
[in]doneThe call function to be called after transformation.
Returns
NVDSINFER_SUCCESS or NVDSINFER_RESOURCE_ERROR.
Implements nvdsinferserver::IPreprocessor.
Definition at line 103 of file infer_iprocess.h.
References NVDSINFER_RESOURCE_ERROR, and NVDSINFER_SUCCESS.
◆ uniqueId()
int nvdsinferserver::BasePreprocessor::uniqueId ( ) const
inlineinherited
Definition at line 91 of file infer_iprocess.h.
